Question about Video Game Consoles & Games
I replaced the top screen of my DS Lite. I had trouble getting the ribbon through the hole Nr the hinge, I had to role it up and pass it through. Eventually I got it to pass through but then couldn't unroll it to get it out. I had to use tweezers and I think I may have damaged the ribbon in doing this, it's very crumpled and has a tiny hole. When I turn the DS on, I get a green light for half a second, the top screen flickers once and that's it...Nothing. No green light...No nothing. Please help. Cheers. Clare
  • 661 Answers
*sigh* -facepalm- Clare, consider this a lesson in electronics component replacement. If you're talking about one of those goldish-orange ribbon cables, then you need a new replacement screen. There actually is a small chance you may need a new DS as well. NEVER, EVER, EVER, EVER force one of those cables. For that matter, never force ANYTHING while repairing small electronics. My friend learned this the hard way. If you look closely at those cables (actually called flex cables), you'll notice that its slightly textured. That's because these flex cables contain multiple conductors. Once your flex cable is "crumpled" that means that some of the conductors inside the cable have either snapped on the microscopic level or malfunctioned in some other way. (I don't think i have to explain what a HOLE through the cable would mean.) Those things are designed to be flat, and REMAIN flat; they are even installed flat, so if you had to "roll it up," as you say, then that means one of two things: You don't have the hand-eye coordination/dexterity necessary to repair things of that size (which i'm going to assume that you DO have), or that you were installing it incorrectly. I'm assuming the latter. I have replaced multiple DS screens, and not once have i ever had to pass it through a hole of any sort. Now, if you are talking about those recievers on the mainboard where you have to flip a small hinge up to remove/ install the cable, thats totally different. The end of the cable goes into the reciever, and stops there. It does NOT go all the way through. Once the cable goes in as far as possible, flip the hinge back down so that the mechanism can "lock" the cable in place.Give it a light tug to make sure its locked in. Don't pull too hard. It should be good to go afterwards. Remember to buy a replacement screen. The one you just bought is totaled. If you have any questions, feel free to shoot me an email at edchen111@gmail.com. Just make sure to include pictures if you do send me an email. I can provide better assistance if you do. Good luck.
Posted on Mar 17, 2011
The top screen of my nintendo ds lite is red
You have probably damaged the cable that passes through the hinge on the DS, the only way to fix this is to replace the top screen on your DS lite.
Nov 14, 2013 | Nintendo DS Lite Console
Ds lite comes on the top screen flashes then it switches off
It could also be a bad top screen due to a bad ribbon cable. If your hinge is cracked it could cause damage to the ribbon cable that passes through it, this shorts out the top screen and will shut the DS down
Jul 08, 2010 | Nintendo DS Lite Console
How do i fix my top screen on my ds as it flickers on and off
Here is a place that sells the replacement screen for your Nintendo DS Lite:
http://www.amazon.com/Nintendo-DS-Lite-Full-Replacement-Screen/dp/B000RX1E8C
May 31, 2010 | Nintendo DS Lite Console
Ds lite
To remove the top external casing first you have to separate the top part from the bottom part of the DS by dissasembling the bottom part and unplugging the top screen ribbon and the white and black wires, then slide these cables through the hinge hole to separate the parts.
Then you must take out the 4 screws under the cover pads in the screen side, and slide the screen side from the external side so the screen side should move like 5mm from the external side and then you would be able to separate both and see the screen, mic and speakers.
May 12, 2008 | Nintendo DS Lite Console
Ds lite hinge broken right h/s (looking at it)this has affected the top screen any ideas please
Hi, it sounds like when the hinge has got damaged, so has the top screen ribbon on the left as its easily ripped. Would need a replacement case and top screen, can recommend here for both: www.console-spares.co.uk, hope this helps.
Mar 24, 2008 | Nintendo DS Lite Console
DS 2 Peices
Hey, you need a new outer case and a new top screen. There is a ribbon that comes out of the top screen on the top case and connects to the bottom one. There is a very good chance that ribbon has torn off. So you need to replace the top screen and a new outer case with a new hinge. I would send it to Nintendo, I believe they offer a flat rate service for the Nintendo DS Lite.
Bimmerhp
Jan 22, 2008 | Nintendo DS Lite Console
Green screen
There is a ribbon that connects the top screen of the ds to the motherboard. It is possible that this ribbon became damaged when the hinge broke. A possible fix would be to replace the upper screen. Hope this helps.
Jan 07, 2008 | Nintendo DS Lite Console
Top Screen Replacement of DS Lite
there is a video tutorial at http://www.maxconsole.net/?mode=news&newsid=11484
which tells you how to disassemble the ds lite
Dec 04, 2007 | Nintendo DS Lite Console
Display screen on DS Lite
I had this same problem on my Lite earlier this year.  It was still under warranty, so I sent it in to Nintendo repair, who replaced the hinge assembly.  Based on the symptom and the repair, I suspect it's caused by a loose/damaged ribbon cable between the upper screen and the rest of the Lite.
I'd be leery of trying to fix it yourself (I've worked on similar problems in laptops), but if your Lite is out of warranty, you might try one of the third-party repair services.  Depending on whether the ribbon cable is damaged or just loose, they may not even need any replacement parts.
Oct 14, 2007 | Nintendo DS Lite Console
Replacement of all covers.
to remove the top screen the back cover actually slides off after removing all the screws from the front, once thats off you can see the ribbon cable coming through the hinge, what you need to do is coil the ribbon cable up into a tight little roll and push it through the hinge it's easier if you pull the two little cables out first. hope this helps
Sep 03, 2007 | Nintendo DS Lite Console
Video Game Consoles & Games Logo
41 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
