Question about Campbell Hausfeld 1800 PSI Electric Pressure Washer
I have a ch pw180500av which iused once a year ago its been in the cellar for a year anf now when i start the hose up it pours water out of the bottom help jim in pembroke ma
    Sergeant:
  • 259 Answers
It sounds like somehow the pump has a crack in it. This will do that if water was left in it and it froze. How cold does your cellar get
Posted on Mar 17, 2011
My 2001 ch malibu is over heating-i have brand new thermastast and water pump in it and it still overheats the fans do work
These are 2-speed fans. Do you know if they're working on both speeds? If so, you may have a clogged radiator or a head gasket problem
Aug 24, 2017 | Cars & Trucks
Why is my 2003 Jeep grand cherokee leaking coolant?
It is probably is the heater hose or the heater return hose.
Aug 11, 2014 | 2003 Jeep Grand Cherokee
Water pours out from washer
Most washer i know of have a small hose coming from the base of the tub abd going up to a water pressure switch up in the controls. As the water level rises the pressure inside the tube rises. When the water level gets just right the pressure inside the switch kills the water and starts the motor. So what goes wrong? Trash and sediment such as sand gets into the tubing. Removing the tube from the control and blowing it out in most cases fixes the probo. Note: If you do this you need to pump out any water in the machine before you start another wash cycle. So that the pressure will build once again in the tubing and shut off the washer at the correct fill.
Sep 04, 2013 | Washing Machines
1994 Lexus ES300 overheats after a few miles and water pours out of the radiator coolant reserve tank. Radiator rebuilt 6 months ago. New radiator hoses and other water hoses within last year. Please...
a cracked block or bad gasket can result in compression bleeding into your cooling jacket causing the symptom you describe. a good shop has a tester to determine if there is compression residue in your coolant. that would be a place to start.
Jul 06, 2011 | 1994 Lexus Es 300
My rodeo started shooting steam out i filled it with coolant and during my 1 mile trip home water was pouring out from underneath,i poped hood,cap was on but steam was coming from below engine,help
Hopefully there is a hole in one of the hoses (least expensive).
No matter what, you need to find the source of the leak. A flashlight will be useful.
When the engine is cool, pour water in the radiator. You shouldn't need to run the engine.
When it starts dripping, look for the leak on:
  • The radiator
  • Large hoses leading to and from the radiator
  • Heater hoses (smaller leading to firewall)
  • Water pump (on the engine)
Once you find it, the severity and type of problem will dictated whether to fix or replace the damaged part.
Mike
Mar 24, 2011 | 1996 Isuzu Rodeo
It just stop pouring water
Into the basket? if so you have a kinked hose or clogged water valve screen filter which need to be cleaned out once every three months if your on well water and once a year on city water. if that dosnt fix your problem could be a bad water valve you will need a qualified technician come look at it sorry for the troubles hope this helps.
Jan 07, 2011 | Whirlpool Washing Machines
Air pocket must be in the block and preventing thermostat from opening. how do i bleed that out
remove top hose from rad pour antifreze in hose towards block to prime water pump once pump primed it will throw air out so once rad hose full and coolant running from rad
re conect hose and start car with rad cap off once rad fluid starts to flow in rad fill it up with 50/50 premix and install cap
wait 45 secs or soo then remove cap carefully as not to make a mess now check fluid levels when still running add if required
also make sure if serp belt that is has water pump spinning in right direction
some cars like the cavalier will allow the pump to be spun in reverse burning the bearings out and cooking the water pump
Jan 17, 2010 | Hyundai Motor 2002 Elantra
I have a Tobi steamer, The steam is not coming out like it should how to I unclog the hose? I do know its the hose. Thank you
My wife has thrashed hers in her shop and it suddenly stopped steaming. It was about two years old. I managed to fix it. I dont think that the hose or the nozzel will be blocked because they are too wide a diameter. There will probably be a build up of silica or calicum inside. Unscrew the hose where it meets the machine. Remove the blue water tank. If you pour some water down the pipe from the end that you just unscrewed the hose , the water should well up in the depression where the tank sits through the little holes at the bottom. If it doesnt then the blockage is inside which is what I found. I used some decalcification liquid product ICL and poured it in from the hose end and let it soak for 10 minutes. Then I got a thin plastic tube to go in and scrape around as far as you can from the hose end. A thin bottle brush or pipe cleaner would be good. I then used a thin piece of wire to poke around the slits in the other end( depression) Then I emptied it out and continually flushed it through with water and give it a good shake holding your hand over the hose end connection hole. I found that when I emptied the water out , it contained all this silica and residue. I would have got about a teaspoon full in total. After several goes the blockage suddenly cleared itself and I found that suddenly the water was running through freely and welling up as described. I kept doing this until the gritty residue dissipated. You can hold the hose end under the tap and tilt the machine so that the water runs freely out through the depression well. I reassembled it and tried it out. Bingo just like new. Hope this helps. - Grant
Sep 30, 2009 | Irons
Kenmore top load portable washer, model 110.42722200
i had same prob. at my daughters house, similar model. first time a hose popped off the top(i removed the lid), later i noticed leaks because my son in law was using oxy clean and it foamed over. my advice is, put machine on its side and look for loose/popped off hoses, dont use too much soap or additives, which will trick the water level sensor or just pour over that little drum
Jul 16, 2009 | Kenmore 2.1 cu. ft. Portable Top Load...
Campbell Hausfeld 1800 PSI Electric Pressure Washer Logo
155 people viewed this question
Top Campbell Hausfeld Garden Experts
John Trevino
Tim Venetis
Are you a Campbell Hausfeld Garden Expert? Answer questions, earn points and help others
