Question about Epson PowerLite 7300 Multimedia Projector
We have connected the laptop to the projector with cable to Computer 1. After pulling up the DVD we need to project, we hold the function 8 key and it just shows 'not supported' on the screen. Not sure what to do. We did load the CD Software included ver. 1.03 to the computer. Thanks for your help.
You could try prior to "hold the function 8 key" to:
Both may be found in the laptop's Display Properties.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 02, 2008
Jul 14, 2015 | Computers & Internet
'No signal' and 'unsupported signal' messages mean 1 of 2 things, either the VGA output is off(laptop) or the display resolution is set too high(laptop and desktop). Assuming the VGA cable you are using is good, try this:
Desktop: hook the computer back up too your computer monitor & set the computer to the basic VGA resolution. For windows XP, right click a blank area on the desktop, click 'properties' on the dropdown menu, click settings. Write down the numbers in the 'screen resolution' and 'color quality' boxes!
Drag the 'screen resolution' all the way down to then 'less' side. Then change the 'color quality' to the lowest setting. Click apply, then answer yes (the display will look UGLY - don't worry!!) Now connect your computer back to your projector. If it works, then the resolution you use on your desktop monitor is not supported on your projector. Experiment with different resolutions to see which one looks best on your projector. You will need to change the settings each time you switch monitor to projector.
Laptop: by default the VGA connector on your laptop is off. To turn it on, look for a blue symbol on one of your function (F1, F2, F3...) keys. It looks like an old TV with a line on both sides 'O' (F4 on HP) Press & hold the blue button (on the lower left of the keyboard, usually to the left of control ) and tap the bleu button you just found. Let go & give you're a computer a few seconds to change over. If the laptop screen goes blank, you found the correct button! The display image should now be visible. Repeat this 1 to 2 times to change it back to laptop display.
If you did not see the display on the projector, 2 other issues are possible. First, verify that the VGA output on the laptop is working - connect the laptop to a regular computer monitor & change the display resolution to the lowest settings (see desktop above), then try it again on the projector. If you cannot get an image on a computer monitor, your laptop settings may need to be adjusted in the same dialogue box as the settings. Monitor #1 is the laptop display, Monitor #2 is the external output.
Happy viewing :)
Jun 12, 2011 | Epson PowerLite S3 Multimedia Projector
Mar 03, 2011 | InFocus In2102 Projector
Dec 09, 2010 | Elmo Projectors ELMO TT02RX DIGITAL...
Aug 26, 2010 | Canon LV-5210 Multimedia Projector
Jun 17, 2010 | HP Digital Projector Vp6110 Multimedia...
Jul 09, 2010 | Eiki LC-SM4 Multimedia Projector
May 24, 2010 | Dell Inspiron Mini 10 Notebook
Jan 06, 2009 | HP Pavilion dv4000 Notebook
Aug 04, 2008 | Computers & Internet
Jan 08, 2013 | Epson PowerLite 7300 Multimedia Projector
Aug 01, 2010 | Epson PowerLite 7300 Multimedia Projector
118 people viewed this question
We've tried to lower the resolutions to the lowest possble output. Do not see anything about screen refresh. It still doesn't work. Yikes, we present in 7 hours.
I may try to hook up a portable dvd player....if we can get ahold of an S video.
If you have any other suggestions, thanks.
