Question about Canon imageRUNNER 3035 Black and White Copier
I need to know how to print out a hard copy of the meter read on a Canon Imagerunner 3035 copier??
  • Canon Expert
  • 287 Answers
Hello mhitt,
Even though you have a pretty new copier, the ability to print the meter reading is not available. I know it's crazy since other copiers have been able to do it for years. Only the most recent models of Canon copiers have this ability. To print the meter readings for your copier would require that you go into SERVICE MODE and print a report that has several pages of **** and if you know what you are looking for you can find it.You could use the REMOTE USER INTERFACE (RUI) and view the meter and do a "screen print". I know it's not a happy answer but its correct. I wish you well. :-) By the way, the main meter reading (designated 101) is the count of sheets of paper that have successfully exited the copier regardless of size. My company uses meter "102" which counts 11x17 as 2 clicks on the meter. You probably cannot see this meter unless a service tech programmed it in.
Posted on Mar 17, 2011
MY canon iR3035 ccd scanner position is faulty..
Re: canon ir 3035 copy not lined up 1/4 inch higher it scans but configuration page i
service mode > copier > adjust > adjust xy > adjust Y input the value from the label on the front cover
This is all I could find. Try adjusting by 1/4 inch. Thank you Santosh
Jun 25, 2016 | Canon imageRUNNER 3035 Black and White...
I have the canon imagerunner 3035- how do i find the serial and model number?
simply print out a report . or press the counter button and u can see it on the bottom of the screen
Sep 07, 2011 | Canon imageRUNNER 3035 Black and White...
Dhow to print off meter readings on a canon 3380
goto service mode additional function * additional function then goto MISC_P
here u can print the meter
Jun 30, 2011 | Canon imageRUNNER 3035 Black and White...
Is there a manual meter to get the copy count on a Canon IR6570 ? I cannot seem to locate it.
there is no manual meter. if wanna have the print out of meter then u have to enter the service mode and the press MISC_P to print the meter
service mode
Jun 29, 2011 | Canon USA - COPIERS - IMAGERUNNER 5570...
Where is meter reading on canon imageRunner C5180i color copier?
Hi sophie,
Look to the far right of the operator contol panel, past the 9 key pad and you will see a "little button" called COUNTER check. Press it and it will tell you your meter reading.This screen can be configured "by a service tech" to allow you to view the count of up tp 6 different meter counts depending on the function you wish to monitor. The basic meter reading is named "101". That because there are hundreds of funtions that are always monitored and they name them 101,102,103 etc. 101 counts the number of sheets of paper that have exited the copier. "102" does the same except it counts 11x17 [ledger] as 2 copies as 11x17 is really 2 letter size sheets. So my company uses this meter for billing purposes so we ADD the 102 meter to the list of viewable meters. Again this can be configured to the customers needs or the service provider needs. You can set it to view just black and white, just color, or even how many copies were made at 64%. its wild. But the 101 meter is the default and cannot be removed or altered. I sure how I helped you. Please let "FIXYA" know.The pat me on the head when I do good. :-) Take care . SPINAL
Jan 28, 2011 | Canon imageRUNNER C5180i Color Copier
Canon Imagerunner 3035. refilled staples, but copier thinks empty
frst: did you set the staples according to the instructions?
second: try the few times remove and insert staple cartridge in and out, until you heare the loading clicks.
third: check the staple holder for damadges or residuals of staples.
Jul 31, 2010 | Canon imageRUNNER 3035 Black and White...
Canon IR3035 Print orientation
you set the setting the way you want them, the go to additional functions/common settings/store and that should help
Apr 08, 2009 | Canon imageRUNNER 3035 Black and White...
COUNTER CHECK "CANON IMAGERUNNER 2200" BLACK AND WHITE
On the left side of the on/off switch is there a small button mark with 123 press that button and the meter reading will display.
101 TOTAL ***** -that will be the total of copies,printing,and fax receiving on A4
103 TOTAL LARGE ******-this is the total of the A3 copies,printing and fax receiving made
201 COPY(TOTAL) -this is the total A4 copies
203 COPY(TOTAL LARGE)-this is the total for A3 copies.
Apr 02, 2009 | Canon imageRUNNER 2200
Canon 3035 missing drawer options
On your computer go to the start menu,select control panel,printers and faxes,right click on the ir 3035 driver,select properties from there go to device settings.In the paper source options inable the casette unit.
Then you will be able to print from the extra cassette unit.
Mar 13, 2009 | Canon imageRUNNER 3035 Black and White...
Canon imageRUNNER 3035 Black and White Copier Logo
460 people viewed this question
old marine
old marine
