Question about ASUS P4S800-MX Motherboard
Wuill not start until four pin plug pulled out
  • 340 Answers
Which four pin 2x2 or external drive power cable
Posted on Mar 17, 2011
Why can I not get power to the small wire going to the starter on my 2004 taurus
You need to know how it works before you can diagnose it. There is a starter relay in the under hood fuse/relay box .. This relay is controlled by the PCM - engine computer . Does you car have a anti-theft system ? a red light on top of the dash or a SECURITY light on instrument cluster ? Is the red light flashing fast when trying to start the car . If you find an pull the relay out an look on the bottom you will or should see four numbers . 30 & 87 , 85 & 86. You can test from the socket where the relay plugs in . PIN'S 87 & 85 should have B+ voltage . PIN 30 takes voltage from PIN 87 to start the vehicle , PIN 86 is the control from the engine computer . The PCM gives a ground on this circuit to energize the relay closing the contacts inside ,completing the circuit between B+ voltage on PIN 87 to PIN 30 to start the car.
Feb 04, 2016 | 2004 Ford Taurus
My 98 Mitsubishi eclipse 2.0 I recently purchased had oil in the spark plug wells I noticed the valve cover bolts were loose (2) u tightened then down changed plugs and wires when I removed cylinder four...
In theory you should be worrying about all warning lights but that is sometimes impractical when it becomes necessary to allow things to develop in order to find out what might be going wrong and wait until a decisive problem appears - often the expected problem never does develop.
Apr 11, 2017 | 1998 Mitsubishi Eclipse
How do I find the pin number on a motorola sb5101n
  1. Enter the last four digits of your phone number on your cell phone PIN screen. When setting up a cell phone PIN, the default number assigned is the last four digits of your cell phone number for most cell phones.
  2. Enter 9999, and if that doesn't work try 1111. The number sequence 9999 and 1111 are other standard numbers assigned when choosing a cell phone PIN.
  3. Shut off your cell phone, take off the back of your phone and pull out the battery. Record the IMEI number under the battery. Reinsert the battery and power on the phone. Enter the last four digits of the IMEI number on the PIN entry screen. The last four digits on your IMEI number can occasionally be the service provider's preset PIN for the cell phone.
  4. Call your service provider and request the PIN. You will have to prove you are a customer by stating your cell phone number, address and Social Security number.
  5. Turn off your phone. Hold the keys "3," "*" and "Call" and switch the phone on. Hold the three buttons down until the word "Formatting..." appears on the screen. This should reset the phone lock code.
  6. Go to one of the links in the Resources section and have your IMEI number ready. These websites will ask for your phone model and IMEI number and then charge you a set fee for the unlocking PIN.
Mar 13, 2011 | Motorola Computers & Internet
Having trouble starting, I have cleaned the spark plug but after I try to pull the rope to start it the plug seams to be full of fuel.
If there is excess fuel getting into the cylinder it means the rubber tipped needle in the carb is leaking, a simple pressure test will prove this, if you do have a pressure tester you will have to change the needle as a matter of course, the needle is housed under the metering side diaphram, remove the silver cover held with four screws, rmove the diaphram, and the gasket, the needle is held in by a pin secured by a single screw.
Feb 20, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I am having problems getting the power brake booster installed on my 2000 dodge grand caravan. Are they any online instructions for this?
I doubt it,
You need to take the two nuts that hold the master cylinder to the booster off,pull out on the master cylinder until it clears the booster,but don't take any lines loose!
Now go inside your van and remove the knee panel below the steering column,And then a metal plate behind that comes down next,After that reove the brake light switch connected to the brake pedal,it is held in place with a push pin and hair pin clip,remove the clip and then the pin,now you can remove the push rod that was connected to the pedal,Now look at the fire wall where you took the rod out ,you will see four nuts that make a square,two on the left and two on the right,straight up and down from each other,Remove these four nuts and go back out under hood and pull the booster out towards you.
Jan 18, 2010 | 2000 Dodge Grand Caravan
Convert three pin plug to four pin
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one on top is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown on the bottom.
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Sep 06, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Saw will not start
Possible sheared flywheel/crankshaft alignment pin. Remove flywheel check pin.
Jul 08, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Wont power up
This may help. I have had the same problem from time to time. I took the back off ( slowly don't break the four wires connected to the back) then I cleaned the connections where the battery pins press to the main board.
Jun 12, 2009 | Magellan Meridian Gold GPS Receiver
No anything
Flashing amber power button indicates a failure of the power supply.
Jun 14, 2008 | Dell Dimension 4600 PC Desktop
ASUS P4S800-MX Motherboard Logo
216 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
