Question about Toshiba e-STUDIO 352 Black and White Copier
Is it possible to reset the total counter of this machine?
How to reset the total couter of copy of xerox machine
It's impossible to reset the main counter for the machine because its stored on the main board of the machine
Oct 27, 2015 | Xerox Office Equipment & Supplies
Total counter reset program for sharp ar 5618
Can not be done. people then would reset the counters on old machines and sell them as new
May 16, 2015 | Sharp AR-5320 Black and White Copier
Fini BSC 20 compressor how to reset hour counter
Usually you can't reset an hour counter, as it is designed to report total hours of runtime on a machine -- much like an odometer tracks total mileage on a vehicle. Instead, write down the number of hours displayed when you perform service on the machine, and calculate how many hours will be showing when the next maintenance is required.
Sep 18, 2013 | Air Tools & Compressors
Resetting the counter on a Toshiba e studio 2500c
I reached the total print counter 109219 and want to re set.
Oct 23, 2012 | Toshiba E-studio 2500 cbc939390, Copier,...
How do one enter to Service Mode level 3 of Canon irc3200
That level 3 mode is only for Canon engineers. What counter are you looking to reset? The counters for most maintenance items are reset in service mode level 1. The total counter for the machine cannot be reset without replacing the main controller pcb & the counter pcb.
Jul 25, 2012 | Office Equipment & Supplies
I REPAIR THE MACHINES IN AFRICA SO I NI THE ERROR RESET CODES
Perform the following procedure to enter the simulation mode.
"#" key Interrupt key "C" key Interrupt key
Main code Start key Sub code Start key
Usual "reset" codes:
14 - Trouble cancel (except for U2)
16 - U2 trouble cancel
20 - 01 Maintenance counter clear
24 -01 Jam total counter clear
02 Trouble memory clear
04 SPF counter clear
06 Paper feed counter clear
07 Drum counter clear
08 Copy counter clear
09 Printer counter clear
13 Scanner counter clear
14 SPF jam total counter clear
42 01 Developing counter clear
There are codes and subcodes.
example if yiu want to clear the maintenance counter , you have to enter simulation mode and then enter 20 / Copy key /01 /copy key.
I hope it helps you.
regards,
Adi
Nov 05, 2010 | Sharp AR-5316 Advanced Digital Imager...
How to reset epson stylus d120 waste ink counter? where to download software for resetting? thanks
You don't want to reset the waste ink counter unless you have removed all of the waste ink. Unless you feel like totally dismantling your printer and hand washing the felt pads that are currently soaked in ink you'll probably want to have it serviced professionally or just replace it. Most times replacement is less expensive. Resetting the waste ink counter without cleaning out the waste ink can, and likely will, result in waste ink eventually overflowing out of the the bottom of your machine. Be cautious.
Jun 09, 2010 | Office Equipment & Supplies
Myprint totals say zero.
Press the counter check button. What counters do you see. There can be up to 6 different ones I believe. What counter numbers do you see e.g. 101: Total 1
Counters to display can be set using Service Mode. Press Additional Functions > 2,8 > Additional Functions.
Copier > Option > User > COUNTER1,COUNTER2,COUNTER3,COUNTER4,COUNTER5,COUNTER6
Default's are COUNTER1: 101, COUNTER2: 103, COUNTER3: 201, COUNTER4: 203. COUNTER5, COUNTER6 none.
You could try entering those counters.
The counters could have been reset. It is apparently possible but certainly not advisable to do so without permission from Canon.
Jul 13, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Need to reset display counter/meter on a bizhub 750
If your are speaking of the total counter of the machine, the main counter when you press the "utility/counter" key this can not be reset except in the case of replacing the main board.
Jan 22, 2009 | Office Equipment & Supplies
Afficio 250 SC900...copier will not operate
Is the SC just 900 or is it SC900-01? If it is 900 then it is a total counter error stating that the machine exceeded 9,999,999 copies. If the machine does not have this many copies then the NVRAM is defective. If the SC is 900-01 then the total counter is not working properly. Causes could be .... the mechanical total counter defective, mechanical total counter disconnected, or a poor connection at the total counter. Hope that it is the latter of the 2 codes.
Jan 03, 2009 | Office Equipment & Supplies
Toshiba e-STUDIO 352 Black and White Copier Logo
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
