Print jobs from my computer print an extra blank page between all copoes, but it onle happens when I print, not when others print
    Master:
  • 325 Answers
Check that your page settings in printer properties AND!!! printing preferences are correct...ie its not set to letter instead of A4.
Posted on Mar 17, 2011
  • 114 Answers
Check your Printing Preferences.
What causes intermittent skipping of labels? In the middle of a print job the printer will spew a blank label then continue on with the print job, I'm hoping someone can help me with this issue.
Check your mailing list. Especially check how many invisible spaces are after a name or address. Suspect extra characters are pushing the mailing list into the next page or label and then it will print an extra blank page or label. Seen this happen when I was a Computer System Administrator and had to fix a similar fault for a client.
There is a reveal code option on most word processors that shows up hidden spaces.
May 27, 2015 | Office Equipment & Supplies
My cannon D680 prints a blank page after every print or copy job. the pages print fine but at the end it always feeds 1 blank page. what can it be?
See if there is an option in your settings to print a "job owner" page after each job. That's not what it's actually called but I had a similar issue with a Canon printer and found that you can have the printer automatically print a page after the job that identifies who sent the job to the printer. It's the last page so it lands on top of a finished job and separates it from other jobs sent to the printer before you have a chance to get yours. If you don't have network identifications associated with users it may just print a blank page as a separator.
Jan 14, 2015 | Canon imageCLASS D680 Laser Printer
I have just bought a Xerox Phaser 6500. Prior to this I had a phaser 6125. The problem im having happened with both printers which makes me think somewhere along the line my settings are wrong. If I...
You may have the "separator page" option turned on in your print driver. This option will insert a blank page after each print job to separate one print job from another. Simply uncheck the box by the separator page option and you should be back to normal !
Oct 21, 2013 | Xerox Phaser Office Equipment & Supplies
Prints blank page
Have you checked the print que
Printer problems can be a real hassle.
From time to time, due to document layout or settings on your computer, in your software of choice, or even on your printer, a blank page may get "printed" with the rest of your document.
Fortunately, this issue is a simple one to troubleshoot.
Click "Print Preview" when you are finished with your document and ready to print.
Observe your document.
If you see an extra, blank page, you have created a second page.
To delete the second page, close Print Preview, go back into the document and eliminate any blank lines in your documents that you may not need.
You may also find an inadvertent page break at the end of your document.
Place your cursor on its symbol and delete it.
Locate the symbol by clicking on the Show Formatting paragraph icon in the toolbar.
Circumvent this "ghost page" if you do not see a second (or additional) blank page in Print Preview.
Specify the number of pages you wish to print, within the Print dialogue box.
This is typically done by selecting the "Print From" option, then entering the page numbers desired.
If your document happens to be ten pages (without, of course, that final blank page), then enter in the "Print From" field the numbers "1-10".
This will print only pages 1 through 10, without an eleventh (blank) page.
Jul 11, 2013 | HP Deskjet 5940 Photo InkJet Printer
Canon iR C6800 prints leading and trailing blank pages
There is an option in the print driver to print a separation page (typically just a blank page unless you specify otherwise) so that each person's print jobs can be differentiated easily.
This option probably got enabled somehow on her PC. Have her go into the print driver's properties (right click on the Canon in the list of printers and select Properties) and look for the option that says separation page or separator page and deselect it. Then click Apply or OK, and it should be good.
Jul 06, 2010 | Canon imageRUNNER C6800 Copier
Printer sends out extra page everytime I print
either your paper size settings need to be adjusted in the software, or your setup has included a seperator page.
Jan 27, 2009 | Office Equipment & Supplies
Printer only works after test page is printed
possible causes:
1. printer driver conflict to other program. Try reinstallation.
2. virus or spyware. check and clean
3. remove all other printers in the list.
Sep 24, 2008 | HP DeskJet 670c InkJet Printer
Extra blank page on ricoch printer
There could be a couple reasons...
  1. "Separator page" or "cover page" options could be enabled. The easiest way to find this option is to print a menu map from your machine. These are managed from the configuration page on the printer display
  2. Your printing from a terminal application, no fix...the terminal apps often send a (page break/ carriage return) at the end of jobs to make sure the page is printed and not held in queue.
  3. Check your settings in Office and print setup window - Word, Excel, etc. all have a "Seperator Page" and "Cover Page" options as well.
Hope this helps.
Jul 16, 2008 | Ricoh Aficio CL3500N Laser Printer
Printer prints first page with strange nonsensical characters
I would move the printer to another computer. See if the problem follows. I have seen the issue a few times with issues in normal.dot but also in other office applications.
Problem I'm fighting with on my 1720 is its printing extra pages between pages. basically print a 5 page document and get an 8/9 page final with the extra blank pages. Think its a user error but could be machine related. going to try it on another PC and see what happens.
May 28, 2008 | Dell 1720dn Laser Printer
HP LaserJet 3550 spits out blank paper when job sent from computer but prints fine when printing directly from printer
Try connecting the printer via the USB port on either one of the computers. Then test if the machine prints fine then likely possibility is that the Network interface card is faulty remove the network card and install in a different slot and test. If the same thing happens then reinstall the drivers and test.
Hope this helps
Thanks J
Jan 27, 2008 | HP Color LaserJet 3500 Printer
Computers & Internet Logo
109 people viewed this question
David Payne
David Payne
