Question about Philips DVDR3380/05 DVD Recorder
What cable do i need to connect philips dvp3520/05 to hd tv
  • 635 Answers
The DVD player only has a SCART out and unless you have an European model TV it won't have a SCART input. So you have to buy a SCART to RCA cable and connect the RCA end to the TV's AV input ( Yellow to Video and Red/White to audio input )
what cable do i need to connect philips dvp3520/05 - bobhifi_18.jpg
Posted on Mar 17, 2011
We bought a used Philips 42" flatscreen digital TV with no remove and hooked it up to our cable box. It works beautifully but we have not able to reset the screen size using the side buttons and menu...
Yes there is a trick. Usually the cable box and its remote determines the picture's screen size. First off, this television is able to display hd on an hd cable box. Make sure that this cable box is connected with this television the hd way only. It should only be connected to your television with either a component (green,blue,red, white, red) cable OR and hdmi cable. The coax cable should not be used to connect the cable box to the television if you have an hd cable box. Next make sure the television is on the proper input/source to display the cable box in hd.
Now if all of this has already been done, look for the hd zoom # button on your cable remote. It is usually towards the bottom. When you press it you change the screen size. You can buy a philips remote-the original one for your television at http://www.replacementremotes.com if you need the wide/stretch/zoom/viewmode button to further adjust your picture size.
Jul 16, 2011 | Televison & Video
TV does not have aHDMI port so what audio and vdeo csbles needed to connect to a Sky HD box ?
Hello
There is a side socket connection set on your Philips TV. You can connect two audio channels Left and Right and one Video. Connect these socket with an AV cable, and connect the other end of that cable to your SKY HD boxe's respective output sockets. Then select the TV input to AV by going into its menu and surfing through it. That is all for settings. OK
Jan 16, 2011 | Philips 50PF7320A 50 in. Plasma HDTV
I have surroundsound. I have dish network with hd dvr. I have a sony bravia hd tv. I have a dvd player, and cd player. I have a magnavox dvd recorder. I want to record from my dvr to my dvd recorder. ...
To get the functionality you're looking for you'll need to to take the cable running from your DVR output and connect it to the input on your DVD recorder. Next you want to connect a cable from your DVD recorder output and connect it to your TV. If this is an HD set up you want to use HD Cables for all of the connections.
Daniel Busa
DISH Network Customer Service
Jan 03, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
How can I connect my dvd player to a Philips 32PFL5605H/05 32-inch Widescreen Full HD LED TV ? It is of the type which has one red, one yellow, and one white connector but i do not see any sockets that...
The included cable with the red, yellow and white RCA connectors is a composite A/V cable. To connect this cable to the TV, you need a SCART-cinch adapter. Then use one of the SCART connections on the TV. Note: the SCART connection does not handle HD signal.
You will get a much better picture if you buy a different cable. Depending on your DVD player, get either an HDMI cable or a pair of cables - a component video and audio cable. (Both component and the audio cable will have RCA plugs at each end. The component video has 3 plugs - red, blue and green. The audio will have 2 plugs - white and red.) Both of these will carry HD signals. Most DVD players will have at least component video and composite video jacks; some have the HDMI output. Most DVD/VCR combinations will need the composite video for the VCR and the component video is optional for the DVD signal.
I hope this helps.
Dec 24, 2010 | Philips Televison & Video
When i connect my my hd cables on my philips 32fd9954 tv the sound will not work
It is likely you are connecting via the DVI or VGA connectors. By default, these do not carry audio. You will need to bring audio into the display through one of the other sets of connections, then manually select the input with the remote.
Sep 30, 2010 | Philips 32FD9954 32 in. HD-Ready Plasma...
How do i connect a xbox 360 to a philips hts 3555 and hd tv?
Connect audio out cables (L and R) from HDTV to far left audio input at back of hts 3555. Then connect HDMI output from XBOX360 to HDMI input slot on TV. Setup XBOX 360 for audio through HDMI turn TV off and then on and all should be good. It worked for me.
May 25, 2010 | Philips HTS-3555 System
Laptop connection
Buy a HDMI cable.Hook up one side of the HDMI cable to ur tv HDMI Hub.The other side of the HDMI cable to ur laptop USB Hub.That it u got a connnection,now go in ur tv input pick which HDMI inputs,u put it in,example 1 to 4 HDMI Hubs.Pick the one HDMI Hub that ur laptop it hook up in.That it now u got ur LCD tv used as a monitor.
Apr 27, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
I have a Philips DVDR 3575H. using Comcast's
Try this set up-
Use an RCA audio/video cable for this set up (Yellow/Red/White).
Connect from the Video out (Yellow) connection on the back of the cable box to the Video in on the back of the DVR.
Connect the audio (Red/White) cables from audio out connection on the back of the cable box to the "Audio in" on the back of the DVR.
This should still get you a decent picture but not a true HD picture for your recordings.
When you set the timer to record set it to record either E1 or E2 depending on which input you connected the cable box to and ensure that the cable box is tuned to the channel you wish to record.
*** NOTE: If you keep the HDMI cable connected as you have for the cable box and watch normal TV through the HDMI input on the TV you will get HD programming for your general viewing but still have the option to record with the DVR at a lower quality. ***
Good Luck and please rate this solution....
Jan 07, 2010 | Philips DVDR3575H/37
HD feed problem
this tv can only process 480p and 1080i as hdtv signal. Check your motorola to see if it is outputing something like 720p....
Sep 17, 2008 | Philips 30PW850H 30" TV
Magnavox 15" LCD TV
If the LCD only has coax, it will never display a HD picture quality. However, the Comcast HD Box will still display a picture using the coax connection. So, you could watch any HD channel, but the picture quality will not be high definition.
Jan 22, 2008 | Philips Magnavox 27MS343S 27" TV
Philips DVDR3380/05 DVD Recorder Logo
197 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
