Question about JVC Televison & Video
We have an 8 year old jvc i'art pro that has s problem with the colors. It has green lines going thru the pic and it looks a little blurry. Does anyone have an idea what could be happening and how to fix. Don't really want to buy new tv. Thanks in advance!!
    Sergeant:
  • 261 Answers
Sounds like to me that the green CRT is going bad possibly. You can take a ruler or something non-metalic and tap the bottom of the crt GENTLY and see if that helps at all....Sometimes the CRT'S get a piece of debris from inside the tube that drops across the plates of the tubes and causes weird issues.... Tapping on the neck of the crt GENTLY vibrates these pieces off and vaporizes them and then picture goes back to normal. If the set is 8 years old and you watch a lot of TV, I have seen the CRT'S actually worn out physically. Then it isn't worth fixing at that point and your best bet would be to purchase a new tv. If you have any other questions, don't hesitate to email me back. @ zx1400jay@hotmail.com Cheers.... HDTV GURU JAY
Posted on Mar 17, 2011
There is a humming in back of tv.the sound always good but picture doesnt come thru and i get a green screen someetimes blurry with distortion.color wheel or dmd chip or lamp starting to go out
as my experience, the most possible reason should be the color wheel or its photo sensor board.
firstly try to clean its photo sensor board, or have to replace a new wheel.
i just have this wheel, when you need to replace it, contact me freely
May 02, 2016 | Televison & Video
Jvc I art pro double color pink and green
a model number and a better description might help here, like 3d looking?
Sep 03, 2012 | JVC Televison & Video
The picture is a little blurry and the words a fuzzy
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 29, 2011 | Hitachi 50DX01B 50" Rear Projection...
My picture is blurry and green
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 09, 2011 | Sony KP-51WS500 51" Rear Projection...
Lines, a little blurry, a little movement
  • Screen looks 3D
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
Jun 10, 2010 | Hitachi 51F59 51" HDTV Projection...
Blurry and colors are seperated red green white
if you are viewing from a projection tv, chances are you have to go thru the menu of the tv to 'picture tuning'. here it gives you different things that could be fixed. one to look for is 'lamp alignment'. It should show all the colors and lines with directions to bring them into focus. This should fix the blurriness and 3-d red/green/white separations. hope this helps you!
Aug 16, 2009 | Philips Magnavox 51MP392H Rear Projection...
Sony KV-36FV27 too dark, pink or green tint, 5 blink error,
Fuzzy,blury picture in CRT tv tube.Tv in long use not repairable.Tv tube is dying,it junk.
Mar 27, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Green color convergence
make sure you hooked everything up properly and that all connections are tight
Aug 26, 2008 | JVC AV-56WP74 56" Rear Projection...
Daewoo DP42SM coloring missing blue tint on dvd playback only
I don't know are you familiar with electronic,if you are you can fix it by yourself.The problem is in video process board,the one in metal cage.What you need to do is to remove the board from the set,remove the cage, then to replace all SMD capacitors!!!And do not put SMD as replacement put the normal capacitors same values they can be fited.You should aslo replace capacitors at the PSU and check 170V,160V and 70V and adjust them after the replacement.PSU is easy part but the video board is tricky one but it can be done
Feb 15, 2008 | Daewoo DP42SM 42 in. HD-Ready Plasma...
JVC I'Art Pro, Color Fade
sounds like two separate problems. color fade ?
green gun/band = bad convergence ic
Dec 18, 2007 | JVC AV-56WP30 56" Rear Projection...
Televison & Video Logo
97 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
