Question about Dishwashers
Water going in but arms wont turn - Dishwashers
  • Dishwashers Master
  • 43,501 Answers
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Posted on Mar 20, 2011
My Lamona dishwasher HJA 8650 lower spray arm wont rotate, water is spyaying out and nothing in place to stop it rotating, can you help?
Sounds like the pump that pushes the water up to the spray arm is going south on you.
Check to see if the pump or any of the piping, or sprayer arm jets are clogged.
Feb 23, 2017 | Dishwashers
Upper spray arm on my Kitchen Aid dishwasher (8573025) doesn't work.
Arm operates(turns) by water pressure. If it does not turn no water is going to the top spray arm. make sure the setting washer is on does not preclude the top spray arm from operating(read manual). If not check arm by spinning by hand to make sure it is free. If arm is free and it still does not turn when DW is running than there is a restriction in the tubing to the upper spray arm or the check ball or solenoid are not operating correctly.
Mar 01, 2012 | Dishwashers
Arm wont spin..drains fine..arm spins by hand fine
If the arms are not rotating then there is not water going through them.
Remove the arms and check all the holes for blockages.
Oct 07, 2010 | Danby 22 in. DDW396 Free-standing...
I turned off my ice maker with the switch on the ice maker now it wont turn back on. Is there a reset or a way to reset the ice maker
How did you know it is not on? A single cycle for an ice maker takes some time to complete. They don't have reset buttons. You just lower the arm to turn it on and raise the arm to turn it off. The cycle goes like this. The tray is filled with water then as the water freeze it reaches a temperature that which triggers a sensor. Then a heating element melts the bottom of the ice then the mechanism rotates and dump the ice. Cycle starts again. This single cycle can take a few hours to complete. If the cycle is interrupted by turning off the water, it could take a while because the ice maker will go through the cycle regardless.
Jun 26, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Icemaker
this is a test, if its a new er model, turn maker switch off for 15 seconds,turn on move the flap arm below the maker bak and forth 3 times waite 3 min, this should reset maker
May 07, 2010 | Maytag MSD2651 HE Side by Side...
Dish washer problem
check water going into unit. disconnect to make sure there is a strong pressure going through.
check the water valve with a meter if there is continuity the valve is good. if not the valve is bad a no water water will go through. let me know if this helps
Feb 23, 2010 | Dishwashers
Dishwasher fills but arms wont spin
sounds like a sticky or broken valve. these units have electronically operated valves to control water flow. its very likely that one of these has failed.
Sep 20, 2009 | Dishwashers
Wont fill
turn off the water, there is a cap on the top pop it off with fingers or a screw driver and rotate the fill valve arm a 1/16 to 1/4 turn and the top should pop off turn the water back on and it will flush it out, make sure you have your hand or a cup over the top so the water doesn't go everywhere then reassemble it and it should be good to go
Aug 07, 2009 | Fluidmaster Plumbing
Arms wont spin
there is a problem in the motor and impeller the impeller on the end of the motor could be loose this is what forces the water through the system for the spray arms to turn check the whit impeller on the end if not tight replace the motor assy
Apr 30, 2008 | Frigidaire 24 in. PLD2850 Built-in...
I replaced the spray arm seal, but the arm still wont spin. I get water but not enough pressure to turn the top arm. The bottom arm works fine. Should the top arm turn easily when pushed by hand. It...
arms should turn freely. spray arms are only rotated by water spraying out from angled jets at end. check for blockage in spray arms - sweet corn and rice are the worst offenders. take spray arms off and run water in centre hole and see it runs out of all the jets freely
Apr 08, 2007 | Whirlpool GU2400XTPS Built-in Dishwasher
Dishwashers Logo
29 people viewed this question
Top Dishwashers Experts
