I have just bought and loaded a new HP cartridge black ink 21 for 1400 series. Test page prints ok but printer is now offline. I have turned on/off, reloaded cartridge, checked printer drivers are up to date. Still printer offline. If i tick use offline still won't print. Please help.
  • 111 Answers
Kindly check if you have pending print outs on your computer, if you do just delete those.
Else check if you have set the printer on default printer may be your printer is not the default one.
Thanks.
Posted on Mar 17, 2011
My hp office jet all in one printer is only displaying error ,when i turn it on
HP Officejet J4580 All-in-One Printer Troubleshooting ' HP ...
support.hp.com/us.../HP-Officejet...All-in-One-Printer.../troubleshooting/
Let HP find my products ... Note: This tool can only find HP products you are currently using or ... Error · Printer Problems after Upgrading to Windows 10 · A 'Paper Jam' Message Displays for HP Officejet J4500/J4600 All-in-One Printer Series ... PrinterSpecifications for HP Officejet J4500 and J4600 All-in-One Printer Series ...
A 'Paper Jam' Error Displays on the HP Officejet 4215 a
Dec 18, 2015 | HP Office Equipment & Supplies
HP deskjet 6122 prints test page but everything else doesn't print
Regarding your recent inquiry about the HP 45/78 printer error condition (i.e. improper print quality, etc'), it sounds like your cartridge's internal micro-electronics are either clogged or have electrically failed and will need to be replaced. NOTE: The HP 45/78/78+ ink cartridges are extremely robust (compared to many of the newer versions found in market today) and can typically be refilled 8+ times, on average, before suffering a hard internal electronic failure. To verify the electrical health of the ink cartridge, please perform the diagnostic checks below or refer to our HP printer diagnostics document: http://inkjet411.com/?page_id=1813
In some cases the ink cartridges just need to be FIRMLY re-seated into the carriage assembly (also check the cartridge restraining mechanism/arms if present - sometimes these mechanical restraints/arms become loose over time...please double-check these if applicable). We also suggest that you ensure the printer carriage/flex cables (where the cartridge interfaces to the carriage inside the printer) and ink cartridge rear electrical contacts are thoroughly clean to rule out poor connectivity as root cause: http://inkjet411.com/?page_id=1519
Cartridge & Printer maintenance should be evaluated:
Ensure both ink cartridges and flex cable contact surfaces (where the cartridge interfaces to the carriage inside the printer) are thoroughly clean: http://inkjet411.com/?page_id=1519
1) Gently blot the cartridge Nozzle Plate with a damp lint-free towel/wipe - a small amount of ink should be dispensed, and be visible, on the towel (all 3 colors should be present for a Tri-color cartridge).
2) If no ink is dispersed from nozzle plate (i.e. visible on towel) or ink cartridge completely fails to print on paper after installed in printer, then more drastic cartridge and printer cleaning steps will likely need to be performed to recover ink cartridge (NOTE: foam inside cartridge can dry out and become very hard - the foam must be moist with ink to function correctly (i.e. ink flows and wets the nozzle plate). Refer to 'clogged ink cartridge recovery' video here: http://inkjet411.com/?page_id=2818
Providing the ink cartridges are clean, the problem may be caused by a dirty wiper blade or poor seal in the service station (capping station where the ink cartridges park when not in use) and this is causing the poor jetting / print performance issue you are observing. Remove the ink cartridges and thoroughly clean the wipers and seals: http://inkjet411.com/?page_id=1519
DIAGNOSTIC TESTS FOR HP Officejet and LX, Officejet 300 series, 700 series, T series, D series, K series, G series, V series, 4100 series, 5100 series, 6100 series, 7100 series PRINTER (HP 45/78 ink cartridges):
Perform Self Test Print: http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&dlc=en&docname=bpu00734
1. On the front panel of the product, press Menu (or Setup).
2. Press the Right Arrow until Print Reports displays, and then press Enter, Start, or OK.
3. Press the Right Arrow until Self-Test Report displays, and then press Enter, Start, or OK.
NOTE: Unfortunately, alignment pages and internal self test prints will usually print Ok even if the cartridge is internally electrically damaged.
