Question about Samsung Televison & Video
Tv doesn't turn on right away and takes several minutes to come on screen. . .
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • Samsung Expert
  • 177 Answers
I have esperiences with samsung flat TV's. That problem mostly from capasitor on SMPS board.
open rear cover, than check on PCB power board (SMPS). There are capasitors which almost exploded. Changes with same type but increase the voltage. ( 1000uF/16V change to 1000uF/25V).
Good luck.
Posted on Mar 17, 2011
RCA flat screen TV turns off by itself and won't turn back on
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 13, 2014 | RCA L22HD41 22 LCD TV
Blurry at first then when it warms up the distortion goes away
Most of the Toshiba sets of this age had problems with a board inside that gives lines/noise left to right for several minutes and then clears up--as time goes on the warmup takes longer and longer---bad Hyper board with about 10 tiny surface mounted filter caps that dry out.
Part is not available and two options--either have a shop repair it or try it yourself---takes above average skill to remove board and replace all ten caps.
Shops will if they will attempt this usually get over 200 for the repair.
Oct 25, 2012 | Toshiba 50HX81 50" Rear Projection...
Insigna 37 in screen comes on then off right away
which mean had an error detected by the main board which turn to safety mode. if you will be the one to do the repair make sure you have knowledge in electronic repair since as you know some parts with high voltage. now let first disconnect the connector that supply the inverter board for screen back light just to ensure if their is a shorted component in the board. then turn on the tv unit, if the tv unit doesn't turn off right away that was mean the cause is the inverter board.
Sep 04, 2012 | Insignia 26 in. LCD Flat-Panel HDTV
Sounds works, image doesn't come on for several minutes
Send your tv back for professional repairs as this is the first sign of failing LED's somewhere in your tv. I hope this helps
Aug 25, 2012 | LG Televison & Video
Red Vertical bars cover the right 1/4 of the screen. They starting appearing sporadically several weeks ago and would go away, now they stay on the screen, regardless of video input ..
Try resetting the TV to the factory settings. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue still persists, then the TV requires service.
Jul 25, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
My tv takes like ten minutes untill it's turning on,why?
Replace any swollen capacitors in power supply.
Apr 24, 2009 | Televison & Video
Unwanted rectangular black area appears on screen blocking 40% of picture
This could be the result of a partly shorted vertical winding on the deflection yoak.Since the line is on an angle and not straight across.
Nov 07, 2008 | Durabrand DWT1304 13" TV
I have Pioneer plasma screen using a media box. When I switch it on the red and green buttons flash alternately for several minutes before it comes on. Once on the tv works ok. It is only on starting that...
This may be due to the media box taking its good old time to set up when you turn your tv on.
Try without it and see if the problem goes away.
Mar 12, 2008 | Televison & Video
Screen problem
check captions on your menu settings it has caption 1 and 2 if it is not set on caption it could be on text which cause the black box to come on the screen turn off every thing on the caption menu.if that does not work then take you set to a tech to have it reset then it could be your eprom or your video circuit.good luck.
Aug 28, 2006 | Samsung TXK2754 27" TV
Televison & Video Logo
118 people viewed this question
Henry  Thomas
Henry Thomas
