Question about HP Officejet 6500 Wireless All-in-One InkJet Printer
Put in new ink HP office Jet 6500 and error comes up "Yhe print head appears to be missing or broken.
  • HP Master
  • 1,591 Answers
Lift the lid and Remove the offending printhead (K/Y or C/M)
With a q-tip moistened (not dripping) with bottled water, clean the CONTACTS only on the head, and in the printer.
"pound 6" the printer (click here for the procedure or paste this link in your browser address box http://www.fixya.com/support/r8534283-hp_all_in_one_printer_acting_up )
Reinsert the head when it complains it's missing.
The printer will whir and click and gyrate for some period...be patient.
If that doesn't fix the problem, you may need a new head. These are available where you buy your ink.
Posted on Mar 17, 2011
COLOURS ON MY HP OFFICE JET 6500 NOT RECOGNISED
make sure cartridge is fully seated it may not be. when you clean the ink carts you should use isopropyl alcohol to provent it from shorting out the cartridge or the circuit board on the carriage where the cartridge is seated. alcohol will evaporate water won't
Nov 19, 2015 | HP Officejet 6500 Wireless All-in-One...
Why is my hp office jet 6500 A Plus is printing very light
Check settings on page setup in your PC application (File - page setup) - it may be set to LIGHT or ECONOMY MODE or similar
Or, your ink is nearly out.
Or, your paper is too glossy and ink is not distributing well
Jul 31, 2014 | HP Officejet 6500 Wireless All-in-One...
HP Photosmart B210a error message
Simple. Remove the ink and printhead. You can remove printhead by pulling gray latch up and sliding printhead up and out. Clean printhead gunk off using warm running water. Remove any ink gunk on the right side of printer if you see any. Turn printer off and on. See if problem went away. If it did, try putting the cleaned printhead inside printer again. If problem comes back, seems like the issue is with a bad printhead. Below are video instructions on cleaning head manually. The printheads are not same. B210 printhead is not the same with HP 6500, but instructions are same.
Jun 07, 2017 | HP DeskJet F4280 All In One Printer InkJet
I have a HP Office Pro L7580, model #C8187A. I am getting white horizontal lines across my documents. The white lines appear about every two to three inches. The top portion of the letters are missing
The black print head has a few blocked nozzles.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Apr 04, 2013 | HP Officejet Pro L7580 All-In-One InkJet...
My HP 6500 wont print black ink. It's like a very very light grey and I can't see it. Tried 2 new print cartridges and no luck. Please help.
The HP 6500 printer has separate in cart and print heads. The light print you are getting is because the print head in clogged with dry ink. First thing to try is to go into the printer software on your computer and do a print head cleaning procedure, this will take a few minutes to finish. You may have to run this several times to clear out the dry ink. If this does not solve the problem when you will need to get a replacement print head, the part number is CB868-30002
Sep 25, 2012 | HP Officejet 6500 Wireless All-in-One...
The printer is not printing, ink is new
Ink means cartridges? but what about print heads?..go to tool box perform clean nozzles, check if not satisfied do this process twice or thrice. check print quality if you found yellow or black missed replace left print head, magenta or cyan missed replace right print head.. part number on print heads..
Sep 27, 2011 | HP Officejet 6500 Wireless All-in-One...
I have a hp 6500 officejet wireless printer that i jut put in new ink cartridge and all it does is print blank pages?
This happens as the ink needs some time to saturate the system. Usually one needs to print quite a few pages for the ink to flow through and get to the ink head. A better quicker way is to clean the ink heads with the aid of the software that came with your printer.
Navigate to your windows control panel and double click printers and faxes. Then right click on your HP Officejet 6500 printer and select properties. Then click the Print test page button. Check the manual for cleaning the ink head.
Take care!
damnor01
Aug 30, 2011 | HP Officejet 6500 Wireless All-in-One...
HP OFFICEJET 6500 WIRELESS INK SYSTEM FAILURE
You can click on the link below to see step by step instruction to resolve the Ink system faliure error. These messages comes due to cartridge or print head issues.
Click here >>> Ink system faliure
Regards,
Shrey
May 28, 2011 | HP Officejet 6500 Wireless All-in-One...
HP Officejet 6500 Wireless All-in-One InkJet Printer Logo
188 people viewed this question
Seeker5211
Seeker5211
