Question about Alesis DM6 Performance Electronic Drumset Bundle
Hello, I connect my headphones to the Alesis DM6. As result, i can listen my drumming, while i'm playing. But, the sound is not always good. Sometimes I hear, only on one side the music, or it is rustling. What can I do to solve this problem? The problem is not the headphones, that's were I am sure about. Bye, Lucas
  • 604 Answers
You have a bad cable (wire) or a bad jack (where you plug in your earphones) plug your output into another device (guitar amp for example) and see if the problem persists. if it does then it is most likely internal problems with the output jack. If this is the case you will have to take the unit apart to find out where the problem is. if you're not comfortable doing this then you will have to take the unit to someone who is.
Posted on Mar 17, 2011
Testimonial: "Thank you men. I'll try to fix it"
How fix the firmware problems with alesis dm6?
Have you updated the firmware recently? If not, do so.
If you are having volume issues, you can adjust them with the following:
Adjusting the volume of individual pads:
-Press Voice.
-Then press Volume.
-Strike the pad you would like to adjust.
-Then use the + and - buttons to adjust the volume of the individual pad.
-To adjust another pad, strike that pad, and repeat step 4 above.
Aug 04, 2014 | Alesis DM6 Electronic Drum Set
I own an alesis dm6 mod. how upgrated firmware?
Click this to unload the latest firmware from the manufacturer!
DM6 Module - Firmware Update [v06]
DM6 Firmware Update Installer for Windows. Updated 04.26.2012
Fix'dYa
Can I use a 12V adapter to power the 9V output for my Alesis DM6?
No, it will work for some time, but will eventually overheat and cause damage. Spend the $10-20 and have piece of mind.
Jul 25, 2014 | Alesis DM6 Electronic Drum Set
Alesis DM6 kick/bass has a really low volume-any way to make it louder?
MAKE SURE WHEN YOU ADJUST THE VOLUME YOU PRESS
SAVE , GO BACK IN A CHECK VOLUME LEVEL TO A MAX OF 16
Jan 09, 2013 | Alesis DM6 Electronic Drum Set
No sound from bass drum
MAKE SURE YOU DIDNT TURN OFF THE TINY SWITCH IN THE BACK OF THE MODUELE
Jan 04, 2013 | Alesis DM6 Electronic Drum Set
Alesis dm6 bass pedal
There's a tiny switch on the back of the module "kick type" try switching that
Sep 22, 2012 | Alesis DM6 Electronic Drum Set
Alesis DM6 electronic drum kit module sound problems: The mix in, display and sensors are working on the module but no drum sound is produced through the monitor or through headphones (but an ipod can be...
It appears that you have to select a "Kit" of drums when using the external triggers. It appears that the volume level for the kit and that for each voice MAY all have to be set, especially after new firmware download. Read manual about KIT volume level and selecting voice and volume level for those. Manual is NOT very clear about these things and you have to try them as this is where the probllem is.
May 08, 2011 | Alesis DM6 Electronic Drum Set
Have the alesis dm6 there is no out put sound. monitor appears to be working. hooked to small amp or headphones. just fuzz. please help. little guys christmas present!!!
Two things:
Check that cables are seated, especially the one at the main module.
Second, look for a setting for "Local Control" in your user's manual; That setting should be "On" to accept the triggers from the pads.
Dec 25, 2010 | Alesis DM6 Electronic Drum Set
I own an Alesis dm6 mod. how to add cymbals.
I think your best solution is this> You can add 10 more triggers with it:http://www.alesis.com/triggerio
May 09, 2010 | Alesis Sr 16 Stereo Drum Machine
Alesis DM6 Performance Electronic Drumset Bundle Logo
341 people viewed this question
Top Alesis Music Experts
drivealot
Lawrence Oravetz
Robert Graf
Are you an Alesis Music Expert? Answer questions, earn points and help others
