Good evening! my problem is i cannot open my files on my kingston usb flash drive because there's an error prompted "syntax is incorrect" i follow the instructions given to me online about how to fix errors in kingston usb flash drive, i click the properties of usb drive then click the tools then click the this option will check the volume for errors then click check now, then under check disk option there's a selection box i check the automatically fix file system errors then click start, the reply was your device or disk successfully scanned for i thought the problem of my usb drive will be fix, but then after that all my files was deleted, i don't know how to restore all my files, i need to restore all of them because all files are very important documents, i don't have any copy or back up files, please help me with my problem, hopefully i can restore again all my files. Thank you
    Sergeant:
    Champion:
  • 210 Answers
Dont be upset.... i dont think that u will be able to restore it... have ur disk formatted and start over...
Posted on Mar 17, 2011
The Computer cant open the USB Flash Drive. It said that it is not formatted so I try to Format the Flash drive via command prompt. The command prompt said "The first NTFS boot sector is unwriteable....
It should be the file system problem. Usually a usb drive should be formatted to FAT initially instead of NTFS. Recommend you try the USB on another computer and see if the problem still occurs. If yes, then try format it from Disk Management of your computer. If you can't format, use TestDisk (also a command line tool) to fix the file system error. You can also see from this blog post to learn more about the possible reasons or solution. Regards
Jun 14, 2011 | Computers & Internet
I have a kingston datatraveler dti g2 with 4gb capacity. when i insert it it displays as "Removable Disk (F:)" but when i clicked it the message "Please insert a disk to drive F". my os...
Solving this program is simple. Your BEST option is to contact Kingston directly:
http://www.kingston.co,/support/default.asp
Answer the questions on that page and follow the prompts to get help from Kingston. They will know how to help you solve this problem at no cost. They will tell you how to test the flash drive to be sure that it is still working properly. If the drive is defective, they will issue you an RMA number so you can return it for a new one. Kingston support is excellent; contact them and they can help you solve this.
Good luck; let us know how this turns out.
Apr 14, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My flash drive have an ioctl error. the drive can still be recognized only can be accessed. how can i fix this problem. my usb flash drive is a kingston 16GB?
I have a kingston usb flash drive 256mb but it shows 0mb in windows when I format on cmd prompt it shows IOCTL error does any one have a proper solution or utility to remove this problem
Nov 01, 2010 | Computers & Internet
I can't write files to my kingston 2gb usb flash drive.
Hello.
If you are getting a message that the disk is full, erase some of your existing files.
If there are no files on your flash drive, I'd suggest formatting your drive. If there are files, note that any existing files will be erased.
If your flash drive is drive "G" for example, enter "format g:" (no quotes).
Hope this helps.
Nov 07, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I have a shortcut to an internet site that has somehow had its name changed to a line of ??????? ? ?????????. The computer will not allow me to delete it, stating "the file name or directory name or volume...
run a check disk first, those kind of names is not allowed in windows, so it should pop up some error.
in msdos command prompt:
chkdsk C: /F
(assuming it is in drive C)
It should give you an error, saying the volume is locked, so you need to reboot, during the reboot, it will check the file system.
Still in command prompt, just try to delete the file using:
del "??????????" /F/S/Q
USE the quotes please, or it won't work.
OR... the hardway ;) get a Linux Live CD, mount the filesystem, and delete the file.
Sep 14, 2009 | Microsoft Windows XP Home Edition
Cannot delete my bad files...
Could be a process issue stopping you deleting the files. Try downloading unlocker (http://ccollomb.free.fr/unlocker/) and see if this helps.
If not it might be an 8.3 naming convention issue. Go to DOS prompt to a "dir /x /a". Rename the file to less than 8 characters using the SHORT name only. Then try deleting the file.
Apr 01, 2009 | Microsoft Windows XP Professional
My bad files cannot be deleted!!!
I would Boot into "DOS" or to the C:> prompt WITHOUT loading windows, (from the same window that you enter safe mode from), and find the suspect files and delete them.  del <filename.ext>
Mar 29, 2009 | Microsoft Windows XP Professional
Annoying files cannot be deleted...
First I recommend you try deleting the files from the Windows safe mode... it might work, or you an use the deleting software Unlocker
http://www.softpedia.com/get/System/System-Miscellaneous/Unlocker.shtml
Mar 20, 2009 | Microsoft Windows XP Professional
Unable to format 64 gb kingston pen drive
These are actually ccore flash drives, shipped with the name "Kingston". YOU CAN FORMAT ANY ZIP DRIVE WITH "HP USB DISK STORAGE FORMAT TOOL". Trust me, it really does the needful. I had the same problem earlier =)
Feb 12, 2009 | Computers & Internet
Problem with kingston DTI/4GB
Help me please!!!When I insert my 2GB kingston USB into my computer I go to "My Computer" then I go open it but it say "Choose a program to open the file"!!!What should I DO???Please help......Usually I can open it one but now suddenly cannot(I don't have the program that can be used to open the USB)
Apr 09, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Computers & Internet Logo
157 people viewed this question
David Payne
David Payne