Perform Printer Error Reset:
1. Open the printer/cover as if replacing the cartridge and allow the carriage assembly to move to the cartridges access/loading position.
2. Unplug the power cable from the rear of printer and close the printer's cover.
3. While depressing the power button, plug in the power cable. Keep the power button pressed for about 10-15 seconds, allowing the error flag to reset.
4. After printer powers on, cycle printer power once again and allow printer to fully initialize (may take ~5 minutes for the message/error condition to disappear).
NOTE: If ink cartridge error persists then replace ink cartridge.
If procedure above does not work, then refer to HP.com to print a HP Self-Test Report (older HP printer models) - click here for instructions & sample prints: http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&dlc=en&docname=bpu00734
*Many cartridges eventually do encounter problems or failures, especially after their original ink is gone and they are re-used, and this is often unrelated to the refill process. Typically the ink cartridge's nozzle plate suffers a break at one of the flexible circuit lines within the base of the cartridge nozzle plate...refer to photo at bottom of this page: http://inkjet411.com/?page_id=509
However, if your printer works routinely after inserting a brand new HP 45 black or HP 78 color ink cartridge in it, this will confirm the root cause of failure.
We trust this detailed technical information provides you some additional insight into the issue you have endured.
CAUTION: Be advised, the use of compatible/clone cartridges (i.e. sold thru the internet from China) are known to be problematic and may cause printer errors. We do NOT suggest refilling these types of ink cartridges.....refilling of original/genuine ink cartridges is only suggested!
HP 45/78 Ink Refilling Services & Additional Cautions:http://www.youtube.com/watch?v=M7Q8t2pr2WA
If you need to purchase a new ink cartridge, we suggest you try a remanufactured HP 45/78/78+ ink cartridge from http://www.inkplicity.com/ as their ink cartridges typically have the lowest cost in the USA and reportedly have a high reliability rating (plus free shipping for all orders above $20).
For any additional questions please contact us directly: Inkjet411help@gmail.com
-Thank you
Aug 30, 2014 | HP DeskJet 6122 InkJet Printer
Black cartridge problem device documentation. HP Officejet 4500
This type of HP 901 ink cartridge error ("Refer to Device Documentation", etc.) condition is likely an internal micro-electronic failure inside the HP 901 (or 901XL) black ink cartridge. These failures typically occur due to natural degradation of internal micro-electronics over time and can occur with brand new ink cartridges.
To confirm root cause and check the internal electrical condition of both black and color ink cartridges, please execute the 'Tap 41' cartridge's electrical diagnostic test below (refer to procedure B).
CAUTION: Be advised, the use of remanufactured ink cartridges is considered somewhat unreliable since the cartridges are already on their 3rd life when purchased new (off the internet or at select retailer stores). As well, the use of compatible/clone cartridges (i.e. sold thru the internet from China) are known to be problematic and may cause printer errors.
NOTE 1: Unfortunately, alignment pages and internal self test prints will usually print Ok even if the cartridge is internally electrically damaged. Do not use these test pages as a proxy for determining whether a cartridge is good or bad, only the 'Tap 41/43' diagnostic test report can yield this information.
DIAGNOSTIC CHECKS:
A. Ensure BOTH carriage/flex cables and BOTH ink cartridge contacts are thoroughly clean before proceeding: http://inkjet411.com/?page_id=1519
B. Validate the cartridge's electrical health by running the 'Tap 41' diagnostics test. Refer to 2nd video procedure at the following link on how to activate and read the service test: http://inkjet411.com/?page_id=620
a. Load Letter/A4-size paper into paper feed tray.
b. If any lights are blinking, first press Cancel to attempt to clear.
c. Press the * and # keys simultaneously.
d. Enter 124 at keypad. The 'Underware' menu should be displayed.
e. Use the arrow keys to navigate to the System Menu. Select Ok.
f. Use the arrow keys to navigate to the 'print-mech tap test'. Select Ok. Printer screen should display "code = 0".
g. Use the arrow keys to enter "code = 41" (or just enter 41 on keypad). Select Ok. The Tap 41 diagnostic test pattern prints.
