Question about Hotpoint RLA80 Refrigerator
My RLA80 does not go cold anymore. The black compressor is red hot. The thermostate was on 5 but this morning it was on 1.
  • Hotpoint Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 18, 2011
WHY FREEZER/FRIDGE NO COLD?
Sound terminal, plugged in, switched on, fuse is good.
Is it under guarantee, you say the noise was midnight and the compressor was still hot next morning, that may suggest seized motor in the compressor unit. Sorry no quick fix from me, ring manufactures service department help line - call a refrigeration engineer (expensive) buy a new one with guarantee.
If you have anymore info please post as I am online for now. Also check your household contents cover it may cover you for breakdowns and loss of perishables.
Regards David
Mar 06, 2016 | Refrigerators
Looking for manual for sanborn B51-A24-80V1 model
PDF]Sanborn Black Max 5hp Air Compressor Manual B51 A24 80 1
intrigante35hindu.strictlyyouth.org/rzsatzo_sanborn-black-max-5hp-air-...
Jul 16, 2015 - Sanborn Black Max 5hp Air Compressor Manual B51 A24 80 1 ... Black Max Portable Air Compressor - 5 gallon Item #: 81527 ' Model #: BS0880504 ...Compressor Manual: $4.95: Buy Now: B51-AT24-80V,B51-A24-80V1.
Aug 28, 2015 | Air Tools & Compressors
Replacing a relay and overload protector with a 3 n 1 hardstart
2 BLACK WIRES IS POWER. ONE GOES TO NEUTRAL, ANOTHER TO THE HOT WIRE(LINE) AND IT DOES NOT MATTER WICH YOU WILL HOOK UP AS LONG AS ONE OF THE BLACK WIRES HAS NEUTRAL, ANOTHER ONE POWER. AND BLACK IS GOING TO COMPRESSOR COMMON PIN, WHITE TO START PIN OF THE COMPRESSOR AND RED TO RUN. I HAD ON THIS REFRIGERATOR START AND RUN CAPACITORS, I ILLUMINATE THOSE - THEY CAN NOT BE IN THE CIRCUIT WITH 3 N 1 HARD START KIT. SOME COMPRESSOR HAVE THOSE CAPACITORS, SOME NOT. I DID NOT UNDERSTAND WHY THIS ONE HAD CAPACITORS IT WAS ONLY 1/3 HORSEPOWER. HOPE THIS HELP YOU.
Jan 01, 2014 | Kenmore Refrigerators
How to fix a Kenmore chest freezer model #255.19502010
Kenmore model 255.19502010 seems to have this problem where it will not get cold anymore, but it is a $12 solution and and easy wiring job. Easy like if you know colors and how to plug things in you should be able to do it. Get a Supco 3 n'1 Start (model RCO410) for a 1/4-1/3 hp compressor on ebay or Amazon. This one device replaces 3 different components (relay, overload and start capacitor) that all have a tendency to fail. When it arrives, make sure the frezer is unplugged, remove the metal panel on the side of the freezer. You will see a large black orb almost the size of a football, that is the compressor. On the left side there is a black plastic box that covers the connections on the side of the compressor. Open that up and you will find another black plastic thing plugged into the compressor that has a bunck of wires plugged into it. Pull it loose of the compressor by pulling straight back or gently prying it away with a flat screwdriver. You will see that it is plugged into 3 metal prongs that stick out of the compressor. You will see that all the wires go back to a Cylinder shaped device about 1.5 inch diameter and about 5 inches high it is secured to the bottom rail with a single bolt. Remove the black cylinder and all other pieces that were plugged into the compressor. You should be left with a white and black wire coming from the dial selector on the front. Follow the directions on the package of the SupcoBy connecting the white wire to the lower left prong on the compressor, the Black wire to the top center prong and the red wire to the bottom right prong. Connect the other 2 black wires to the black and white wire coming from the dial with the enclosed wire nuts. Put the new 3 in 1 next to the compressor andplug in your freezer to test. If it gets cold then unplug it and secure the new 3 n1 with a ziptie, duct tape' screw' or some other way (do NOT screw into the 3 n 1 just through the hole in the top.)
If this does not fix your freezer then put it on craigslist for a fermentation chamber for home-brewers and home wine makers because your compressor is probably shot.
One note: while I was repairing mine I took the dial thermostat out and int eh process unplugged one of the connection. The first time I plugged in my freezer it did not turn on but the green light was on. If this happens to you inspect all the connections and make sure they are on tight.
Feb 07, 2013 | Kenmore 5 cu. ft. / 142 liter Chest...
