Question about Jensen JMC-300 CD Shelf System
The top lid has broken off making the CD player inoperable. Can this be fixed or is there a alternative way of still using the CD player without the lid? vaphl48@hotmail.com
  • 604 Answers
I doubt that it can be fixed, sorry
Posted on Mar 17, 2011
CD player won't load
the CD player is toast.
can you <? i dont know, are you a technician>
but for sure it can be fixed, any tech can
but will cost more than a new CD head.
that is why we throw away things, 2 hr. labor + parts is more that
china new player.... economics.
You could remove the lid and see if some young kid stuffed
in some junk into the slot.
or you see it is totally broken parts inside.
Sep 15, 2013 | Suzuki Cars & Trucks
Hyundai i30 cd player
hi Squeakylyssa .This goes for all cd players.
If a CD is skipping, first ensure that the disc is working properly by checking to see if it plays on another device. If so, you'll have to uncover the problem in your CD player. Some common problems include: broken parts in the device, physical damage to the CD player, dirt within the player or, most commonly, damage to the lens.
Before you do anything with the CD player, it is important to remove the batteries and disconnect the device from any power source. Wait half an hour before you begin cleaning the device.
Use a lens cleaner to clean your CD player's lens properly. Unscrew the top cover of the player and locate the laser lens, which is located just adjacent to the central disc drive. Place a small amount of your cleansing solution on a cotton swab or other applicator that came with a lens cleaning kit; as an alternative to lens cleaner, you can also use isopropyl alcohol. Rub the cotton swab in very light and small circles against the lens until it is clear. Allow the lens to dry, and then proceed to test the CD player. If the CD player is still skipping after the lens has been cleaned, there is likely a hardware problem that needs to be solved.
A CD player has a few hardware components that may be causing your discs to skip. Unscrew and open the case of the CD player to locate the read head and potentiometer. Depending on the type of device you have, you may need to remove the bottom cover to gain access to the soldered side of the electronics board - if so, you will need to remove the whole board before you can proceed. In single-play designs, you should be able to find 3 or 4 screws that need to be removed to enable you to take out the whole optical deck. There may also be a grounding contact under the deck held in with one screw. Make sure you replace this exactly as you found it.
If your player spins for some time without finding the list of tracks and keeps returning some kind of error message once you place a CD in the player, there is a most likely a problem with the read head. The read head is represented by a small square piece that has a plastic disc sitting on top of it. Using a flathead screwdriver, adjust the plastic disc to realign the read head. This process requires you to plug in the device and hit play and stop until these adjustments fix the CD player. Make sure to put the case back on the CD player each time you test it to avoid any electrical shocks.
The potentiometer, which is positioned directly above the laser, may also be misaligned. Usually this is represented by a small square piece that has a plastic disk on top. The disk has a slot adjustable using a small flat head screwdriver. Before making any adjustments, mark the current position of the potentiometer using an indelible marker pen so that it can be returned to its initial position if need arises. You will need to gently adjust the potentiometer and locate the position where the CD player recognizes the disk again and plays it without skipping. Since this is more of a trial and error process, small rotations of plus/minus 30 degrees of rotation are usually recommendable. For safety, put the case back on the CD player each time you test. If you are happy with the performance after the adjustment then put the case back on and you are ready to rock.
Dec 14, 2017 | Cars & Trucks
Makes noises when dvd is inserted
If it loads normally I would not worry about, keep in mind they use more plastic than metal and noise on loading is more evident.
Apr 02, 2012 | LG RC-197 DVD Recorder/VCR
The CD's don't change. The message appears on the screen "error....". Nor can I eject the CD's.
You have a problem with a Cd which is stuck in the transport carriage. If there is no way that you can retrieve do not try to wriggle this out as you might do more damage. You will need to take the player out of the dash and open the top lid.look inside for a CD that would have warped or broken and not being able to come out. Carefully see if the disc can be taken out without damaging the carriage, do not use force, if the loading motor could be accesssed then it becomes easier but do it only if your are confident., Once you get the cd out , reconnect and check if the set will perform. otherwise there could be further failure of the drive circuit, open connection to motor or failure of the pcb. Hope my advice is useful Good day
Jul 06, 2010 | Nakamichi CD-500 CD Player
The top will not close when I put in a CD
Without knowing the make or model of your CD player, it's hard to figure out what's going, but likely the latching mechanism is broken.
Jan 28, 2010 | GPX Audio Players & Recorders
Singing machine ism 1010
My machine has the same problem and I got the same response from the company. I discovered a quick fix. With needle nose plyers I removed the wire from the corner of the lid that holds the lid open. Without the wire, the lid remains closed and the CD will play. The downside is that its tricky to open the lid. I've been using the piece of wire I removed to gently pry the lid open. I think I will glue a knob or ribbon to the top of the lid to make it easier to open. This isn't a perfect fix, but it was quick & free and now I can use my machine!
Apr 21, 2009 | The Singing Machine Singing Machine SME399...
Cd player inoperable
Radio fuse blown - Check your documentation on fuse panel lid or owners manual.
You're looking for a red 10A fuse.
Feb 03, 2009 | 2004 Dodge Neon
CD lid
I strongly suggest super glue. Just allow the hinge to move into the opened position without the lid attached and then carefully match up the broken section and allow the glue to dry. Should work just fine. A replacement would not only be nearly impossible to find but would probably cost as much in product and shipping as the unit itself is worth.
Best of luck!
Sean
Sep 01, 2008 | Spectra Hello Kitty KT2028...
Faulty goodmans 1104s dab player
In the lid should be a mgnetic plate that holds the disc to the motor spindle (much like slight pressure would). Inspect it to make sure it's free moving and seating all the way when the lid is closed. I had one unit where the spindle on the motor shaft had slid down slightly causing the magnetic plate to not seat down all the way. Also, if the magnetic plate is removable, try placing it on the disc with the lid open and bypassed and see what happens.
Hope that helps...
Geno
Mar 06, 2008 | Televison & Video
Jensen JMC-300 CD Shelf System Logo
89 people viewed this question
Top Jensen Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Jensen Audio Player and Recorder Expert? Answer questions, earn points and help others
