Question about Sony KP-57WS510 57" Rear Projection HDTV
Convergence problem - Sony KP-57WS510 57" Rear Projection HDTV
    Sergeant:
  • 261 Answers
Usually what happens is that the convergence IC goes bad or the fuse going to the convergence ic goes bad. Pico fuses they are called sometimes open up. You may want to open it up and pull the board out and check the solder connections on the convergence IC. Sometimes these get fractured or cold soldered and aren't making connection to the PC board.
Let me know if you feel comfortable with pulling TV chassis out or pulling the board that has the convergence IC on it out. Then you can resolder convergence IC OR replace it.First thing i would do is check to make sure there is between 22vdc and 25vdc on the fuse or the convergence IC. Let me know if this helps out any.... Sincerely HDTV GURU JAY
Posted on Mar 17, 2011
Is having a local newspaper start placing video about news events on its website an example of media convergence
Anon, I think this could be looked at as a type of media convergence. Check the attached links on media convergence. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
What are examples of media convergence
Converging Media Home
media convergence
What is Media Convergence
Jun 03, 2013 | Computers & Internet
How do I adjust the convergence?
3_24_2012_6_00_06_am.jpg This is a common problem on many brands of Projection Tv sets. Its usually a convergence issue. You can get more details and a solution here on fixya using this link http://www.fixya.com/support/r11932741-convergence_repair_dull_video_repair
Feb 03, 2011 | Panasonic PT-51G36 51" Rear Projection...
Convergence issues
Your TV most likely has a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 20, 2009 | Mitsubishi WS48511 48" Rear Projection...
Picture color ghosting
  • Screen looks 3D
0667c5f.pngSOLUTION
Jun 20, 2009 | Toshiba 50HX70 50" Rear Projection...
Convergence problem--blue lines won't line up
  • Screen looks 3D
0667c5f.pngSOLUTION
Jun 19, 2009 | Mitsubishi WS-65809 65" Rear Projection...
I have a sony Projection TV KP46WT510 convergence issue. How can I fix it? I see fusy picture with red and bleu double picture. I tried the convergence fix in manual and it shows the issue but could not...
Your TV most likely a convergence failure. ( common problem )
  • Screen looks 3D
0667c5f.pngSOLUTION
Jun 13, 2009 | Sony KP-51WS500 51" Rear Projection...
Need to know what convergence chips are in Panasonic PT51HX41E
your model has two STK392-110 CONvergence Cs, you will also most likely need at least a few of the 2.2 ohm 2watt convergence resistors. I am posting a link to the actualrepair kit for your model which contains both Convergence ICs and all 6 of the convergence resistors and they send instructions with pictures that show how to do the repair.
http://servicemanuals.vstore.ca/product_info.php/pName/panasonic-projection-tv-convergence-repair-kit-1/cName/convergence-repair-kits
May 28, 2009 | Televison & Video
Manual Convergence
your convergence ICs have failed. You can get the convergence repair kit for your model at the following link which contains both convergence ICs and all of the feed resistors, plus the kit contains step by step instructions with pictures on how to do the repair.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-dptv-305-dptv345-convergence-repair-kit/cName/convergence-repair-kits
Feb 01, 2009 | Philips 60PP9202 60" Rear Projection...
Convergence problem
your model has two boards that control convergence. One is the convergence board. the other is the convergence board power supply, usually when more than one color is off its the Convergence power supply that is bad. You can get replacement circuit boards at the following link.
Jul 19, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
No color adjustment
Problem with Hitachi 51F500 51 in. Rear Projection HDTV-Ready Television
i want to learn how to do convergence on my tv its a hitachi rear projection i have problums with colors not aligning,could you lead me in the right direction ps: i don't have the remote so i
can't magic focus
Posted by avatar13.jpgejaparks on Mar 03, 2011
AdChoicesMajor Appliance Repair
www.graysoncollinapplianceandac.comResidential/ Commercial, all brands Friendly, knowledgable technicians!
Get $75 of Advertising
www.Google.com/AdWordsPromote Your Business On Google. Claim Your $75 Coupon Now!
Solutions (1)
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Jul 04, 2008 | Philips Magnavox 9P6034C 60" Rear...
Sony KP-57WS510 57" Rear Projection HDTV Logo
187 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
