Question about Rode NT1A Professional Microphone
I got a pre-amp (Focusrite Platinum Trakmaster Pro) with phantom +48v. i got an M-Audiophile 2496 installed to the comp. and a mic Rode nt1A. Eveything is plugged in and installed and iv'e recorded songs many times before. i was without my studio for a while, and now i got a new mic wich is Rode nt1a. The Problem: The problem is the volume, i need to go on like 8-9 on the pre-amp level to notice any sound activity in the recording program.. and its just noise.. also my voice records but its a big noise in the background... Before when i recorded i only had like level 2-3 on the preamp and it was perfect... whats the ******* problem ?!?!
  • 604 Answers
The process of elimation will help you to solve your issue. first plug the rode nt1 (great mic by the way), into a good pa head or something you know works, of course you will need to have a pa that gives you phantom power. if the mic works then move on to the preamp. try it in the pa too, if it works move on to the m-audiophle and plug a line level signal into it (a cd player or mp3 player for instance) it this works then you have determined that everything works and you don't actully have a problem other than switching, Also try plugging your mic into the M-audiophle directly and see if thaat works ( don't know if that provides the 48 volts, if it doesn't than you will have to get a phantom supply to plug into first. good luck
Posted on Mar 17, 2011
Bluebird mic wont work
Surely you have checked that the phantom power button (48v) is pressed to the ON position?
Jun 04, 2014 | Blue Microphones Blue Bluebird Condenser...
How do you set pattern on Rode NT2? Does the mic function the same on battery power as phantom?
The cardiod pattern is as the instruction manual dictates and there is no difference between 9v battery or 24/48v phantom power.
Mar 20, 2014 | Rode Audio Players & Recorders
MY SE X1 MICROPHONE HAS LOW INPUT ON MY FOCUSRITE PLATINUM VOICE PRO PREAMP
Have you tried a different pre-amp to narrow down the possible issues on your audio chain? Or ensure your preamp works properly by trying a different mic on it..
Also, if this is a stereo setup, try balanced cables to ensure this isn't a phase issue - which can reduce volume dramatically.
there are some programs out there that can boost audio, but if the mic itself is damaged, then take it to an electronics/mic expert.
Apr 12, 2012 | SE Electronics SE X1 Microphone
C451eb dead?
hard to say without more info. you probably know this , but as a condenser mic it requires 48v phantom power to operate. Does the pre-amp/mixer you are plugging it into provide that (there will be a button on it marked 48v)? If not, that is the problem.
Apr 30, 2011 | AKG C451B Professional Microphone
I have a Focusrite Pro 10 i/o Firewire Interface and am experiencing 60 Hz hum through the mic pres when phantom power is switched on with the power supply attached. Phantom power running from 6-pin...
I assume you are using condenser mics as you would NOT be using phantom power with any other type connected or other devices plugged in while you have phantom power. It is important to have ALL interconnected equipment, including the computer, powered from the SAME receptacle or power source. Make sure the power supply you are using is SPECIFICALLY for the unit from Focusrite as some supplies have filtering within the wall transformer module and others do not. The power supply MAY be generating magnetic fields... try moving it around and see if hum is affected. The capcitive coupling in a power supply can let in higher frequency components from lamp dimmers. Make sure you have no lamp dimmers anywhere near the equipment.
Apr 25, 2011 | Focusrite Saffire Pro 26I/O 26 In/26 Out...
Rode NT1A: i got an adapter so i can input it in the mic input the pc says an audio device has been put in but i cant find it anywhere! please help me i also have an Acer Z5710
The reason it is not being picked up by your PC is because the NT1A is a condenser microphone and it requires an audio interface that can supply phantom power (48V) to get it powered up. Without phantom power, the NT1A won't work. You many need to buy an external audio interface that provides phantom power to use the mic. Hope that helps.
Mar 03, 2011 | Rode NT1A Professional Microphone
Mic to PC
This mic is a condenser type microphone. It needs phantom power (48v) to operate. Might want to buy a USB mic preamplifier box, like an M-Audio product, which will provide phantom power, xlr/1/4 inch inputs and USB output.
May 23, 2010 | Behringer C-3 Professional Microphone
Signal peaks automatically once track is armed for recording.
Is there something plugged into your inputs, and are the pre amp channels turned all the way down? Also is your 48V phantom power turned off? To prevent damage to diaphragm or electronics of condenser microphones, the phantom power should be left turned off and only turned on after a mic is plugged in and the pre amp turned off and track unnarmed to prevent damage to speakers.
Aug 17, 2009 | Digidesign MBox 2 Mini (USB, includes...
Rode NT2 got Phantom!
Well... Rode NT2's are condenser mic's that require phantom power to work. So the phantom switch should be on. When you turn phantom power on you usually hear a bump sound (through the amplifier). In this case, nothing is broken.
Your picture is of a Rode Videomic (not an NT2) which is a stereo mic for video cameras. If you had some kind of stereo mini to (single) XLR adaptor, and put phantom power through it, the mic would probably be damaged. But maybe not... just try again without phantom power to see. a stereo mic won't work very well with the Mbox Mini because it only has one mic preamp.
Feb 12, 2009 | Rode (VIDEOMIC) Professional Microphone
Rode NT1A Professional Microphone Logo
389 people viewed this question
Top Rode Audio Players & Recorders Experts
Michial Gueffroy
Jay Plesset
Tom Chichester
Are you a Rode Audio Player and Recorder Expert? Answer questions, earn points and help others
