Question about Facebook Computers & Internet
It's been totally scrambled the last couple of days. when I open it, everything is to the left side,, some on right, can't do anything with it
  • krisinuae Mar 17, 2011
    so i'm suppose to PAY for it? what a joke
emissionwiz
  • 76846 Answers
SOURCE: worn out rear brake pad only on 1 side...
sounds like the caliper is defective, replace rebuilt the brake caliper.
Posted on Jun 03, 2009
rajforu
  • 69 Answers
SOURCE: the right side of my firefox pages are cut
U can set ur page style by going section view then page style then click basic page style.
Posted on Feb 26, 2010
fieldy14
  • 456 Answers
SOURCE: my Element Plasma TV now has a scrambled image on
Normally, these symptoms occour when the Y-sus or the X-sus printed circuit boards become faulty, but if the problem is occouring on every input as well, the problem is either a faulty plasma panel, the screen itself, the main printed circuit board or the logic prnted circuit board, or a combination of all three. Sorry to be the bearer of bad news. I hope this helps in some way. If the unit is under warranty return to the retailer for a new one, or if its only a short timeframe out of warranty, contact the manufacterer and the may offer the grace and supply parts and/or labour under warranty. Good Luck.
Posted on Apr 20, 2010
  • 312 Answers
SOURCE: Sunroof will not open
I think there is a good chance that the left side needs lubricating and the channels lubricated with a colorless non oil substance. The motor is probably working too hard and it burns it out. Darrell S
Posted on May 23, 2010
  • 1206 Answers
SOURCE: rear doors will not open from either side in
the only thing that could have happened is the child safety locks are on. that is why you can not open them from the inside and the outer handles have broken . the thing to do now is to use a tool called a slim jim to open the doors . then unlock the child safety locks so you can still use the doors until outer handles are replaced.
Posted on Nov 16, 2010
I have kitchen aid superba the icemaker works fine, except at the door where ice is dispensed the unit freezes up the ice crusher area like there is an air leak in the door somewhere which allows warm air...
I have had this issue with my french door kitchen aid freezer drawer. I have a toddler who sometimes gets into the drawer. If it is left open just a hair, it will melt everything completely and water leaks out all over the floor.
The drain gets clogged when the door gets pushed back in for a tight seal and freezes again.
Try to focus on keeping a really tight seal every time you open and then close the freezer...its almost like you have to TRY to close it hard to ensure it is closed. Total pain, but it works. When the door is closed tight, it stays like it is supposed to .
Oct 16, 2013 | KitchenAid Superba Architect KSCS25INSS...
One surface light bulb on GE Profile microwave keeps burning out
I have the same problem. The left one burns out within a couple of hours use, the other one lasts a couple of months and is then gone. This pattern has repeated over 8 years. I replace them every now and then and then just go without until I get the urge again to fix it. Maybe smaller lower wattage lamps are worth trying...
Jun 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Worn out rear brake pad only on 1 side...
Jun 03, 2009 | 2003 Honda Element
Vegetable and fruit crisper drawers freezing foods
You have a defective thermistor and damper control in the fresh food or a bad control board.
Check the thermistor first.
Also, adjust the return air damper at the bottom left side of the fresh food sction to warmer.
Feb 21, 2009 | GE PSS25SGN Side by Side Refrigerator
My Samsung BD-P1400 is frozen on "load" and disc tray won't open
My player worked fine couple of days ago, then last night when powered up, message was "load" and it stayed like this forever, and tray open would not work. Tried everything, nothing worked. Left unplugged from power for 24 hrs and bingo everything worked as should. I suspect that the unit is still trying to load info from last disc which I stopped in the middle of some bonus material, even though the disc was no longer in the tray.
Dec 26, 2008 | Samsung BD-P1400 Blu-Ray Player
T30 always comes up with record-ready display screen
T30 defaults to an opening display screen based on where you were when you last used the device. When leaving from the record folder and record mode, you will always open with the record-ready screen. If you left your T30 while in the music folder playing a music file, you will be returned to that.
This record-ready display screen has a numeric and bar time line. The numeric values of the line are in hrs:min:seconds. This line is also split: the right half of the line indicates the total amount of available recording time, while the left half indicates your time as you record. If you compare the values of the right and left sides of the numeric bar while you are recording, you will see that the right side is diminishing as the left side increases in numeric value. When you complete your recording and save your track, the right side will now indicate the new total time (the amount your screen first displayed LESS the time value of the track just recorded).
When you are playing a music file, if you watch the time display, you will see the numeric information changing in the same way. The left side indicates how may hrs:min:seconds your track has played while the right side indicates the total time value for that file and will be correspondingly decreasing while you play your music file.
So in the short, you don't need to worry much about your display screen unless you open in the wrong folder or you need more recording time than is available. Then it has a message for you.
Nov 06, 2008 | iRiver T30 MP3 Player
Last night everything worked fine and I printed many pages. I just now turned my HP 5510 all in on on and the (3) lighted buttons, Copy, Fax, Scan, started flashing. Error message # Oxa0000146 is...
Suspect the printer's program is scrambled (didn't "boot" right)
Could there have been any power fluxuations/lightning during the night? Even if it wasn't on, if it was plugged in the wall then there could have been damage. Are you using a universal power device or a current protector?
Unplug the unit from the wall, wait 20 to 30 seconds for the power capacitors to disipate their energy and then plug it back in. This will do a HARD reset.
Jul 23, 2008 | HP Office Equipment & Supplies
Scrambled keyboard
Is it giving you numbers and symbols? do this: Press and hold the function key fn while pressing the num lock key num lk . This will deactivate the integrated keyboard/numeric keypad, and the keys will respond normally.
Please remember to rate all users who assist you for free :)
Jun 30, 2008 | HP Compaq Presario V6000T Notebook
Freezer dethawed
By the end of the day we realized we thought the refrig. part was working but was not. We pulled it out from the wall, unplugged and plugged it back in. Still no results. I unloaded everything from the freezer in the morning and refrig in the evening. Right after I got almost the very last item out, (the door on the refrig was opened and left opened) I moved the temperature control levers back and forth quickly, really just out of frustration, thinking, 'great no more refirgerator' - now what am I gonna do?!. i went to dump the last of the contents, and like some sick joke, the refrig started working and then the freezer. We have quite a bit of dust under the refrig. that may have been blocking a fan or something. I think God just wanted me to empty the refig contents and things that looks like pieces of the moon from my ridge. Go figure. I am praying no more problems.
Jun 15, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Computers & Internet Logo
75 people viewed this question
Top Facebook Computers & Internet Experts
David Payne
David Payne
Are you a Facebook Computer and Internet Expert? Answer questions, earn points and help others
