Question about Jwin JX-MP124 (128 MB) MP3 Player
When i on my device .it shows only word starting and the off automatically.
  • 20 Answers
This sounds like a battery issue. The battery sounds dead, try replacing the battery with a known good battery. If this doesn't solve your problem, plug it into your computer and try to access it's data, if you can access the data then the device is fine, the power is not.
Posted on Mar 17, 2011
How to connect motorola h350 bluetooth device for listen the music in our android phone
Go to Settings on your phone turn on device as you start your Bluetooth on your phone. They should find each other and pair automatically but if they don't, turn off the device and then on again then immediately touch "scan" on your Bluetooth setting on your phone. If a new device shows up after scanning under "available devices" touch the new device name and it should pair. Good luck!
Aug 05, 2017 | Motorola Radio Communications
My cd-r king usb flash disk 8gb ve series is not detecting my pc
  1. Click Start, then type device manager in the Search box, then click Device Manager.
  2. Expand Universal Serial Bus controllers. Right click a device and click Uninstall. Repeat for each device.
  3. Once complete, restart your computer. Your USB controllers will automatically install.
Dec 17, 2013 | Electronics - Others
Acer aspire 5630
You may have accidentally disabled it. Right-click the volume icon and select "Playback Devices"
Right-click a blank space and select "Show disconnected devices"
If a device shows, right-click and select "Enable"
If that fails, open the start menu, and in the search bar type "device manager". Click on the "Device Manager" option. Once it loads, find "Sound, video and game controllers" Click the arrow to the right of it. If there are no drivers there click "View" at the top of the screen and select show hidden devices. If it's still not there, click "Action" and tell it to find new devices.
If it appears, make sure you have the drivers installed. You can update a driver by right-clicking the device and selecting the update option. If you had to use the "Action" option it should automatically install the drivers.
If none of this worked, you may need a new sound card.
Aug 11, 2013 | Computers & Internet
Hook the ipod 8gb to computer and it shows as camera. also does not recognize as a device in itunes anymore
You will need to restart the Apple Mobile Device service. If you use Windows. Then:
goto start>run type services.msc find Apple Mobile Device, double-click it, set start up type to automatic and press start. Your ipod should be visible now, if not reboot your computer
Feb 24, 2011 | Apple iPod touch
No sound card driver no sound audio
Try this:
Go to Start->Settings->Control Panel->Adminstrative Tools->Services
Then locate in the list of services "Windows Audio". Open this service
If this service is showing with a Startup type set to Disabled then Select "Automatic" from the drop down list then hit apply. Then click the "Start" button.
If this service is showing with a Startup type set to Manual then Select "Automatic" from the drop down list then hit apply. Then click the "Start" button.
Next Go to Start->Settings->Control Panel->Sounds and Audio Devices then select the Volume Tab then put a tick in the box marked "Place Volume Icon in the Task Bar" then click apply.
With a bit of luck and following wind you should now have your sound restored.
Good luck
Apr 20, 2010 | HP (400745-001) Sound Card
My HTC touch is dead after WM6.1 upgrade from XDA developers
Hi. Have you tried reflashing your device (Assuming you have done before with the instructions from the xda-developers) with another ROM from xda-developers? If it doesn't work, you can try to reflash your device with an official ROM from the HTC website. Hope this helps.
Jun 26, 2009 | HTC S620 Smartphone
My pc is restarting automatically continously when i turn on my
Does it show BLUE Screen, or does it show the Windows loading before it restarts?
If Bluescreen, something happened to root system files and you need to REPAIR
1. Shut down PC, pull out all USB devices, Floppies and insert Win CDROM
2. Power on
3. Press any key to boot from CDROM
4. Select Install
5. Select Repair
6. Ans questions and let run 30min
7. Remove CDROM
8. Reboot - it should work now
If Windows Logo, A device or driver you or MS or Mozilla or... installed for you malfunctioned and you need to start in LAST KNOWN GOOD mode
1. Reboot
2. Press F8 and hold down
3. Enter Password if asked
4. Select "Last Known Good"
5. When stable and logged in, Reboot
Jan 18, 2009 | Microsoft Windows XP Home Edition
Automatic updates
Hi ,
right click on my computer--properties--automatic updates--click on ---check box---apply --ok
check like this..........
Jul 02, 2008 | Computers & Internet
Device won't start Code 10
Try starting in Safe mode (press F8) before the WinXP start screen appears, then uninstall the device. Also you can check "Show Hidden Devices" in device manager.
Also try a different slot if there is one available.
Code 10 means there isn't any resources or address left for your card.
Also make sure your BIOS is set for automatic plug and play mode in case the setting was reset somehow.
Mike
Oct 30, 2007 | NexxTech NPCINIC Network Adapter
Jwin JX-MP124 (128 MB) MP3 Player Logo
Top Jwin Audio Players & Recorders Experts
 Grubhead
Grubhead
Oloyede Monsuru
Are you a Jwin Audio Player and Recorder Expert? Answer questions, earn points and help others
