Thanks for the answer - If we have 3 controls as Bass, Mid and Treble. If we keep those in 12 O Clock position, will the output level be equal. In using the Bass and Treble control only (if we have only two controls as Bass and Treble), controlling these knobs will affect the mid range adjustment - meaning will the relative Mid range frequencies be increased or decreased.
  • 396 Answers
Depending on the design of the amplifier, Bass could be in the range of 20Hz to 200Hz, Mid Range could be between 400Hz to 2. 5KHz and Treble could be in the range of 5KHz to15-20KHz. When you adjust the Bass and Treble the Mid Range should not be effected, unless the amplifier tone filter has a broad band width. Keep in mind, what we hear is a derivative of many frequencies called harmonics. This means an instrument or vocal is not one frequency. It is a combination of many frequencies, which could be in the Low, Mid and High range. There is no easy way to answer this question because of the amount of variables, which exists. The variables are; amplifier design, speaker types and room acoustics. The amplifier has an electronic filter which will limit or boost a specific range of the frequencies in the audible sound spectrum approximately 20Hz to 20KHz. The speakers have a Cross Over which separates the Bass, Mid Range and High frequencies to the Woofer Mid Range and Tweeter speakers which could affect your frequency response. The Room Acoustics could absorb audio frequencies in furniture and curtains or echo of the walls. The most effective way to adjust your sound system is to use an audio spectrum analyzer and play white noise (all audio frequencies at the same amplitude) which sounds like static. Using the spectrum analyzer the visual graph of the white noise should be equal at the same amplitude throughout the audio spectrum. If it is not then you should adjust the equalizer ( Bass, Mid Range and Treble) to boost or limit the sound in that spectrum range. However, two or three adjustments will not adjust your sound system perfectly. You will need a parametric or graphic equalizer to archive optimum results. Once you have adjusted your system you will hear music how the audio engineers and musicians intended it to be heard. I hope I did not confuse you and did not over answer your question. However, I wanted to explain the adjustments so you can appreciate your sound system more than just adjusting the audio for your personal preference.
Posted on Mar 17, 2011
  • 3,400 Answers
If all are in 12 o'clock position they are "flat" (nothing has been added or subtracted foam input signal) If you only have bass & treble, yes adjusting will affect "mids" but Mids change can go both ways dependent on increase or decrease of Bass and /or treble. By increasing bass you will pull some mids up also. By increasing treble you'll subtract some mids.
SOURCE:
Zone 2
I would consult your owner's manual but I don't think you can adjust the bass/treble levels on the zone 2 outputs.
May 21, 2013 | Denon DRA-397
Does the alpine 9845rb have a clock display?
yes it does see below
  • CD receiver with built-in amplifier (16 watts RMS/45 peak x 4 channels)
  • detachable face with Quick Search button
  • plays audio CDs, CD-Rs, and CD-RWs including discs burned with MP3 and WMA files
  • Bass Engine (bass center frequency, width, and level, plus treble center frequency and level adjustments)
  • BBE sound processing
  • two sets of preamp outputs
  • rear-panel minijack auxiliary input
  • clock
  • CEA-2006 compliant
  • CD frequency response 5-20,000 Hz
  • CD signal-to-noise ratio 105 dB
  • FM sensitivity 9.3 dBf
  • warranty: 1 year
Jun 02, 2011 | Car Audio & Video
In most of the Amplifiers we have only Bass and Treble control (Bass works on 100 HZ and Treble works on 10KHz - approximately). In some Amplifiers we have Mid range control also. What is the frequency...
The frequency of mid range control is about 1KHz. The bass and treble are usually enough to set the tone of sounds and music, and if the customer has high quality speakers connected to the amplifier it is almost unnecessary to modify any tone. In my opinion you are right that x-band equalizer became less important now.
Thank you.
gylacz
Mar 17, 2011 | Audio Players & Recorders
How to turn sound on phillips plasma 32 inch tv
Hello
I thinks that you want to tune your TVs sound parameters, and answers. As you know, when the TV is switched on it will display picture as well as sound, according to the volume level setting. If you want the qulality of sound much more better, by pressing Menu button and higlight the opton 'Sound'. As you select, there will be a 'tick' mark appears, indicating that sound option is selected. On to the right side, there will be Bass, Treble,and balance control displays. Use "Cursor Up" button to go box 'Bass", and increse or decrese Bass lavel as you likes. If you wants to adjust treble, use "Curser Right" button and do as previous to your taste. Come to the "Balance" option by using "Cursor Up or Dn' keys and set it to mid position. There will be indication for its mid position, and it should be in that position, so that you can hear sound from both speakers equally.
All jumpings and adjustments can be done with 'CursorUp, CurserDn, CursorLeft, CurserRight' Ok.
Oct 31, 2010 | Philips 32PT6441/37 32" TV
Where do the cables go to hook up Beheringer EQ to2222mixer?
In the mixer there is an AUX with an input and output together. The output of teh equaliser must be connected to the input of the aux and the output must be given to the power amplifier. Make sure to keep the R&L channels in order from the source to the amplifier.
Adjust accordingly your equaliser to your requirement. Keep the bass and treble in your amp to mid position and boost only if required. Hope this helps you to connect. Good day
Jun 24, 2010 | Behringer Audio Players & Recorders
Line 6 Spider III 15W- My Bass and Drive knobs arnt working... my mid and treble seems to be fine plus all my channels and effects but just those two knobs...and its buggin the **** out of me.... any...
resolder the three legs of the pots back down to the pcb. usually the treble feeds the bass, then from bass to mid then to ground. so if treble and mid are working its hard to imagine why the bass wouldnt be working. i would try to resolder, as you might have cold solder joints. keep it unplugged, pull off the knobs, open it up, remove the pcb screws and pull/flip out the pcb and resolder all of the pots.
May 25, 2010 | Line 6 Spider Iii 15 Modeling Guitar...
How to get the best sound
punk and metal tones (late 80s): treb-7 mid-6-7 bass 6-8, presence 6-10, gain/distortion all the way up. classic rock just turn down the gain/distortion to 6-7. bridge pickup
metal mid 90s & up: treb 6-7, mids 3-5, bass 7-9, gain all the way up, presence (which is a mid and treble boost) 4-6. bridge pickup
blues SRV: treb 6, mid 6, bass 7.5, presence 8, gain 5, reverb (if you got it). use your neck pick up
of course this is subjective and depends on the guitar, cable quality, etc. it looks like a small speaker with a low watt output. that little speaker in there is going to be hard to articulate any tones. more than likely it will have a harsh bit to it cause the value of the pots and the logarythm you hear. reduce treble as needed to smooth out the harsh, keep the mids up.
Nov 02, 2009 | Washburn Amplifiers: 25 WATT Guitar...
Where are the bass,treble,mids,high on a basic EQ.I have an 12 band stereo eq.what #'s are the bass,etc.
Bass will be anything below 300Hz, mid will be 300Hz to 5KHz (Voice), above 5KHz will be Treble.
Nov 01, 2009 | Audio Players & Recorders
Can't adjust bass and treble
The only adjustments available on the unit are Volume and Bass (Subwoofer Level). There are no Mid-Bass or Treble adjustments.
Sep 20, 2009 | Jasco GE 98903 2.1 Speakers
How to access bass and treble controll
there should be and audio button on the face plate...keep pushin it till it says bass mid or treble...then use the up down left and right buttons....
Jan 15, 2009 | Pioneer DEH-P7700MP CD Player
190 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
