I am trying to clear a pump out fault with my Hotpoint WF 541. The hoses connected to the pump are held on with plastic clips that are pressed together in such a way that the plastic teeth lock into grooves. I have tried to loosen these but am worried about breaking the clips off. Is there a best way to loosen these? Many thanks, J.
    Brigadier General:
  • 6,277 Answers
NO!
I suspect they are not meant to be re-used, just replaced, sorry ;-0(
John C
Posted on Mar 17, 2011
Problem with Hotpoint Washing Machines Samsung
ND -not draining. There could be something is stuck in the drain pump or one of the hoses connected to it( normally a coin is stuck in the L-shapped plastic connector to the drain hose)if the system is clear,then I would replace the drain pump.
Nov 02, 2013 | Samsung Washing Machines
What does Fault code F-05 mean
Drain machine by running the outlet pipe into a bucket at floor level or run the outlet pipe out of the back door if it'll reach. Check the filter unit for blockages. Filter generally located behind a panel at the foot of the machine.Some are obvious like little square hatches and some are hidden behind the trim panel at the foot of the machine. Once panel is removed the filter should be visible. Its generally a circular plastic fitting which unscrews in an anticlockwise direction. Some hotpoint, indesit and ariston filters are located in the big black sump hose (the one that leaves the bottom of the outer drum and connects to the pump). Remove the back cover, locate hose, remove the tensioner clip by squeezing the tabs together with a set of heavy pliers or vise grips, remove the hose, take out filter and clean. Be prepared for spillage of water. May help if the machine is tilted backwards at an angle.
If problem persists, check pump and pump hose. Pump removal: power off, drag machine out onto the floor, remove back cover or tip machine up at an angle, locate pump, (attached to other end of drain pipe).undo 2 wiring connections, 2 hose connections, and pump mounting screws. Remove pump chamber - some are held in with screws, others clip into place. Check for foreign objects round the impeller. If pump chamber is clear, may be a fault with the pump motor - in which case, replace the pump.
Jan 20, 2011 | Indesit W 123 Front Load Washer
Aquarius WF 541 will not go to spin
machine draining ok? check the pump/filter/outlet hose. if ok check the brushes in the motor.
Oct 26, 2009 | Hotpoint Washing Machines
Washer door will not open. washer just making humming noise
OE-pump blocked. Disconnect the power before attempting any work. Use of an RCD (plug in power breaker) is recommended.
Disconnect pump from sump hose and check for obstruction in either item. Pump removal: power off, remove cover, locate pump, (attached to other end of drain pipe).undo 2 wiring connections, 2 hose connections, and pump mounting screws. Remove pump chamber - some are held in with screws, others clip into place. Check for foreign objects round the impeller. If pump chamber is clear, may be a fault with the pump motor - in which case, replace.
Also check the filter - generally located behind a panel at the foot of the machine.Some are obvious like little square hatches and some are hidden behind the trim panel at the foot of the machine. Once panel is removed the filter should be visible. Its generally a circular plastic fitting which unscrews in an anticlockwise direction. Some hotpoint, indesit and ariston filters are located in the big black sump hose (the one that leaves the bottom of the outer drum and connects to the pump). Remove the back cover, locate hose, remove the tensioner clip by squeezing the tabs together, remove the hose, take out filter and clean.
post further comment for more help....
Apr 17, 2009 | Maytag MAH8700A Front Load Washer
OE error code
best of luck...........
Mar 29, 2009 | Maytag Neptune High Efficiency Washer...
Water wont drain
Good Luck!!
Mar 26, 2009 | LG WM-2277HW Front Load Washer
Oe error code
Feb 06, 2009 | Maytag EPIC MFW9700S Front Load Washer
Error code-OE
Good Luck!!
May 27, 2008 | LG WM2016C
HOTPOINT aquarious extra
try putting the drain lower worked on our WF 541
Dec 15, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
