Question about Telex ENG100LB Professional Microphone
I have a telex FMR100 wireless mike and there is a short in the bodypak where the mike plugs in causing static over the sound system and need to find a repair or replacement
    Genius:
  • 1,126 Answers
You should be able to take it to a shop where they have electronic techs, even a TV shop and they should have it repair under a hour.
Posted on Mar 17, 2011
How do I get rid of the static sound in my 4PR908?
There causes varies from types of headset to another. In respect of a wireless headset, the static sound is caused by interference. Whereas in a cord headset, a loose wire somewhere in your headset or cord is responsible for the static sound or crackle. It might also emanate from the mic in respect of a one calling, or from the ear-piece.
The solution with a wireless headset is to move away from any device e.g computer which might have cause the static sound. Resetting the wireless headset is also a solution measure.
In the case of a cord headset; Get the cord wiggled at the plug and at the headset; and then move the mic to locate the loose connection. Where the problem occurs, loop the wire, taping it down at the point. soldering the affected wire is best than taping.
Finally, if the static sound persist;which it should not after all the treatments; check on the volume of the device. Reduction of the device volume can go a long way to bringing the longed solution. Similar problem occured with my headset;and was solved via the same recommended possibility.
Jan 30, 2015 | Wireless Gear 4PR908 Bluetooth v2.0 EDR...
Sound is distorted and crackles
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
The speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
Clean your computer of dust using a can of compressed air or a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit.
If you use a vacuum cleaner dont use one with a metal pipe if it touches anything on your motherboard it might short something out.
dust causes static to build up in a computer
hope this helps
Nov 16, 2012 | Computers & Internet
Static with mike
Static can be caused by many things. Are you to far from the receiver. If you put it on a padded surface does the static continue, if so it may be local interference. If not it is probably something loose in the microphone. If all else fails Go to Shure.com look under support, you can get a price list and where to return it for repair.
May 16, 2012 | Shure PGX Series Wireless Microphone...
What adapter if any can be used for dell2400 to connect wireless
Most of the wireless adapters available now are compatible to all the computer system.
You can just buy a wireless adapter to any electronic/computer store and it should work after installing the software/driver that came in with the device.
Note when buying any device for your computer:
Always check for the Operating system compatibility of the device.
e.g. : if you have a windows XP system, make sure that the device is compatible with it.
Do the same if you have windows vista, 7 or any other operating system.
Thanks,
~jash
Aug 10, 2011 | Computers & Internet
ProStar UB12. When I turn on the wireless, I get occasional static that is irritating to the point I cannot use it. Is there a fix?
I had the same problem. Mostly, when using near energy saving fluorescent lighting. I would receive high static, especially when the mic was off. We were using it indoors & usually no more than 200 ft from the receiver. I opened it up, resoldered some poor solder connections, sprayed contact cleaner on the squelch & volume controls, but still had the problem. What actually resolved the issue, was turning the squelch control (thru back panel) fully clockwise & completly lowering the antennas aimed horizontally to the rear. If you are using it outdoors, you should not have interference from fluorescent lighting, but may need to raise the antennas if operating from a greater distance.
Sep 16, 2010 | Telex FMR-200H Professional Microphone
Buzzing static sound in speaker
Static can be caused by a few things.
Does the static persist if you unplug the audio cable from your computer?
If so, the static is being caused by the amplifier built in to your speakers.
If not, the static is probably caused by interference on your sound card. Try plugging the speakers in to a portable media player. You might need to replace the sound card in your computer.
May 13, 2010 | Bose Companion 3 Series II Multimedia...
Unable to connect ipod touch to home network
Sounds like an I.P. problem. If set to "Dynamic", try "Static" IP. Had a similar problem with my Linksys wireless camera. It worked...than it didn't. Sounds eerily similar.
Mike
Feb 16, 2009 | Linksys ULTRA RANGEPLUS WIRELESS N GIGABIT...
Telex WT55 wireless lapel mic & FRM70 Receiver
How do I set the squelch on a TELEX FMR-70 receiver?
Jan 27, 2009 | Telex FMR70 VHF Wireless Microphone...
Telex BTR-500 Instruction Manual
I have a manual I can fax to you if you are interested. Email me your fax number, or e-mail address and I'll scan it. Send to: diann_sells_slah@yahoo.com.
Jul 26, 2008 | Telex Btr-500 set (71208000sp) Wireless...
Installing hard drive on this model
Sure why not.
You,ll need a ribbon cable also 40 or 80 strand IDE Cable. to connect from hard-drive to Motherboard. If you have an existing connector already in. this should be In IDE 1 Or Primary slot ( on motherboard ) there should also be a secondary IDE Slot.
connect ribbon to IDE 2 Or secondary slot, and to hard-drive.
ensure the jumper on the hard-drive is set to Slave Or Master, if your running another device from that same cable, set to Master/Slave alternate to hard Drive.
Good luck and go for It.
Power Off first.
Motherboards are,nt too happy about Static.
Mike @ compurepair.
Feb 21, 2008 | Telex 4-52NH SpinWise CD Duplicator, Four...
Telex ENG100LB Professional Microphone Logo
70 people viewed this question
Top Telex Audio Players & Recorders Experts
Ben Armstrong
Sam Palermo
Sam Palermo
jairo sanchez
Are you a Telex Audio Player and Recorder Expert? Answer questions, earn points and help others