Hi there We have a kelvinater fridge, it is quite old but not that old that you don't get parts for it anymore. But anyway the thing is broken, first the gas but thats fixed, we even got a new...
if the compressor runs but the fridge never gets cold, toss it, if the compressoris not running replace the start mechanizm, also check to make sure the thermostate is putting power to the compressor when you turn it colder, if not... then replace the therm
Feb 05, 2013 | Refrigerators
I just bought a new ingersollrand compressor its a 80 gal 5 hp 220v i need help wiring it
This is simple it is a 220 volt machine so you would need 2 hot wires one red and one black each one is 110 volts now you have a green wire that in the grown wire and then the white wire with is the neutral wire. So black to black, red to red, green to green and white to white./
Aug 22, 2009 | Ingersoll Air Tools & Compressors
Just bought a second hand service fridge/freezer. Plugged it in and it is not getting cold or freezing. I can hear a hum but only for a few seconds at a time. I have been assured that it works but after 2...
no check the air thats being blown by the fan in the freezer can you feel any cold air and i mean cold? if not go to the back of the fridge taKE Off the bottom panel should have like 6 to 10 screws see if the fan in the back is working  if yes see how hot the compressor(the big black thing next to the fan, sorry some people dont know what it is) see if its hot if it is very very hot like burn your hand hot you can try to cool it down with some paper towels and cold water but unplugg the fridge if its warm not so hot or cold than you need to get a 3 in 1 kit  your compressor is not turning on because the starter relay is not good and its not helping the fridge turn on the relay is very very easy to install once you get it youll have to take off the black plasticon the right or front side of the compressor there are two plastic parts that are on the compressor under the big black part ( you might not have the black plastic if not just do this step) take the plastic parts that have the wires attached to it put the kit on on the kit there are three wires with metal little parts at the tips fallow the directions and place them on the right part of the  compressor there are three metal sticks about less than an inc big and you have to put the three wires on each one FALLOW THE PICTURE black on the middle on and depending if you middle on is on the top or bottom would depend where you put what color wire if you middle one is at the top put white wire on the left and red on the right and if you middle one is in the bottom black goes on it and white on the right and red on the left but like i said fallow the directions
than you have to strip the other two wires that are left on the kit than take the two wires that you took off with the plastic parts that were on the compressor once you cut them strip the wires and just connect them to the two left over ones from the kit doesnt matter which one goes where
sorry for the long reply but this should help
if you do the 3 in 1 kit and the compressor turns on and after a while like an hour it doesnt feel cool air at all than you have a freeon leak which mean new fridge
the 3 in 1 costs like 20 dollars
good luck keep me upadated
Jun 07, 2009 | Freezers
Whirpool Refrigarator Compressor Very Hot Will Burn You and Is not Cooling Properly It is letting freezer melt and not barely cold inside
hey
you either have 3 things an over heated compresser, this wouldnt allow the compressor to cool anything beacuse it has an overload which kicks out once the compressor is too hot, and the compressor doesnt work without the overload. solution: get some paper towels, UNPLUG THE FRIDGE, and run some cold water on the towels and use them to cool the compressor, i like to get like 4 or 5 towels wet them and put them on top of the compressor and get another 4 5 towels wet them put the un the bottom front of the compressor. than use another 4 5 towels and cool the front by just rubbing the middle front. keep repeating this until your compressor is not hot anymore like luke warm or better than buy a 3 in 1 its like 20 dollars and install that ( if you need help i will be more than willing to walk you trough it over this or you can call me too)
and the second thing that it can be is overheated compressor due to the condesner fan not working, and thats simple fix just see when you turn on your fridge and turn the dials all the way up to 9 or w.e option you have. see if the fan by the compressor is working if not replace it its also like 20 bucks
or 3 the worst case scenerio free-on leak it has no freeon and the compressor keeps keeeps working to cool the fridge but it cant without freeon so due to the excessive working lol the compressor overheats and shuts off  if thats the case buy a new fridge
if you want to email me with a response  please do so at manison88@aol.com
Jun 06, 2009 | Whirlpool GD2SHGX Refrigerator
Marley md26 line voltage thermostat
The Black Wires from the md26 are your load(the heater) and the red lines are your line(power). The lines are also paired up on the thermostat with a red and black on the left and are red and black on the right. In the actual heater connect the black to the black wire and the white to the white and connect the grounds. In the thermostat connect the black from the heater to left side black( remember there are pairs left(black, red) right (black, red) and the white to the right side black connect the black from your power to the left side red and the white from your power to the right side red. Should be ready to go.
Nov 08, 2008 | Marley Electric Hydronic Baseboard Heater,...
Magic Chef MCWC30MCG not getting cold?
You need to replace the Ptc unit attached to the compressor. Go to REPAIR CLINIC.COM and order the following part. 1206838 Ptc relay. They also will show you were it is located and how to replace it. Compressor tanks very rarely go bad. It is an $11.00 dollar part
May 28, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
Hotpoint RLA80 Refrigerator Logo
110 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
