Question about ASUS P5PE-VM Motherboard
No display on built inn video card - ASUS P5PE-VM Motherboard
  • 784 Answers
Draivers? hawe you installed drivers or not?
Posted on Mar 17, 2011
Gigabyte G31
It is impossible to increase the performance of a built-in video card except increasing the video RAM. The more RAM you add the less main RAM will be allocated to the main memory. The reason is the video card uses Shared RAM.
To increase the video RAM go into the BIOS setup - video display - memory allocation.
The best way to improve is to install a video card in the AGP expansion slot, you may need to disable the on-board video in the BIOS.
Apr 06, 2012 | Gigabyte Intel G31 775 DDR2 )
It looks like the video plug is built into the MB if this is bad can a plug in video card be used?.
Hi Rich,
Yes a plug in video card, called a PCI-Express display card, can be plugged into your main board.
On your particular model I understand that there is a setting in the BIOS setup whereby you have to change it from on-board display to PCI display if adding the plug in card.
Best wishes,
Graemevm
Jan 07, 2012 | HP Pavilion Media Center a1320n PC...
Display not working
Hi! My name is Mace and I'm here to help you.
Are you using the built in video card or you are using a pci video card.
Assuming you are using a built in video card. Check the CMOS setup and make sure the video card is enabled.
Assuming you are using a pci video card. Try to disconnect it from the motherboard and reseat it properly. Better check also that the built in video card is disabled in your CMOS setup. And that you installed the driver if its not plug and play. Check also if the vga cable is properly connected to both the video card and the monitor.
Please post back if you still have some questions.
I hope this information will help you.
Thank you for using Fixya.
Jan 13, 2011 | Compaq EVO 500 DT/MT S478 P4 Motherboard...
One long beep and two short beeps. the red light flash on the motherboard
Good day.
Commonly, 1 long and 2 short beeps refers to a defective display card.
In a case that you have an external video card (separate from your motherboard - not built-in), turn-off the pc then remove the display card. clean the contact points with a pencil eraser, re-install the card then power-on again. If you received the same beep codes, then there is a need to buy a new video card.
In a case where your video is built-in to your board, to hard, but you need to buy a new board or disable the video adapter in your BIOS and install an external display card.
Just let me know if you need some more help.
Good luck.
Tedmac
Sep 28, 2010 | Computers & Internet
I have a Lenovo Thinkcentre A61e that has a display problem. The display is red and I have tried 3 different monitors with all the same results. Any idea why??
This is either a bad video card or the wrong or damaged Video drivers. If the display is red even when the computer first boots up before Windows even starts then it is the video card. If it turns red only after Windows actually starts then it may be the drivers.
1. Check for bent pins inside the video connector on the computer.
2. Check for bad video cable.
3. Remove and reseat the video card (if you have a separate video Card)
4. If the video is built into the system board, you could try to install a new separate video card to get around the problem.
Oct 14, 2009 | Lenovo ThinkCentre® A61E PC Desktop
I need to know what kind of sound card i have for my hp note book Model number: KR346AV
Processor Processor Class: AMD Turion 64 X2 Mobile Processor Speed: 2 GHz Cache Size: 1 MB Bus Speed: 800 MHz Memory Installed Memory: 2 GB Maximum Memory: 4 GB Memory Technology: DDR2 System Input Devices: Keyboard|Touchpad Interface Connection: Audio - Line In (1/8" Mini)|Audio - Line Out (1/8" Mini)|Audio - S/PDIF (1/8" Mini)|Bluetooth|Ethernet - RJ45 Twisted-Pair (XBaseT)|FireWire 400/IEEE 1394 - 4 pin|Infrared - iRDA Wireless (iRDA-SIR)|Port Replicator/Docking Station|Serial - RJ11 Modular (Phone/Telco)|USB - Universal Serial Bus 2.0|Video - S-Video|Video - 15 pin High-Density D-shell (VGA) Slots: Express Card 34|Express Card 54|Memory Stick PRO|MultiMedia Card (MMC)|SD Card|Sony Memory Stick|xD-Picture Card Display Display Size: 15.4 in Aspect Ratio: 16:10 Display Type: LCD Display w/ Glossy Screen Max Resolution: 1280 x 800 Video Chipset: NVIDIA GeForce 7150M Storage Included Drives: DVD+-RW DL Hard Drive Capacity: 250 GB Number of Storage Drives Included: 1 Features Included Network Card: Ethernet (10/100 Mbps)|Wireless Ethernet - 11 Mbps IEEE802.11b|Wireless Ethernet - 54 Mbps IEEE802.11g Included Devices: Built-In Microphone|Built-In Webcam|Headphones|Modem|Remote Control Software Operating System: Microsoft Windows Vista Home Premium Dimensions Height: 1.56 in Width: 14.05 in Depth: 10.12 in Weight: 6.06 lbs Warranty Warranty Information: 1 Year Limited Warranty More Info URL: URL General normalized-Cache Size: 1 normalized-Display Size: 15.4 normalized-Installed Memory: 2000
Sep 26, 2009 | HP (400745-001) Sound Card
In-built video card not working. how do i switch if off and use another video card via PCI slot?
you can disable from bios
is likely onboard vga
But if you plug in a PCI video card the computer will use that video card
Jul 09, 2009 | Intel Motherboard
Deleting corrupted data on ps2 meory card
Those Memory Max memory cards for PS2 ****, go get real PS2 memory cards. But the reason it has corrupted was it being turned off while saving, you have to delete the corrupted files and it will work again.
Jan 10, 2009 | Sony PlayStation 2 (PS2) Console
No display (black) - power light is amber color
The video signal is not reaching your monitor, check the pins on the connector from the monitor to the computer, then check the video card:
Turn off your computer, unplg the power, and then take out the video card. Wait 5 minutes and then put the card back into the computer and turn it on. For onboard video; turn off the computer, unplug the power, then hold down the power button on the front for 5-10 seconds, then plug back in and turn on.
Make sure the video card is snug in the AGP/PCI slot. If this is built-in video, try borrowing a video card from another computer and install it in this one. If the borrowed card works, then replace you card. If video is built in, then you can disble the onboard video and use the new card without having to replace your motherboard.
Jul 14, 2008 | ViewSonic VX910 19" LCD Monitor
Do I need a video card for this mainboard?
Since you have able to connect your monitor to the board it means that it has a built in video on the mother board but there's no display on the screen if that's the case there's a possibility that the built in video is not working fine, so I'm suggesting you get a AGP video card because its really better not to use the built in video.
Jun 16, 2008 | MSI PM8M-V Motherboard
ASUS P5PE-VM Motherboard Logo
18 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
