Question about Fluke Networks Fluke 179 Electricians Digital Multimeter Kit, Voltage Tester
I have a flluke 179 that when I turn it on it read F179 whichis normal and then it reads nothing else.. battery and fuses are all good.. what could be the problem. It was used and working fine, then went to use it again and now nothing.. any answers.???
    Master:
  • 678 Answers
Probably need new board - send back to Fluke for repair
Posted on Oct 30, 2013
2 Suggested Answers
VtToolMan
  • 704 Answers
SOURCE: WHEN I TURN ON MY FLUKE 179 IT READS ERROR AND
Hi, that is the error message indicating a EEPROM error and unfortunatlely, you can't do anything except have the meter serviced by either Fluke directly, or by an authorized Fluke test equipment dealer.
Since Fluke doesn't provide the specs and coding for their products, you wouldn't be able to repair the meter properly, even if you could burn and program your own chipset.
Here's a copy of the manual for your meter, so you can contact Fluke for servicing and see the other info relating to it (for your future reference)
http://assets.fluke.com/manuals/175_____umeng0100.pdf
Sorry to be the bearer of bad news, but Fluke products are typically quality test instruments and there might be a possibility that you're still covered under their warranty, so checking with them is the best avenue for getting it back to working condition.
I hope you find this Very Helpful and best regards!
Posted on Nov 10, 2009
My honda wont start;sit for a few days,find out da battery was low recharge and alternator bad replaced too and start its good but still nothing
Jump start the car and measure with a voltmeter the voltage accross the battery. It should read 13.7 volts or greater with the engine running.if it doesn't it's the alternator or the voltage regulator. If it reads normal 13.7 or greater then measure the voltage accross the battery with the engine off. It should be 12 volts or slightly higher. If those readings are nominal then there is something that is drawing oower when the car is turned off, could be a light or some other short in the electrical system. If you have anything connected to AUX power make sure the voltage is zero volts with the engine off..
Jan 04, 2015 | 2003 Honda Civic
Battery keeps going dead. Have had 3 new altanators & 1 new battery. 5 mechanics has worked on it over the last 12 mos.has cost quit a bit of $. but still same thing. Seems to go down when setting over...
Try disconnecting the battery after you park the car in the evening. If there is a short, then the battery should still be good in the morning. if not, the battery is no good. Most common sources of shorts are the alternator ,or the starter. Good luck You take a voltmeter and take a reading across the battery posts. There should be no power on in the vehicle at all...everything turned off and key in the off position. A normal reading may between 12 and 14 volts. Record this reading in a notebook. Now..go pull a fuse in the fuse box. Just one..and go back and take another reading at the voltmeter. Was there any change? No? Pull another fuse. Now you have two fuses out. Take another reading. At some point...that reading will change. It will show an increased reading. You have just found which circuit is causing the drain. With the drain removed the available battery voltage will go up. just follow the affected curcuit, until you find the drain. if alternator curcuit is ok!! then you should have at least 14.2-14.7 volts at battery when running with everything off. good-day ! and good-luck!
Sep 11, 2011 | Mercury Marquis Cars & Trucks
My 1999 gsxr 600 turns over but won't start it was fine until changed front tire
changing front tire has nothing to do with your bike not starting! first start by turning the key to the on position, do the lights come on bright? turns sigs Etc, work normally, hit hi beam, does it work, if yes then i would guess your battery does have enough juice to turn it over. Since you said it was running fine before this i doubt its a fuel problem but check your fuel pump fuse just to insure! if fuse is good then its time to get out the meter pull off the seat and take a voltage reading across the battery terminals. if it reads only 12.1v or less, it needs a trickle charge for about 5 hours. Batteries only last about two to three years! if you charge it and it starts!! but sputters when you ride it, then change the battery its going bad!
Mar 20, 2011 | 1999 Suzuki GSX-R 600
Needles on dash guages (temp,fuel,speed) chatter or vibrate on their lower limit pins when the ignition switch is turned on or the engine is started. After about 30 seconds the needles move to their normal...
Disconnecting the leads from the solenoid,avtivating the switch, and reading 12V is normal because you are not reading anything but the signal applied to the solenoid.You need to attach the leads and THEN activate the switch and read the voltage across the terminals.12V would mean the solenoid is good because a voltage reading is a DIFFERENCE of electrical potential.If you have the leads attached and read 0V,there is no difference of electrical potential meaning there is actually 12V on both sides and the solenoid is not absorbing/using the power like it should be.If you simply read the 2 terminals on your battery it would read 12V,likely higher because a good battery will usually read close to 13V.A bad battery may read as high as 11.8V.As for the guages,it may also be that the battery is low if it has never been changed.The average life of an alkaline car battery is about 6 years.If yours was made and sold in 2000 like they like to do these days,the battery may have been changed once and is starting to be borderline.With the car off,no keys,nothing,read across your battery terminals and please let me know what you find. gmccarthy 86 hotmail
Greg
Feb 22, 2011 | 2001 Kia Optima
Sharp SPC 373 transmittting temp 179 for a month
Unfortunately I have the same Sharp atomic clock with the same bad remote temp transmitter and having the same 179 result displayed. Can't find a replacement anywhere.
Sep 28, 2009 | Kitchen Appliances - Others
94 lesabre wont start
thats a good reading. 12.2 is better then normal. does the car crank over or when you turn the key do u get nothing at all?
Jun 11, 2009 | 1994 Buick LeSabre
Caddy Deville wont start
Check the gear selector switch. You may need a Chilton's book to find it. Try starting in neutral.
May 04, 2009 | Dell Inspiron 2650 Notebook
Wiring isue
Put a meter on the battery and get a real-world reading. One at the battery by itself with nothing on, and one with the key on and trying to turn the starter motor. A good battery will read 12+ volts at rest and not drop more than a volt or 2 when trying to start. If that's good, you have a loose or corroded connection between the battery and starter motor. Clean and check all the connections until you find the problem.
Nov 20, 2008 | 2007 BMW K 1200 R
Fluke Networks Fluke 179 Electricians Digital Multimeter Kit, Voltage Tester Logo
287 people viewed this question
Top Fluke Networks Measuring Tools & Sensors Experts
Vuk B
joseph m fucci
joseph m fucci
Level 1 Expert
richie46
Are you a Fluke Networks Measuring Tool and Sensor Expert? Answer questions, earn points and help others
