Question about Intel D102GGC2 Motherboard
Can't power on? what part of system unit is busted?
  • Intel Master
  • 27,725 Answers
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this will help
Posted on Mar 17, 2011
Why wont my roku streamer turn on?
Sorry, sometimes the roku freezes. Have you put in the extra memory micro card. And the reset to original system defaults. Good luck.
May 30, 2014 | Roku 2 XS
Computer won't power on
One of 2 things come to mind. Either the power supply if fried or your button is busted. You can check the buttom by opening you units case and removing the front panel. Be careful removing as to not bust the tabs that hold it in place.
Now the start button could be busted either of 2 parts, the front panel or the actual button wired to the unit. Check to see that the nub from the panel is busted or not. If not then your problem may very well be the button wired to the unit.
I don't know the innards to your unit but the button may just sit in place with plastic nubs or screwed in.Make sure you have a back up Button ready before removing as to remember where it wires to exactly.
Most experts will tell the average user not to turn on a unit without placing all panels back in place but that's hog wash if you ask me. Do make sure all wires are snug though. I don't replace the cover until I know it works. (unless it is the panel button. Don't attempt to unplug or plug-in any wires while the unit is on.
I have shorted units by doing doing so but then I was distracted and didn't realize at the moment. Anyway if switching the button for a new one does not work, your power supply is then most likely no good. Unplug make sure to get same exact size with same hook ups sometimes best go with the same model brand etc. Remember the wire placing.
Removing the power supply can sometimes be a little tricky. To start there should be 4 screw on the outside back. Inside may or may not have any screws. Power supplies can run some money cheapest I have seen Is about $60 or so new. A start button should only be a few $. May check with repair shops to see if they have a usable used one.
Apr 11, 2014 | Dell Inspiron 531s Desktop Computer
Power button blinking on and off. Not powering up. Acer x223w lcd monitor.
it means your monitor doesn't receive any signal from the system unit, have you check its connection? or RAM, or your video card? try to clean your RAM with a pencil eraser like wise with your Vcard, maybe one of them is busted. Now replace it
Mar 04, 2010 | Acer 22" X223w LCD Monitor
Home air conditioner made a loud noise outside and now it looks like the refrigerant is spraying out of a ruptured line. what can I do?
Let it fish then chk what the failure is. They can be repair but something caused it.Fan failure could have caused high head pressure but it would have had to be extreme or a weak spot in the coils
Oct 15, 2009 | Heating & Cooling
Hp pavilion 1230n will not turn on
try to check the wall power outlet if have power output, if have ,try to check the avr if the led lights up if not try to check the fuse of avr maybe its busted, if not, try to check the power cable that used to plug to system unit if have power output use multitester and if have, replace your system power supply.
Oct 11, 2009 | HP Pavilion a1230n (EG134AA) PC Desktop
Orange flashing lights
May be the power supply gor affected by the damage because the cd rom busted so better than trying to use the same power supply better get another new one because it may damage the other parts of the computer.......
Mar 18, 2008 | Gateway Emachine Bestec ATX-250-12E PS...
Xbox 360
hi there
i would suggest that you bring your unit to a electronics store. just tell them that you suspect that your capacitor is busted and you may somehow need a replacement.
since you said that the powercords alright...i would think that its the capacitor thats busted.
thanks again and hope this solves your problem.
Feb 10, 2008 | Microsoft Xbox 360 Console
Intel D102GGC2 Motherboard Logo
18 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
