Question about Canon MP640 All-In-One InkJet Printer
My printer MP640 got message as 6C10 , i had follow the instuction in you solution but they do'nt work , do you got other way . Thanks
  • 812 Answers
Hello and Welcome to FixYa
Error 6c10 is ink absorber problem.You need to reset Printer Canon ink absorber. Follow the steps given below
  • Start with printer off
  • Press and hold resume Button (triangle in the circle) and click "Power" button. Green led should be on
  • While holding the Power button, release the Resume Button.
  • Without releasing the Power Button, click "Resume" button for two times and release Both Buttons.
  • Click "Resume" for four times then soon click "Power" button, to confirm the selected action (reset counter absorber).
  • Turn off the printer and turn on again
Error will be removed
Anymore help, I am here to help
Thank you for using FixYa
Posted on Mar 17, 2011
  • XXJASONXX May 12, 2011
    I have same error 6C10 on the same printer MP640. I have used the solution above but it did not work for me. Any other ideas ?
Disconnect the printer from the power source and the pc.
Close the rear feed tray.
Close the front tray.
Lift the printer from the front with both hands so that it is above your head.
Bring the printer down aain with as much force as possible so that it smashes on the floor.
if this doesnt work try throwing it out of the window.
Posted on Jul 05, 2012
  • MadMarty Jul 05, 2012
  • Linda Mee
    Linda Mee Jan 29, 2013
    It worked!!
PIXMA MP640 6C10 fout
You need to replace the ink absorber and reset the error code by following the reset procedure:
Resetting error 6c10
Dec 23, 2012 | Canon PIXMA iP4600 Color InkJet Photo...
Canon printer 6c10 error
Did you try IPA to clean the absorber then leave it to dry COMPLETELY. Also some printers have a small electrical connection to detect when the absorber is at capacity, check these contacts.
Oct 03, 2012 | Canon Pixma MP640 All-In-One InkJet...
6C10 error cannon printer MP640
This error could appear on these Canon Pixma printers: MP110, MP540, MP630, MP620, MP640, IP3600...
Solution 1:
  • Move the printhead to the center.
  • Disconnect the printer and check on the right: is the purge unit ok ? No peace of paper ?
Solution 2:
  • Do a reset of the printer:
  • Power on
  • Hold down the "Resume" button (triangle in a circle) for 15 to 20 seconds.
Solution 3:
  • Power off the printer.
  • Open the door.
  • Power on.
  • When the cartridge is in the center, close the door.
Solution 4:
  • Open the lid and allow the ink cartridge carrier to center itself.
  • Looking to the right, you will see a row of white rollers behind the carrier.
  • At the end of the rollers there is a small, clear piece of plastic that sticks up. Take a small piece of a paper towel and wipe all of the ink off this piece of plastic. When that is clean move on to the ink pad.
  • About 1 inch, towards the front of the printer from that piece of plastic, is a small square, about 1/2 inch per side, that is a small foam pad. This is where the excess ink is collected.
  • Take a piece of paper towel and press into the foam. Do this until the paper towel is no longer collecting ink. Close the lid, turn off the printer then turn it back on.
source: http://fix-your-printer.blogspot.com/2011/06/how-to-fix-error-6c10-on-canon-printers.html
Jul 04, 2012 | Canon MP640 All-In-One InkJet Printer
Canon MP640 has 6C10 error, I have used the service mode and restore button x4 to reset absorber counter, but this stops the error until you go to print - then the next document returns the same 6C10 error...
my canno mp640 will not print in black, have replaced the 521/520 carterages new also a new printhead, and stiil it will not print,yet it prints colors ok. can you help please
DD.
May 12, 2011 | Canon MP640 All-In-One InkJet Printer
My printer is only 5weeks old / installed end of March and i have this error message on the display screen 6C10 I have tried ti turn the printer off and back on again but the error still occurres. Do...
This error is caused when the ink absorber has got full and needs to be replaced.
This is something you can get done by a local service centre or a Canon service centre.
Andy
May 02, 2011 | Canon MP640 All-In-One InkJet Printer
6c10 errror message on canon mp640, tried suggested moving of printcartridge holder, no go. Any suggestions?
Hi, I solved this by doing a "cleaning roller" (dont know the right word in english) from the settings -> maintenance menu of the MP640. Good luck!
Oct 24, 2010 | Canon MP640 All-In-One InkJet Printer
Hi Guys...I have a MP640 which is showing a 6C10 error...Please Please Help...I have soo much work to do that is pileing up....
Hey you, I solved this problem by doing a "cleaning roller" (dont know if this is the right english term) for the paper cassett. You can do this via the settings -> maintenance menu of MP640. Best regards!
Jul 30, 2010 | Canon PIXMA MP540 All-In-One InkJet...
Canon MP620 Printer has 6c10 error message. Nothing I have tried seems to work. It will not power down unless I unplug it. Then when powering up th ecode comes back again in about a minute.
after youll be sure that you have communication with your internet modem ! delete your printer from your computer and install it again. at list thats what i did with my mp640 on my mac book. system preferences/print + fax. i suppose its something similar with the pc. i solve my problem this way. hope i help.
Apr 28, 2010 | Canon PIXMA MP620 All-In-One InkJet...
Canon MP640 All-In-One InkJet Printer Logo
2,067 people viewed this question
old marine
old marine
