Question about Car Audio & Video
I have the stock radio installed inside my van. When i turn the radio on it plays music for 10 seconds then it cuts off. Also only the back speakers play music. I purchased a cd player from Best Buy. When i had it installed absolutely no music played from the speakers. What can i do to resolve this problem?
  • 114 Answers
Could be a faulty capacitor. Also check the power for the unit.
Posted on Mar 17, 2011
I have a jvc kd-r440 radio installed in a 2001 stratus rt. It will play fine for a bout 10 mins or so then loses sound. If you push buttons you can hear beeps through the speakers. But no music. Tried to...
You need a new radio. Amp in the radio is bad. When you first cut on the car its cool. After 10 minutes it gets too hot to operate so it cuts off.
Oct 21, 2014 | Car Audio & Video
Chrysler Concorde 99' radio fuse constantly blowing
Everything isn't stock. The amplifier isn't stock. Is the radio stock? If so what are you using for remote "on" to the amp? Start there.
Jul 13, 2013 | Chrysler Concorde Cars & Trucks
Installed new radio in 95 oldsmobile cutlass ciera and speakers dont work
you may need new speakers or there are wires not hooked up right
Oct 29, 2017 | 1995 Oldsmobile Cutlass Ciera
When I turn the radio on its plays fine for about five seconds, then it's stops playing and it says call on the screen. Then if I hit the power button again it goes back to playing music and it never
Is your Bluetooth devices connecting to it automatically when you turn it on? That is most likely the reason, your getting into the car, turning the radio on, playing music and then your phone is connecting to it automatically through Bluetooth, causing it to cut out the radio and display "Call".
Dec 24, 2012 | Cars & Trucks
I hooked up a Sony deck and new Kenwood 12' subwoofers and amp that came together in a box set in my 95 Jeep Grand Cherokee and when I play the radio the stock car speakers play but the subwoofers are...
their should be a blue and blue white wire on the Sony radio. cut the blue wire and then connect the car side to the blue white wire and tape off the blue wire that is on the radio side.
the blue wire only turns on when the radio is activated. the blue white wire is activated when the radio is turned on.
please rate my solution.
Jul 02, 2011 | AudioBahn Car Audio & Video
Wiring Apine SPS-600C speakers
hey there,i hope the project turns out great,
1) round up all materials needed such as door components and indash radio,install plug for aftermarket radio,get a radio install kit they are like 10-15 bucks ,and if ur doing a double din radio you will have to cut trim to fit and inside compartment behind radio,but if your doin stock 1 din you will be fine.
2) in order to get to radio in dash you must pull dash bezel off from around gauges and radio and the radio has push down release tabs on both sides of radio ...push these down and pull radio outwards.
3) use new wire plug harness and install radio using install kit so radio sits in it and slides back in with tabs.
4) door panels come off with (3)crews that are 7mm near door handle,bottom of door near speaker,and inside where the switch panel is.must pull up switch panel to get to screw others are visible.
5) take mirror cap off and lift upwards on panel the whole panel will come off make sure to unplug vanity light at bottom door and all switches.remove n set to side door ....remove speaker and unplug then install new speaker cut plug install new crimped wire connector caps and install speaker and do reverse to put door back on and this go's for the otherside as well.
6) if theres more to your system write back with any ?'s ok ill try to help as much as possible.
couldn't find anything about the network?
May 17, 2010 | Alpine SPS-600C Car Component System
Bass speaker start up noise
Hello anne845,
It sounds like the installer wired the amp remote turn-on terminal to an "accessory" lead in your vehicle. Many stock radios do not have a dedicated amp turn-or lead and the alternative is to connect the amp to a switched power source (ignition or accessory). This means the amp turns on whenever you turn on the vehicle ignition, often resulting in a thumping from the subs. It is a perfectly satisfactory alternative, and will not damage either the amp or the sub. But it's irritating.
If the thumping is objectionable, have your installer wire a SPST (Single Pole, Single Throw) toggle switch inline with the turn-on wire. The switch should be mounted so it is accessible by the driver, and whenever you turn on the radio, turn on the toggle switch.
Hope this helps.
May 11, 2009 | Alpine SPX-17MB 300 Watts MIDBASS Speaker...
Dodge radio starts then shuts off
Hi Davis,
I had the same problem with Dodge Grand Caravan as well. I have a 2001 GCV and these radios go out all the time, plus each speaker has separate amps which some speaker will stop working. You will need a new stereo, however the dealership will charge you over $350 for the same replacement. I chose to go to BestBuy and buy a new Stereo for around $100 which has iPod connections which is a plus.
Next problem!!! Since each speaker has its own amp, in order to get the new stereo to work, I had to install a relay by tapping into the passenger side kicker panel master amp power supply to bypass the chip. Best Buy guy will know what to do. I suggest install the stereo yourself with a kit and go back to install an amp bypass relay switch. Hope that helps.
Stock Stereos **** and Dodge make is difficult to go aftermarket.....Good Luck
Apr 05, 2009 | 2001 Dodge Grand Caravan
Newly installed alpine resetting
Chevy stock speakers are 8 ohm. You should change out the stock speakers. Or at least dissconnect the back speakers and see if cd player still overloads and shuts off.
Feb 28, 2009 | Alpine CDE-9850Ri CD Player
Radio shuts off at volume of 16 or more
Maybe a protection component cutting in.
If you have speakers that are too powerful for the radio it may shut down to protect the amplifier from overdriving the speakers. That produces too much heat in the amp chips/transistors and they either have a overload cut out protection circuit or they burn out.
Even if the speakers are the stock fitted ones the wattage could be bigger than the amp in the radio can handle.
There's probably no way of knowing how powerful the speakers in the truck are but you could try the radio with another set.
Max 50 Watts for that radio. If you don't have the manual for it, it's available here:
http://www.kenwoodusa.com/Support/Car_Entertainment_Owners_Manuals/#_
Mar 07, 2008 | Kenwood KDC-319 CD Player
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
