Purchased a DiVinici 6.1 Theater System, Question, what type of receiver do I need for this system, and what type of wiring do I need. Thanks
    Brigadier General:
  • 8,546 Answers
Does it have a model number? Didn't they come with instructions?
Oh, did you buy this from a scam artist? Google "DiVinici theatre system" before you invest much more in supporting it.
http://www.hometheaterforum.com/forum/thread/241054/davinci-audio
To answer your question - any QUALITY multichannel audio/video receiver would be a good start toward owning legitimate higher-end audio. I'm a Pioneer fan myself. VSX-series.
Posted on Mar 17, 2011
Do you have a owners manual for a D-710 Divinici Receiver Amplifier? ??
Fixya doesn't. Try Googling (Divinici)(D-710)(manual) without parens.
Sep 09, 2016 | Audio Players & Recorders
Have a sony home theater system model davfr10w but the receiver is jumping from sat which is where Iwant if to dvd??? Can anyone give some input on this problem Thanks
I have the same problem. Purchased mine in 2005....went out in 2010.
My Sonny dealer could not fix. They talked to Sony and they wanted $230
to repair with no warranty. I'm trying to find a replacement but no luck.
Dec 02, 2012 | Sony DAV-FR10W System
Can i hard wire my rt 2770 rca home theater subwoofer to my receiver lost white plug that plugs into receiver and can't find a new one?
I have one if you still need it. Hooked my sub up to a different receiver and cut that end off to hard wire it. It has about a foot of wire and the white plug on the end that goes into the receiver.
May 11, 2012 | RCA home theater system RT2770 User Manual
I have and lg tv and a samsung home theater
optical audio cable from home theater to tv. can be purchased on line for a few bucks.
Dec 21, 2009 | LG LHT854 Theater System
5.1 Dolby system does not work with the T.V.
Solution: connected the rear right and left wires to the Front , left and right wires......................and everything works the way I anticipated without any technical problems....... the woofer works on a separate circuit, so I continue to receive the "low" frequency..
Oct 01, 2009 | Memorex MiHT5005 Theater System
System works great with dvd, radio, and ipod dock. But when listening to the tv through the system, the sound is very low even when the volume is at its max.
It sounds like either the input selected to the receiver is wrong, the wires are not hooked up correctly, or the wires are bad. What type of connection are you using-RCA jacks, DVi connector, etc?
Jul 14, 2009 | Sony BRAVIA® DAV-HDX277WC Theater System...
How to connect this entertainment system to existing sony recieve
This is a standalone system. It can't be used with a receiver. Sorry.
Dec 29, 2008 | Jwin JD-VD625 System
Hook up
Karri, I do not have the photo of the back, but attached is a general wiring diagram for any Audio-video Home theater system. If you have a Home Theater Receiver, then hook it up as the diagram. If not, hook it up per the comments in the diagram. This is how I hooked up my ONKYO HT system with my SONY Combo DVD recorder and my Mitsubishi TV. One thing to note on Combos, is that the VCR Tape section will not play through the High Definition connections (HDMI, and Digital Audio). You have to use the older method of Audio-Video (AV) cables or the Co-axial antenna cables. You can ask more questions if there is any confusions. Hope this helps you. Good luck.
Aug 30, 2007 | Pioneer VSX-454 Receiver
Home theater reception
you need to unlpug your set and reconnect everything over and see what it does.if that does not work have a tech check your system.your sony recviever is the culprit let that be checked.good luck
Apr 05, 2007 | Sony KP-53XBR45 53" Rear Projection...
53 people viewed this question
 Grubhead
Grubhead
