Question about Kenmore Dryers
I have an Elite Kenmore Dryer model no. 110 63954101 The problem is it stops in the middle of a cycle but the timer still keeps working as if it is still on. I cleaned the lint out from everywhere recommended. Also, when I open the door sometimes and rearrange the clothes when I shut the door and try to turn it back on the start button doesn't work. If I come back in awhile the dial shows it is complete and the drum eventually turns over again to let me know the clothes are done but in fact they are still wet. Please advise.
5 Suggested Answers
  • 8 Answers
SOURCE: Bosch Axxis WTL 5400 Electric Condensation Dryer...Lint Filter Light
have you checked the vent line it could be stopped up if the line is bent same affect as the lint filter being full
Posted on Dec 15, 2007
exspert
  • 55 Answers
SOURCE: Dryer stopping in middle of cycle but timer continues to run.
oK " It's your timer, it has to be replaced
it's not going threw all it cycles, will start but will not finish
not a big job, unscrew plate on back at the top you will see
timer , take it out and replace it
( can not stress enough that you have to unplug the electrical cord from the wall socket before working on a dryer or any appliance )
Posted on Jan 24, 2008
SOURCE: Kenmore Elite Oasis Dryer with Airflow problem
same problem removed back cover cleaned lint found pulley had unscrewed and belt was off.installed pulley rev threded and put belt back on.
Posted on Apr 07, 2008
  • 552 Answers
SOURCE: sears kenmore elite oasis dryer 110 67032600
Check the vent on the back. This is indicating a air flow issue. If the vent is clear ohm the heater out check it for continuity.
You can watch a video that explains how to complete this repair on your sears Kenmore Elite clothes dryer at the link below.
Sear Kenmore Dryer Video
Posted on Mar 11, 2011
How to replace a heating element on a Kenmore Elite Oasis ST dryer
Sounds like you need to replace the timer one the dryer not the element but to make sure I would do a little trouble shooting to rule out the element or heating coil turn on dryer cycle like normal for about 30 seconds then open the door to feel for heat if you do feel heat its your cycle/timer knob if you don't feel heat then it's the coil or element witch are the same also first always check your lint trap and ducts going outside the dryer make sure you have proper airflow through ducts vents. clogged vents ducts ect. Cause over heating of element coil causing a safety fuse to shut down heating coil/element but will not stop cycle also moisture censors detect moisture causing cycle to continue on hope this helps.
Sep 04, 2014 | Kenmore Elite Oasis 6808 Electric Dryer
How do I stop fluff cycles on kenmore elite dryer
There are two ways this can happen:
1. You set the timer to a cycle that activates this option
2. (If equipped) Turn the selector knob off on the control panel that you can activate this feature with. Every manufacturer calls it something different.
May 12, 2012 | Kenmore Elite Oasis 7808 Gas Dryer
Electric dryer stopped in the middle of a cycle of towels (or after they were dry...not sure, as renters reported problem). . There appears to be no current..panel does not light at all Have reset the...
My 4 yr. old Maytag electric dryer stopped in the middle of drying towels and wouldn't restart. I called one repairman who told me it was my motor and I called another repairman closer to where I live and he came out and replaced my fuse. My dryer works fine now.
Aug 17, 2011 | Kenmore 63942 Dryer
Our Whirlpool gas dryer, Model # LDI5701W1 stopped working in the middle of a cycle. Power supply is fine. With door closed, I can't hear the timer humming. Could it be a door switch, timer,?
it maybe but here is a website that shows how to test them, it may be a loose or broken wire, a reset button on the motor, or other things:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Oct 24, 2010 | Kenmore 72622 Gas Dryer
Kenmore Evenheat MOD# 110 62056100
okay, kenmore elite have had these problems so often, you need to replaced the touchpad, not the board, jjust the touchpad, it cost around $150.00.
Sep 10, 2009 | Kenmore Dryers
I have a Kenmore Elite Washer that does not complete the wash
The timer should be checked/replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 12, 2009 | Kenmore 22422 Top Load Washer
Washer machine problem.
Hello noemystotler
You said,
On the last spin cycle water, never stops keeps spraying. Triede different cycles same problem I even disconnected machine in same problem.
sounds like the timer is not progressing and is defective!
Aug 03, 2008 | Kenmore Elite HE4 Electric Dryer
Keeps stopping
I have a feeling you are buying a timer board.
Dec 11, 2007 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
64 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
