Question about Dell Latitude 120L Notebook
My wireless is not openning? - Dell Latitude 120L Notebook
  • 187 Answers
Is you're wireless radio on?it is a small switch that you can toggle on and off.it should be on the right side then try to connect to your network manually..
Posted on Mar 17, 2011
How do i reset it my wireless adapter
If I were you, I'd first let Windows Manage Wireless Network Connections:
  1. Click Start If you're using XP, click Start then open the Control Panel. Find the Switch to Classic View button in the Control Panel and click it.
  2. Open Network Connections Open Network Connections then double-click the Wireless Network Connection icon.
  3. Click the Properties Click the Properties button. Look for the boxes at the bottom of the Properties window that read "Show icon in notification area when connected" and "Notify me when this connection has limited or no connectivity" and make sure they are both checked.
  4. You could also right click on the Wireless Network Connection icon and click Properties from there.
  5. Open Wireless Networks tab Open the Wireless Networks tab and make sure the box labeled "Use Windows to configure my wireless network settings" is checked. Then click OK.
  6. under Control Panel\Network and Internet\Network and Sharing Center you could find "manage wireless connection" there you could assign/delete wireless connection.
Oct 26, 2014 | Lenovo ThinkCentre M72E 4004-B8U Tiny Form...
Changing my password
Which password you trying to change?
Are you trying to change wireless network password?
You will need to open the setup page of the router and check the wireless settings.
You will find the wireless network password. Change it.
Use wired computer to open the setup page of the router.
Do not use wireless computer to change wireless settings on the router.
See how to open setup page of the router.
May 20, 2012 | D-Link AirPlusG DI-524UP Wireless Router
Can't get wireless to work on laptop
You may use the System restore utility on windows by going to all programs then Accessories... Open system Tools and then System Restore. You may resotre your system to an earlier time, time when you are still able to connect to your router wirelessly.
^_^
Jul 16, 2010 | Dell Inspiron E1505 Notebook
Cant acess the set up wizard
First you will need to check the wireless settings of the router. If you don't know the wireless settings of the router then you will need to open the set up page of the router and get the wireless settings. You will need wireless network name ( SSID ) , wireless channel, type of the wireless security and wireless network key or passphrase.
Click Here to know how to check the wireless settings of the router.
If you know the wireless settings of the router then you will need to open the set up page of the WET54G and put the same wireless settings on the wireless briidge.
To access the set up of WET54G Click Here
Feb 18, 2010 | Linksys : WET54G Wireless-G Ethernet...
Lost wireless connection and yet it works with other computers... do I have an on/off switch on a Gateway 600y?
To turn the wireless emitter on or off in Windows XP:
1 Click Start, then click Control Panel. The Control Panel window opens. If your
Control Panel is in Category View, click Network and Internet Connections.
The Network and Internet Connections window opens.
2 Click/Double-click Network Connections. The Network Connections window
opens.
3 Right-click Wireless Network Connection, then click Enable to turn on the
wireless emitter or click Disable to turn off the wireless emitter.
Aug 17, 2009 | Gateway Computers & Internet
Garage door opening by itself
Most likely you are receiving an outside wireless signal that is activating your garage door. A neighbor nearby could have an opener that matches your wireless frequency. I live near a military base where years ago the base installed some wireless equipment that caused my door to automatically open. My suggestion would be to change the frequency code. Open up your wireless remote button. On most openers there will be a number of small rocker switches which are marked ON & OFF. Using a pen set these switches to a different configuration and then do the same at the wireless receiver which is located next to the overhead garage door motor. Be sure the opener and receiver's switches are set to the same configuration. This should take care of your problem.
Aug 07, 2009 | Universal Garage Wireless Keyless Entry...
Unable to activate wireless lan
TRY GOING TO START, START SEARCH TYPE WIRELSS DEVICE
LOOKE IN DEVICE MANAGE FOR WIRELESS FOLDER
INPUT DEVICES
AS SO CHECK THE FOLLOWING FOLDERS ALLOWING COMMUNICATION BETWEEN THE LABTOP AND THE WIRELESS DEVICE AND THE COMPUTER.
NETWORKING AND SHARING FOLDER
PROBLEMS AND REPORTING
SECURITY FOLDER
SYNC CENTER IF YOU HAVE ONE
WINDOWS DEFENDER
WINDOWS FIREWALL
THE LAST 2 PROGRAMS IN THE LIST ABOVE CAN STOP THE DEVICE FROM WORKING.
YOU WANT MORE HELP I WILL HELP YOU IF YOU HAVE THE SITE CONTACT RODGANDYSR@GMAIL
ROD
May 12, 2009 | IBM TP R51 - P M715 1.5GHZ 256MB 40GB...
Wireless router
Hi
router administration tool can be open through browser (Internet Explorer). you need to make sure that laptop is connected with router by direct cable or through wireless connection
Step 1 Open your web browser and type the IP address of the wireless router in the address bar (default is 192.168.0.1). Press Enter.
Step 2 The default username is admin and the password is blank (nothing). Click OK.
this will open the router administration tool.
Please vote if this solution is helpful.
Dec 31, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Removing security from a wireless network
  1. Open a web browser (such as Internet Explorer or Netscape)
  2. When the browser opens, go to the "Address" bar and input the IP address of the Wireless Router (The default IP Address is 192.168.1.1).
  3. A "User Name" and "Password" prompt will appear, leave the "User Name" field blank and input the Wireless Routers password (The default password of a Linksys Router is admin) into the "Password" field.
  4. After the "Setup" Page loads, click on the Wireless tab.
  5. From the "Wireless" area, click on the Wireless Security sub-tab.
  6. When the "Wireless Security" area opens, select the Disable option for "Wireless Security" option
Apr 17, 2008 | Linksys Wireless-G WRT54G Router
Dell Latitude 120L Notebook Logo
mukhtar21 shaikh
mukhtar21 shaikh
