Question about Canon PowerShot SD800 IS / IXUS 850 IS Digital Camera
Lens error, restart camera
The lens won't retract completely, and it doesn't zoom completely, it does take pictures
  • 4 more comments
  • Anonymous Aug 16, 2008
    we have had the camera for three weeks, and yesterday when we tried to turn it on it displayed the error message: "lens error, restart camera" and will then turn itself off.
    Help! is this a common problem with this camera?
  • Anonymous Sep 02, 2008
    restart camera. error obj
  • canon850is Sep 21, 2008
    got sand in it. opened it and removed sand but still the problem exists. any idea how to clear sand from the lens, the doesn't come out..
  • sjbsf Nov 25, 2008
    Lens does not fully retract and powering on/off does not help. Lens goes out when turned on but image remains fuzzy even in autofocus.
  • vamcsorley Dec 07, 2008
    I have the same problem. I was using the camera outside in 25 degree (F) temperature. I only took about 4 pictures then went to turn-off and the lens would not go all the way in. Tried re-powering and still have the same problem. Does anyone know how to fix this?
  • antuany Dec 10, 2008
    I have the same problem...I was recently on vacation in Las Vegas, & one of the beginning nights I took a picture in a night club & the camera wouldn't close when I turned it off. It really put a damper on my trip not having my camera. Does anyone know how much it would cost to repair - is it really the $260 listed in Solution #1. I'm not sure I'd be able to get it apart & back together doing it myself if it's as complicated as it sounds with the link for the IXUS in Solution #1.
Http://www.ixus-world.de/index.htm?tips/repair_guide/e18_01en.htm
Posted on Nov 02, 2008
My canon powershot sd800IS Has lens error, restart camera it takes pics but the lens doesn't zoom right or retract completely
the mechanism is jammed or broken, the camera needs to be disassembled the lens needs to be inspected and disassembled and then assembled back together the right way.
I highly recommend sending it to a professional service, as these are tricky devices and easyly break.
I can recommend www.advancecamera.com/repair get a free estimate from there.
let me know if you need anything else.
Thanks,
Ekse
Aug 02, 2008 | Cameras
Lens doesn't work
Try removing the battery and memory card for at least 15 minutes. With some cameras, this will reset the camera and lens may clear the error message, as long as there is something that is not physically damaged the camera.
Jan 20, 2013 | Kodak Easyshare C195 14 Mega Pixels...
Zoom lens won't retract on fujifilm f410
This indicate that there will be some problem with your camera Lens. Try to follow these steps to resolve the issue:-
1) Switch the camera OFF and then ON again. (May be your camera lens is struggling to extend)
2) Load new or fully charged batteries.
Else your device need service (repair)
Rating the solution is highly appreciated....Good Luck
Mar 03, 2010 | Fuji FinePix F410 Digital Camera
Hi, my zoom is stuck out and won't retract.
Your lens motor is most likely burnt out. The only way to continue taking pictures is push the lens in manually, You may have problems with the focus after doing this, so just turn the lens manually until you are zoomed in properly. If you have a warranty now is the time to use it.
Jun 26, 2009 | Fuji FinePix A600 Digital Camera
PowerShot SD630 lens stuck out, says lens error, restart camera
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 20, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
I've had similar problems with various versions of this camera. Here's the fix, if all else fails. These are step-by-step instructions to take apart and fix the camera's lens error. http://johnsmouth.wordpress.com/2010/12/01/lens-error/
Mar 24, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Olympus zoom camera ED lens #sp51ouz
it seems that the moter or track is either damaged or out of line this will need to be fixed by an engineer sorry
Jul 28, 2008 | Cameras
Zoom will not retract
Dear Grammie,
You have either experienced a lens error or your zoom dial is broken (both usually caused by some sort of impact damage, but which can be spontaneously occuring).
Look for an error message on your camera's LCD screen such as "E18," or "lens error restart camera." If you do not see a lens error but simply cannot retract your zom lens (go into wide angle mode) via the zoom lever then it simply maybe a broken command dial. Either way, however, you will need to have the camera serviced in all likelihood. Call tech support at 1-800-828-4040 M-F from 8 am to 12 midnight EST and Saturdays until 8 pm EST. Hope this helps.
Sincerely,
HeavyDLB
May 22, 2008 | Canon PowerShot A540 Digital Camera
Lens is stuck out
It sound like a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Aug 26, 2007 | Canon PowerShot A430 Digital Camera
Canon PowerShot  SD800 IS / IXUS 850 IS Digital Camera Logo
352 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