--- Providing the HP 901 (or 901XL) color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health - the printer will attempt to print the diagnostic test print). A good HP 901 color cartridge should display 1248 good nozzles, while a good HP 901/901XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the diagnostic test print: http://inkjet411.com/?page_id=620
---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
For more diagnostic tests and error bypass procedures, please visit the Inkjet411 support center: http://www.inkjet411.com
Hopefully this helps....
Sep 12, 2013 | HP Officejet 4500 All-in-One -...
My black ink does not work. I have put 2 new
please clean the heads of your black cartridge also the scanner or sensor for cartridges this can cause to black cartridge not to print.
Aug 19, 2009 | HP Photosmart C6180 All-In-One InkJet...
Printer replaced with black cartridge, and doesnt print
Hello sir; did you remove the tape sealed on the black cartridge, make sure your cartridge is OEM not GENERIC.
Feb 03, 2009 | HP Photosmart C6100 All-In-One Printer
Hp officejet 6110 not printing with black ink
Hi lilacky-
Here are some HP support links that might be helpful... and a couple questions to consider.
Q: Is your new cartridge one of these listed below?
"The HP Officejet 6100 series and HP Digital Copier Printer 410 products use the print cartridges listed below:
* HP 56 black print cartridge
* HP 57 tri-color print cartridge
* HP 58 photo cartridge (replaces the HP 56 black print cartridge for six-ink photo printing)" info from: Installing a Print Cartridge
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00004340&lc=en&dlc=en&cc=us&lang=en&rule=12548&product=79477 Is your new cartridge a refilled cartridge? Some times those have special challenges. Has your cartridge been sitting a while in the box, maybe in a warm spot? Some times even new cartridges dry out a little. Was your old cartridge low or completely gone? Just as a test, if you put it back in your printer does the old cartridge work? Any printer error messages? Can you print a test page or an alignment page for your black cartridge? These might be too many questions but here are some HP support links with some How To information for getting more answers. Please let me know if any of these are helpful. see also: Slow or No Response from Printer
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?rule=11882&lc=en&dlc=en&cc=us&lang=en&product=79477 -JW
Oct 03, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP colour cartridge no. 22 won't print
if the test pages come out OK then the problem can not be the printer !!!!!!!
it must be from the application
Sep 04, 2008 | HP Color LaserJet 2600n Printer
My C3100 HP all-in-one printer prints a test page everytime I want a single copy. How can I print before wasting ink on a test page?
cannot load new ink cartridge c 3150 black cartridge keeps popping out when you close acces door help thanks harry
Apr 23, 2008 | HP Office Equipment & Supplies
Quit printing black
did anyone ever solve this issue? We have the same printer and can't get the Dam thing to just acknowledge black ink only.. When any of the color cartridges are low the stupid printer won't allow us to proceed printing in black until we replace the cartridge that is low..$#@**&^*$#
Mar 08, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart C3100 series
I just got off the HP help line.  After changing my black ink cartridge a test page was printing each time I turned the machine on.  This is very costly, in both time and ink as the cartridges themselves for this machine hold very little ink.  I tried to learn from HP tech how to turn off the test-print while keeping my color cartridge empty.  It turns out that you cant do it.  HP requires you to keep buying and using cartridges whether you need them or not.If you buy the color ink it will use it up in its testings.  And if you dont buy the color cartridge it will use up your black ink by printing the test each time you turn on the printer.  The printer was inexpensive sure, but I'm paying for it in wasted ink.
Dec 26, 2007 | HP Photosmart C3180 All-In-One InkJet...
126 people viewed this question
jasbo
jasbo
