Question about Nu Mark Numark Dm3050 3-Channel DJ Mixer System
When setting up a sound card to my m4 numark 3 channel mixer do i have the switch to phono or line
    Brigadier General:
  • 8,546 Answers
"PHONO" is ONLY for an old school turntable that would require a PHONO preamp, so that leaves, uh, LINE.
It's more than a matter of gain as Phono cartridges require special equalization to restore flatness to the sound recorded in a vinyl groove.
Posted on Mar 17, 2011
I am not getting sound thur my mixer what could be the problem.
Is there any hum sound? Are the switches set to the proper inputs-phono, line?
Feb 14, 2015 | Numark Im1 2-channel Pro Dj Mixer With...
Connecting numark m3 to turntables
The m3 has two phono inputs in the back. There's a switch for either line- in or phone. Put the switch to phono.
Mar 20, 2013 | Numark M3 2-Channel Tabletop DJ Mixer
I have numark m4 .sound has decreased
You need to have more information, It could simply be a level setting.
Feb 19, 2013 | Numark M4 Dj Mixer
Not receiving STEREO output when toggle switch for mixer is in the STEREO position
Here are a couple of steps you can do first before opening up the mixer & I'll word this so that it covers every potential item, (Turntables, CDJ's, Rack Mount CD Players, External Player, PC, Laptop, etc.) Obviously there are a multitude of items that could be the cause of you only receiving your RIGHT MASTER OUT since you didnt specify what item this occurs with if not all. So here's a quick legend for you to follow my references regarding the NUMARK 5000FX Mixer so here we go:
MIC/Line Phono/CD Phono/CD Phono/CD LA/LB Zone/Booth/Rec/MSTR
LO LO LO LO LO LO LO LO LO LO LOLOLO LO
RO RO RO RO RO RO RO RO RO RO RORORORO
1. Turntables - A) If being used make sure the little black switch on the back is set to Phono instead of CD. Plug just one table in, play the record & see if there's only one side of your MASTER output jumping and make note of it. Then repeat the exact same steps for all Phono inputs (total 3) & again make note of your MASTER output signal Left or Right or Both sides jumping. This will help you identify if its just a specific channell that only works on R or L.
B) Now do the exact steps above for the other turntable & this will confirm whether or not the Phono cables went bad on the turntable or if a specific channell is has gone bad while in Phono mode.
2. CDJ's/Rack Mount CD Player - A) Now just use your CDJ's/Rack Mount CD PLayer for the next test & be sure to now change the little black switch on the back from Phono to CD. Just as the steps with the turntable perform the same for this item in all possible RCA's (total 6) & note your MASTER channell output signals L & R.
B) Now do the same for the other CDJ/Rack Mount CD Player & this will confirm whether or not the RCA cables went bad on the CDJ's/Rack Mount Player or if a specific channell has gone bad while in CD mode.
3. Audio Cables OUT - A) There are a host of ways to have your audio come OUT & multiple configurations depending on how you record &/or bounce your audio OUT. Now since you say your MASTER OUT digital meter is only jumping on the R side depending on if you're going with RCA MASTER OUT or XLR BALANCED MASTER OUT either or is what'll show the digital reader bouncing with audio so check both. It could very well have been a cable going bad on you simple as that & you can check that by pluging your cable that works on the R side into the L side. If it starts showing a reading on the digital meter than you've solved the problem being a bad cable. Also don't forget to check your ZONE, BOOTH & RECORD OUTS as well however these will not show on your digital meter so open up your audio recording software to confirm that L & R sides are working for these.
B) Last but not least double check that your BALANCE knob is set directly at 12 o'clock, this could sometimes be the culpret.
Well I hope this helps & good luck.
WesTCo@sT
Sep 21, 2012 | Numark Industries Numark 5000FX 5 Channel...
Im new with the use of the record player since im tired of MP3's. i bought a Numark TTusb turntable connected everything, but the sound is low. i have to crank the volume to the max, and only get low...
A turntable use a magnetic cartridge and its output is only 5 to 10 millivolts.A moving coil cartridge is even lower,.2 to .5 millivolts(thats 1/2000 of a volt)in contrast, a mp3 puts out a 300 to 900 mv signal..so does a CD player. Your turntable does not have enough signal.You need to get an amplifier that has a phono input. Years ago,radio shack used to sell phono preamps that could plug into a tape or cd input.The other option is to buy a used mixer that has a phono input.The mixer output can drive the cd input easily,as the max output from a mixer is 1.5 volts to 2 volts.
Dec 30, 2010 | Numark ttUSB Turntable
My Technic 1200's are only playing out of one speaker at a time.
Clearly there IS a setup issue. Take serrato out of the loop for the moment and the mixer. Plug each deck (one at a time) into a hifi with a MM Phono input. Are you getting stereo? If yes, you know the decks are ok. Now reset the mixer completey. All eqs and pans including volumes to 12 o clock position and volumes to 0.
Make sure you connect deck one to a red and white of one phono input channel. Do not use 1 channel from phono and 1 from line. Use both left and right of the phono chanels.
Ok, now hook up the mixer to the amp. Keep the x-fader on channel 1 and concentrate getting a good stereo signal from this one chanel. Now do the same for the other cahnnel.
This should hae helped you to get up an running, if not narrow down the problem.
Apr 18, 2010 | Technics SL-1200 Turntable
Cannot hear the songs playin in deck 2 when one is playing.. What should i do?
is there signal lights comeing up on mixer or have u got sound in headphones.have you tryed changing needles,is the phono/line switch set right,also try changing over deck sides an let me know. sound
Aug 04, 2009 | Numark ttUSB Turntable
Cant connect my Numark PT-01 to my Numark DM950 mixer
What do you mean it didn't work? What happened? Are you getting no sound, did the plugs not fit? Please be more specific.
If you are not getting any sound, make sure you connected to the LINE input of the mixer - the PT01 has Line Level outputs, so you CANNOT connect it to the Phono input, as the signal will be too hot for the mixer - so make sure it is in the LINE INPUT. Also make sure the toggle switch on the mixer is set to LINE. There is nothing else to this set up, raise volumes, and that's it. It's very simple.
- OPTiC
DIY Yourself DJ Repair Videos
DJ Equipment Sales
Jan 08, 2009 | Audio Players & Recorders
Stanton S -650
Make sure that the "line/phono" switch on the back of the unit is set to "line", or your output signal will sound distorted.
May 22, 2008 | Nu Mark Numark Cd-Mix-2 Dual CD...
Nu Mark Numark Dm3050 3-Channel DJ Mixer System Logo
118 people viewed this question
Top Nu Mark Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
da surgen
Are you a Nu Mark Audio Player and Recorder Expert? Answer questions, earn points and help others
