Question about Nokia 3110 Cellular Phone
Why my cellphone is not charging - Nokia 3110 Cellular Phone
I have accidentally subcribed to caramba and it charges me R6.00per day on my Cellphone i want to cancel my cellphone number is 0722495276
There was a chance to win an iPad, so your subscription doesn't qualify as accidental. Anyway call you phone company and tell them to refuse the charges and reject the messages from Caramba, that are sent to your cellphone.
Dec 12, 2013 | Transparent Language Caramba Fun Mexican...
Tip
How to get the most out of your cellphone battery. It is always a hassle...
It is always a hassle when your cellphone battery is flat and you can't charge it right away. So get the most out of your battery. Before you put your phone on charge, switch it off first. that way it does not used any energy when it's on charge. Also you can charge it during the night when you are sleeping. Most cellphones have the ability to let the alarm go off even though the phone is switched off. So your phone is fully charged at the end of the night. And you can enjoy your day without any worries.
on Jul 15, 2010 | Cell Phones
Charging hiting
what model of cellphone you have... and what heated up is it the charger or the cellphone.. we have two problem either the cellphone or the charger.. but i will tell you to look for another charger where we can check your cellphone. A charger must stop charging when the battery reaches its peak of charge... if the charger doesn't stop charging even the battery is charged then it will cause over heating to the charger or to the cellphone...
Sep 22, 2013 | Cell Phones
My lg kp320 went off and can't turn it on again
is your battery old already? have you dropped your cellphone in anyway? is the battery full charged? first step: 1. replace the battery with a new one. 2.if you dropped you cellphone,look for a nearest cellphone repair shop and let it repair by the cellphone technician. 3.charge the battery full.
Jun 16, 2011 | Cell Phones
My fly sx210 phone is not charging......what to do to charge it?
You need to change the charging pin of your cellphone. you can do this by going to the nearest cellphone center and they will change it for you. Charging pin is just cheap.
I plug my charger in but it wont charge and when i hold middle button it says charger connected and charges but as soon as i let go it says cahrger is disconnected.
Welcome to Fixya. Possible reason that your charger might have been damaged, or there's a wire that connects from the charger to your cellphones might be loose. Also cahrger connector on your cellphones might also damaged. If you have a friend or relatives that have the same cellphone, I suggest that why dont you try to use their charger on your cellphone or vise versa (your charger to their cellphone). In that way you, you can identify which one is damaged.
Please let me know if you have any questions.
Thank you for using Fixya,
seancarlisle
Apr 30, 2011 | Cell Phones
When i connect my mobile for carging it show (not charging(stop)). But it show after few second and make a beep. with this mobile show different status of charge level.
Hi, I too have this cellphone, when this happened to me I just bought a new charger and that fix my problem. I would suggest you try first a known good charge for your cellphone and if still you have the same issue, try to visit a cellphone repair center or from nokia care center, because there is already a problem with the charget socket on your cellphone. Hope This Helps
Jun 11, 2010 | Nokia 1110 Cellular Phone
Problem charging my Nokia 7610 cellphone
1. try to check if your charger is working or not
2. if charger is good.then try to replace the charging socket of your phone.you have to open it,but if you dont know how to do it.you need to go to a technician to fix it for you rather than taking the risk.
Apr 11, 2010 | Nokia 7610
My z6m cellphone won't charge and won't power up. the
This just could be a battery problem.Take the battery out and refit if it is still the same(doing this might give a small charge to the battery but will soon be lost..Try a new battery
Oct 28, 2009 | Cell Phones
Cellphone not charge
try to put your cellphone on charging for a longer duration say 1 hr or so...if still it doesn't pick up then you may need to replace your battery.
Sep 20, 2009 | Cell Phones
Nokia 3110 Cellular Phone Logo
13 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
