I want to clean my filter on my indesit iwd 7168
    Brigadier General:
  • 6,277 Answers
Here are my complete, general pre-typed (!) guidance notes for checking both the filter and the motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
John C
Posted on Mar 17, 2011
The message flashing says 'door' what do I do?
You have a problem with the door switch interlock.
Indesit WIDE 146 (DE) Washing Machine Spares ' eSpares
www.espares.co.uk > Home > Washers & Dryers > Washing Machines > Indesit
  1. Cached
Items 1 - 10 of 60 - Universal stacking kit suitable for most washers and dryers measuring 60cm across More information. In Stock. Stock Number ES187394.
Get Indesit Washing Machine Spare Parts ' eSpares
  1. Cached
  2. Similar
Genuine Indesit washing machine spares including Drum lifters, Indesit ... Start your Indesit parts search by selecting your washing machine model number from ...
Indesit Washing Machine WIDE 146 (DE) Spares - indesitspares
www.indesitspares.co.uk/washing-machine/wide-146-de.../catalogue.pl?path...
  1. Cached
Indesit WIDE 146 (DE) Washing Machine Spares ... Fits models with serial number from 30127.0001 Please Note the above serial number changes does not ...
Indesit Washing Machine IWDE 146 UK Spares - indesitspares
www.indesitspares.co.uk/washing-machine/iwde-146-uk-f084074/catalogue.pl?...
  1. Cached
Indesit IWDE 146 UK Washing Machine Spares ... This part fits the following models: WIL133UK, WIL133UKCO, WIXE127UKV & Does Not Fit Mod. .... If you have just replaced the door seal on your appliance then you may need this retainer ...
Indesit Ecotime IWDE 146 Built-in Washer Dryer - White
www.indesit.co.uk/appliances_i/Washer_Dryer_IWDE_146/pid_F084074UK/42.do
  1. Cached
  2. Similar
Rating: 8.5/10 - ‎19 votes Indesit Ecotime IWDE 146 Built-in Washer Dryer - White, ... News & Offers; Service & Spares. Service · Spare Parts ... IWDE 146 reviews · Ask-an-owner ...
Washer dryer no wide 146 Google Search
Mar 24, 2017 | Washing Machines
If indeesit iwd 7145 write f 12 what is the problem
F12 indicates that the upper control board is not communicating with the main control board, check its wiring and its connections.
Identifying Hotpoint or Indesit Error Codes
Nov 27, 2015 | Washing Machines
Indesit washing machine Model no IWD 71250 S power circuit got problem in this machine. How can i buy a memory card for this machine .
The only way you will get one that will work is if you can find one on ebay with the same model and production number, Indesit will fit the same board into lots of different models and programme specificly for each machine
Sep 18, 2014 | Washing Machines
I have an Indesit IWD 7145 S and it is not washing properly and flashing code H20
You posted in the photography forum not in the washing machine forum.
Apr 11, 2014 | Washing Machines
Indesit washing machine model IWD 7145S says F06 on display and all lights are flashing. its at the end of wash and door wont open
Hi Sammi,
Have a look in the troubleshooting guide of the User Manual Should find some information to help you there. Good Luck,
Jack:}
Nov 17, 2012 | Indesit Washing Machines
My WD 12X machine is not drying the clothes. They get hot but not dry. Is there a filter somewhere that needs to be cleaned?
Presuming that this is an Indesit WD12X.
Yes, there is a filter at the bottom left of the machine (It can be clearly seen in the illistration on Page 14 of the manual, figure 6).
If you don't have a manual, you can download a PDF of it here:
http://www.indesit.co.uk/indesit/_pdf/manuals/19503326500_UK-USA-AUS.pdf
It's highly likely that the water isn't getting evacuated because the filter is blocked and so there is just too much water to dry. Unscrew the filter, clean and replace. I'm amazed to discover that (so far as I can see) The manual never even mentions the filter! Well done Indesit
Jul 19, 2011 | Washing Machines
The water will not dispense and the ice cubes will not come out. I noticed on the front panel that IWD is "off" and that it shows "lock"ed at the bottom of the screen. I know that the...
Press Freezer and Super at the same time for 5 seconds to turn Ice & Water Dispenser on. This will remove "IWD Off" indicator. If it is locked, press the Alarm/Lock button for 5 seconds to unlock it.
Feb 17, 2011 | Bosch B22CS50SNS Side by Side Refrigerator
Indesit IDL 530 Dishwasher
Switch off, turn off power, turn off water, disconnect water inlet hose, check for blockages, remove filters, clean filters, refit filters, check water supply, reconnect water supply, reconnect power, turn on - problem solved.
Apr 12, 2008 | Indesit Dishwashers
Indesit widl126s
Suggestion: Possible your outlet filter is blocked; this needs periodic cleaning, depending on your usage. Clean this out and re-fit. Refer to your users' manual re. where the filter is....
Jun 15, 2007 | Indesit WA 125 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
