Question about Dyson DC33 Bagged Upright Vacuum
How to change the belt on a dyson dc 33 - Dyson DC33 Bagged Upright Vacuum
  • Anonymous Mar 22, 2014
    What belt does the Dyson dc 33 use
    Sergeant:
  • 319 Answers
With a small torx driver (not the folding kind, the screw driver kind) and some patience, the belts can be replaced pretty easily. They run about 10 bux for both (you may as well change both). Dyson, like most manufacturers, makes it seem difficult in the hopes that you'll send it back to them for repair, where they will most likely sell you the whole clutch assembly because its easier to replace than fiddling with belts.
Posted on Aug 31, 2012
  • superjulimaximo
    superjulimaximo Sep 06, 2014
    Dyson would love to nickel and dime you, not to mention shipping there and back if you don\'t go to one of those "Authorized Service Center" dungeons. It is quite simple to replace this belt despite what they say and you can get it cheap on eBay. I\'ve done it twice, quite successfully I might add. I am not and engineer although I do happen to know my way around a toolbox. Maybe I\'m a genius and don\'t know it. If that\'s the case, I\'m sure you are too. Thus, you can do it too. Happy fixing.
  • Official Brand Answer
  • 2,572 Answers
DC33 is fitted with a Brush Control system which uses belts designed to last the lifetime of the machine, and which are not user-serviceable.
If you're experiencing a problem with your Dyson, please get in touch with us free on 08002980298 (UK), or 1866MYDYSON (US), so we can assist you.
Kind regards,
Jack
Dyson Customer Service
Posted on Jun 27, 2011
  • Joanne Rea
    Joanne Rea Mar 22, 2015
    Totally unaceptable to have to sent this out to a repair shop at a high cost just to change a belt. Ill never buy a dyson again!
tvservice306
  • 458 Answers
SOURCE: hi wondered if you could tell me how to change the
replaced Clutch Assy only
Clutch Assy part no:900252-04
Posted on Mar 01, 2010
Dysonteam
  • 167 Answers
SOURCE: how do you change the belt on a dyson DC 27
Hi its Darran at Dyson.
The belt on this machine is part of the clutch mechanism and as such we only recommend that a suitably qualified engineer carries out any repairs to this.
If you would like to talk through the options with one of our advisors, please contact our Helpline on 1866MYDYSON.
Kind regards
Darran
Posted on Apr 19, 2010
Samyfam
  • 379 Answers
SOURCE: How do you change the belt on a dyson DC 07
DC07s have two belts - one connects the output of the motor to the clutch, the other connects the clutch to the brush bar.
I suspect the belt you are to refering to is the one from the clutch to the brush bar. Unfortuenately the other belt is hidden under a plastic cover, so you cant see if it is okay or not without some dismantling. This cover is not easy to remove and requires a Torx driver to under the securing screws.
If, after removing the cover, the other belt is okay, then you have a faulty clutch. New clutches are available on eBay reasonably cheaply, but again good tools and DIY skills are required.
Have a look at www.dysonmedic.com which has some excellent info on dismantling and repairing your machine, but unless you have access to such tools, and feel confident to tackle it, it's probably time to call Dyson or a Vacuum repairer.
Posted on Mar 06, 2010
SOURCE: Where are the 2 filters
The first filter is located just above the canister and below where the brush and flat tool are stored. The second filter (Hepa) is located under the canister.
Posted on Jan 03, 2011
blueextc3221
  • 15935 Answers
SOURCE: belt
http://video.aol.com/video-detail/dyson-not-picking-up-dirt-no-suction-how-to-repair/2334249387
Posted on Jan 06, 2009
Why is it such hard work to hoover the carpet with the dyson dc 33.it is really hard just pushing it across a new carpet.
Are your belts working and is your power head set too low? Try raising it up one or two clicks. A broken belt will not let your brushes spin and a spinning brush will help it go on carpets.
Aug 20, 2016 | Dyson Vacuums
How do I fix the carpet brush on my dyson dc14 vacuum?
this is what is is broken it is the clutch Dyson clutch belt assembly for DC07 amp DC14 900252 04 473
most likley needs to be changed it is also a good idea to change the roller brush at this point also
Dyson Dc 07 14 33 Upright Models oem 904174 01
Jun 12, 2016 | Dyson DC14 Animal Bagless Upright Cyclonic...
What do I need to adjust to let it work on carpet?
The belts in the clutch are probably stretched out and have lost elasticity. Replace the belts or the clutch.
Mar 21, 2016 | Dyson DC-33 MultiFloor Upright Vacuum...
How to clean dyson dc 33 filters
Hi there, it's Jack at Dyson.
DC33 has two washable filters, engineered to last the lifetime of the machine in normal use. These should be washed at least once every 3 months using cold water without detergent. Allow at least 24 hours for both filters to dry completely before replacing them.
Our online Support guide will walk you through each step: http://www.dyson.co.uk/support/dc33/dc33-multi-floor/dc33-maintaining-your-dyson-machine/wash-the-filters/filter-removal-step-1
I hope this helps, but if you'd like any further advice from our experts you're welcome to give us a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Sep 01, 2014 | Dyson DC-33 MultiFloor Upright Vacuum...
How to make my beater bar on the dyson 33 turn?
Hair is probably still wrapped around one end of the axle. It's HARD to get all the hair out of there.
You did get the drive belt back on, true?
Aug 10, 2014 | Dyson DC-33 MultiFloor Upright Vacuum...
My dyson dc33 beater bar won't turn
There are belts in the clutch, which is the lever you can move to adjust the vacuum from floor to tools. The belts become stretched and need to be replaced. You can purchase just the belts or purchase the clutch assembly with the belts installed. There is also a belt change tool that makes the job much easier to install because the new belts will be much tighter than the old belts. The parts are available from thatvacguy.com.
Jul 10, 2014 | Dyson DC-33 MultiFloor Upright Vacuum...
How to change belt on dyson dc 01
this link is the manual it will give you full instructions on belt change..
http://media.dyson.com/downloads/UK/floorcare/Manuals/dc01_std_manual_uk.pdf
Dec 16, 2012 | Dyson Vacuums
I have a Dyson DC33 bagless vacuum and the beater brush is not turning .. How do I get the cover off the brush to change the belt?
If you lay it down so you can see the bottom of the vacuum, there should be 3 flathead looking screws,just turn them a quarter turn or so, and that bottom should pop off so you can take the brush out and change the belt, just make sure you watch how that brush comes out so you can get it back in correctly. Oh make sure its unplugged!!
Sep 13, 2012 | Dyson DC-33 MultiFloor Upright Vacuum...
Dyson DC33 Bagged Upright Vacuum Logo
15,804 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
