Question about D-Link DES-1024D 24-Port Ethernet Switch (890552611669)
Switch is getting on off automatically - D-Link DES-1024D 24-Port Ethernet Switch (890552611669)
    Guru:
  • 561 Answers
Change the power cable. and off the swtich for at least 15 minutes. make sure there is redudnt link .
Posted on Oct 06, 2011
My 2003 Oldsmobile altero gets stuck and i have to jiggle the shifter or leave it set for a min befor if will go from park to reverse ect.. Just got the car yesterday
Your problem is more then likely with the Automatic Transmission Shift Lock Control .This is a safety thing . Has a switch , wiring and a electrical solenoid .
Automatic Transmission Shift Lock Control System
The automatic transmission shift lock control is a safety device that prevents an inadvertent shift out of PARK when the ignition is ON. The driver must press the brake pedal before moving the shift lever out of the PARK position. The system consists of the following components:
• The automatic transmission shift lock control solenoid
• The automatic transmission shift lock control switch
• The park/neutral position switch
Sorry to here your having a problem with it already .
There are diagnostic step to find the problem , involves using a DVOM - digital volt ohm meter an using a wiring diagram to locate test points in the circuit . Plus you will need to take parts of your vehicle apart to get to those test points . The most likely part to fail is the park neutral safety switch . The contacts wear inside after hundreds of times of moving the shifter . But without testing this is just a guess .
With the ignition in the ON position, battery positive voltage is supplied to the park/neutral position switch. With the transmission in the PARK position, the contacts in the park/neutral position switch are closed. This allows current to flow through the switch to the automatic transmission shift lock control switch. The circuit continues through the normally-closed switch to the automatic transmission shift lock control solenoid. The automatic transmission shift lock control solenoid is permanently grounded. This energizes the automatic transmission shift lock control solenoid, mechanically locking the shift linkage in the PARK position. When the driver presses the brake pedal the contacts in the automatic transmission shift lock control switch open, de-energizing the automatic transmission shift lock control solenoid. This allows the shift lever to move from the PARK position.
Apr 25, 2017 | Oldsmobile Cars & Trucks
How do I get unstuck from park?
Vehicles have a safety system that won't allow gear selector to be moved out of park unless brake pedal is pushed ! This what Buick calls there's
Automatic Transmission Shift Lock Control ! Depending on make of your vehicle it mite be called something else . But all vehicles have it.
The automatic transmission shift lock control system is a safety device that prevents an inadvertent shift out of PARK when the ignition is ON. The driver must press the brake pedal before moving the shift lever out of the PARK position. The system consists of the following components:
The brake to shift relay
The rear integration module (RIM)
With the ignition in the ON position, battery positive voltage is supplied to the brake to shift relay coil. When the RIM energizes the brake to shift relay, the brake to shift relay switch contacts close suppling battery voltage to the automatic transmission shift lock control switch. The circuit continues through the normally closed switch to the automatic transmission shift lock control solenoid. The permanently grounded solenoid is energized. This locks the shift linkage in the PARK position. When the driver presses the brake pedal, the contacts in the automatic transmission shift lock control switch open. This causes the automatic transmission shift lock control solenoid to release. This allows the shift lever to move from the PARK position.
Sep 08, 2015 | Cars & Trucks
My mobile will be switch off automatically sometime when i keep it in my pocket
its not switching off automatically, when in your pocket its getting bent and twisted, and the contacts for the power switch are making contact.
Aug 06, 2010 | Cell Phones
My nokia7710 gets automatically switch of when i
Format your mobile phone.. it'll work....
Nov 04, 2009 | Nokia 7710
Automatic switch off my sigmatel s3 mobile
automatic switch off mobile & it lost its phone data(my msg.)date and time
;my mobile setting will change
please send us solution for this
my email id chetanthorbole16@yahoo.co.in .
Thanks
chetan
Sep 30, 2008 | Handmark Software MobileLists (950142) for...
Switching from manually add to automatic sync.
Undock the Ipod. Exit Itunes. Restart ITunes then check off the correct boxes.
Jul 18, 2008 | Apple iPod classic MP3 Player
Nokia 7610 switches off automatically
nokia 7610,
can be rectified..but it will just cost u much for repairs..once u let that to be repaired,another problem will *** in..
u should look for a new one..
Apr 07, 2008 | Nokia 7610
D-Link DES-1024D 24-Port Ethernet Switch (890552611669) Logo
48 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
