Question about Marantz ZS5300 6-Channel Amplifier
Radio channel coming through on cd zone
Hi, An annoying radio channel is coming in when we turn on our Marantz, thi s is INPUT 1, which should only play iTunes from our comouter. So we are getting both the radio station and our music playing at the same time.. any clues? Thanks.
(The radio station seems to drop in and out)
  • 31 Answers
Sounds like an internal prob within the reciever, since recievers have radio tuners in em, maybe a prob in the input switching in it. I assume you are running unbalanced rca cables out of the dvd player into the reciever as it probably doesn't have balanced input capability, unbalanced lines are susceptible to R.F.I. ( radio frequency interference ) but I doubt if that's the problem here unless maybe you are running very long cable lengths from the dvd player to the reciever. Try using a different input and see if the problems still there, can use any input other than phonograph really as they are all line level inputs.
Posted on Aug 07, 2008
Do you know were I can get a wiring harness for DDA 650W VALOR car stereo
no wiring diagrams found
only this
Features:
6.5" Double Din Size Fully Motorized IN-Dash Monitor w/DVD;
2 DIN;
16:9 Wide Screen;
Compatible with DVD/VCD/CD/MP-3/CD-R/CD-RW;
"True All-In-One" (no separate brain);
Built-in DVD;
AM/FM radio tuner;
Wireless remote;
3 video inputs;
1 aux input;
2 video outputs;
Front and rear audio outputs;
Subwoofer output with adjustable crossover;
Center channel output;
Reverse signal input for camera;
Dual zone playback function;
AC-3, Dolby Prologic II;
Dolby digital surround (5.1CH) audio output;
PAL/NTSC compatible;
DVD/CD changer interface;
5 x 45 watts;
Oct 23, 2016 | Cars & Trucks
How do you set time/date?
Hi, do you have the MiniTuner module in the radio? You need that in, and the antenna connected facing the SW horizon. Turn on to SATellite. Adjust antenna so that you can hear Channel 1 clearly. After you hear channel 1, the satellite will send a time signal. Then go to MENU, select Adjust time and pick your time zone and if you are on Daylight Savings time. Then, menu to exit out. Your satellite signal will keep the time updated when in Satellite mode.
I don't know if that will also set the regular clock too, or just only the time while in satellite mode. Let me know how you do with it.
Aug 19, 2014 | Timex TMX1 Satellite Radio Receiver
How to set swr galaxy dx 949
you do not "set" swr.you cannot set it on the radio. the radio can tell you what yourswr is. it can take an swr measurement. swr has to do with the antenna system. in order for the radio waves to radiate from the antenna properly, the physical length of the antenna must match the length of the radio waves. if the antenna is too long or too short you will have a higher swr ratio. the higher the ratio the less energy will leave the antenna. but that energy needs to go somewhere, so it goes back into the radio which causes damage and can ruin a radio.
first turn the channel to 20. then switch the meter switch to CAL. then key the radio. while keyed, turn the CAL knob up until the needle in the meter gets right to the CAL Mark. next flip the meter switch and key the radio. where ever he needle is, is what your swr is.if it is more the 1.5 that's getting high. if its over 2 you are in the danger zone. if its over 3 you are damaging your radio. you must repeat the calibration proceedure for every channel.to figure out weather your antenna is too long or short, you compare the swr readings from channel 1 and ch 40. if the swr is higher in 1 then on 40 the entenna is too short. if its higher on 40 then 1 its to long.
Aug 05, 2011 | Galaxy Radios DX-949 40-Channels Base CB...
I have a kdc-mp228 im have trouble getting sirius on it
Visit the new website siriusxm.com then turn on your radio and put it to channel zero get the radio id which compose of an alphanumeric characters. Then on the website refresh.siriusxm.com enter the radio id of your radio and then put your radio channel to channel 1 the go back again to the website after inputting the radio id click refresh after 5 to 15 minutes turn on to the channels that you want. Make sure that your car antenna is facing under a clear view sky.
Apr 09, 2011 | Kenwood KDC-MP228 CD Player
I recently bought a NR1501 receiver and a CD5004 CD player at the same time. I don't use the tuner as I have a separate DAB radio. I use the Aux2 source for the radio input and the CD source for the CD...
How did you isolate it to the CD player?
Of course you know that this fault lies in the realm of the Twilight Zone as no 'intelligence' or commands are exchanged between the units via their RCA cables.
http://www.retrevo.com/support/Marantz-NR1501-Receivers-manual/id/23506ag717/t/2/
I'd try to eliminate the posibility that erroneous remote control commands are getting into the receiver from somewhere, either your own remotes or some other I/R source. Block the I/R sensor on the receiver and see if it switches spontaneously. You may haved a rogue I/R source in the room.
Do not allow direct sunlight, an inverter fluorescent light or other strong source of light to shine onto the player's infrared receptor window. Otherwise, the operation of the remote controller may be disabled.
• Bear in mind that operating the remote controller may cause other devices operated by infrared rays to be operated by mistake.
• The remote controller cannot be operated if the space between the controller and the player's infrared receptor window is obstructed.
• Do not place any objects on top of the remote controller.
Doing so may cause one or more buttons to be held down which will cause the batteries to run down.
Jan 20, 2011 | Marantz NR1501
NOT SCANNING CORRECT ZONE
No! your radio is not programed properly. you will need to take it to a Motorola Dealer or back to the person that programed it. It is a simple fix but you cna not do it from the keypad.
Sorry. Bill
Apr 30, 2009 | Motorola Talkabout T4500 (7 Channels)...
Only one speaker works in dvd/cd mode, both work when you use AM/
could be dry solder joints on the input of the amp?
Apr 25, 2009 | Marantz SR-780 Receiver
My xm roady will only turn to certain preset stations
Turn the unit off and on with the power button and you should be able to get channel 1. Can you get Channel 1? If so, then call XM and ask them to send you a 'refresh' signal to reactivate your subscription on the radio. okay?
Mar 14, 2009 | Delphi Roady SA10035 XM Radio Receiver
Marantz SR-5200 - Analog inputs only play the right channel
please invert your cable and watch if the problem moved the problem in your cable change it with new one.from any radio shack near you or any electronic store.
Jul 05, 2008 | Marantz SR-5200 Receiver
2-way radios
The Bellsouth 2231 is a FRS VHF I couldn´t find if thi Bell south 1007 is FRS in UHF or VHF if you have this informtion compair them if both are in the same band VHF or UHF both radios can communicate to each other
Mar 02, 2007 | BellSouth 1061 (14 Channels) 2-Way Radio
Marantz ZS5300 6-Channel Amplifier Logo
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
