Question about D-Link DES-1024D 24-Port Ethernet Switch (890552611669)
D-Link 24 port switch is getting on off automatically
  • 114 Answers
Remove the power cord for at least 30 seconds and then plug it in.
Posted on Mar 17, 2011
How to connect 2 unmanaged 24 port switch as one unit
You can connect them using a x-over cable to an unused port. the switch should detect the other switch and trunk it automatically. (don't connect more than 1 or you will get a switching loop and possibly a broadcast storm... which is bad)
Jun 04, 2012 | Nortel Networks BayStack 42024T Switch...
I am trying to add an additional PoE device, put it will not power up. How can I tell the switch to power up a specific port, or put the switch into automatic mode?
Are you within the power budget?
Power feeding of Ethernet is limited for fixed 10BASE-T/100BASE-TX ports. The solution can provide maximum output power per PoE port up to 15.4W on 12 ports or 7.5W on 24 ports simultaneously. The Switch provides independent overload and short-circuit protection for each port, LED indicators for power status per PoE port, and supports IEEE802.3af MIB for Power over Ethernet functionality.
For each attached 802.3af-compliant device, the Switch automatically senses the load and dynamically supplies the required power. The Switch delivers power to a device using the two data wire pairs in the twisted-pair cable. Each port can provide up to 15.4W of power at the standard -48 VDC voltage.
Source: http://www.cisco.com/en/US/products/ps9967/products_qanda_item09186a0080a36afb.shtml
Mar 19, 2011 | Cisco Systems 24-Port SF 300-24P 10/100...
Switch is getting on off automatically
change the power cable. and off the swtich for at least 15 minutes. make sure there is redudnt link .
Mar 17, 2011 | D-Link DES-1024D 24-Port Ethernet Switch...
HAVE 24 PORT CISCO CATALYST 2960 SERIES SI ,HOW TO PUT IT BACK TO FACTORY SETING SO I CAN USE ALL 24 PORTS WITHOUT MANAGE..???
Due to the length of the solution I have provided you with a link to the Cisco site on how to reset catalyst switches.
It is not a simple process and you need to read the instructions carefully.
http://www.cisco.com/en/US/products/hw/switches/ps607/products_tech_note09186a00800c4546.shtml
Dec 15, 2010 | Compaq Cisco Catalyst 296024S switch 24...
Some ports not working
Since this is a non-managed layer2 switch, it sounds like those ports are dead. Switch ports die sometimes. If you're the original owner of the switch, you may be able to get it replaced under warranty. D-Link provides a 5 year warranty on this switch. Once a port dies on a switch like this one, there's nothing you can do but replace the switch, or just not use those ports. Good luck.
Jul 18, 2009 | D-Link DES-1024D Express EtherNetwork...
3550 Cisco switch
It does not have to be port 24 to port 24 - You just need to make sure that whatever port you use is configured the same way as port 24 - Example: Log into switch #2 and set port 23 with the same attributes as port 24. Also log into you new switch and make sure port 23 (or 24) is configured the same as those on switch #2. You can the cleanly go from switch #1 - port 24 to switch #2 - port 23 AND switch #2 port 24 to switch #3 port 23 - If you also configure switch #3 port 24 like the others you'll be ready for any additional expansion
May 08, 2008 | Cisco Computers & Internet
CNET CSH 2400 24 PORT SWITCH - LINKING TWO UNITS
You might be having problem in following area 1. Check the cable first. You can use the cabe tester. If cale tester is not available then chek the cable with multimeter. 2. Check the port wher you have inserted the patch cord. It should be in uplink port of first hub and normal port of second hub. Try this and revert back with results.
Feb 08, 2007 | Cnet CSH-2400 24-Port Ethernet Switch
D-Link DES-1024D 24-Port Ethernet Switch (890552611669) Logo
83 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
