Question about Car Audio & Video
Amp probs my amp turns on and off while im driving, when i move it it turns back on the back off, whats the prob, does it need a better base, its setting in the floor in the back of my car.
  • Paul David
    Paul David Aug 02, 2008
    i have and the only thing i can think of now is the thickness of the ground and power wires, would that help any?
If its goes out because of movement, then its just loose wire or something. check everything, but start with the simple ones 1s...
sometimes we all tend to think the issue is always a complicated one, then we get mad when we find out at the end that the issue was right in front of us the whole time.
Posted on Apr 30, 2009
Check you ground wire and your power wire
Posted on Aug 02, 2008
02 ram 1500 pulled radio out - need to ck - found no amp -
The base model radio does not have a separate amplifier; the amplifier is part of the radio assembly. If you check 20A fuse 51 and 4.5A circuit breaker 2 in the integrated control module and you have power on the PNK and BLK /RED output leads, connect the radio and turn it on.
Oct 20, 2012 | Jeep 02 03 04 05 Dodge Ram 1500 Pickup...
Wheres my drives?
Go to www.download.com Type cnet_dvdrepair_zip this program will work in most cases bringing back the cd rom and dvd driver.
Jul 19, 2012 | Sony Computers & Internet
Hi Guys, i've just repaired my sons xbox 360 RROD prob using the screw kit and fired it up and it played a game. Now here's where it went a bit crazy, i moved the console from horizontal to vertical and...
ok, what you need to do, is leave it laying horisontal, this is actually better for the console, but after you open the console, remove the disc drive and make sure all moving parts are lubed up, and with the drive out, push the tray back in.
Dec 19, 2010 | Microsoft Xbox 360 Console
Makes a hard clicking sound in the passenger side tire area when i turn either way. ony when im sitting still and start to turn tho.
this sounds like a bad cv axle, this is what turns the wheels to make the car move if its clicking its going to break soon and leave you stuck out on the road, the axle needs replacing.
Sep 07, 2010 | 2000 Kia Sephia
My driver seat is moved front and back, up and down by the same switch located on the left side of the seat. the seat will not moved on any direction,what is the prob,need help, Tkns
Check connections under seat are all connected ok. Don't use a multimeter as airbag wiring also under seat and can set off an airbag if you don't know what you are doing! If connections are ok, you'll need a wiring diagram of the seat circuit, then you can investigate feeds & earths etc. Otherwise may be better to get it checked at your local GMC dealership.
May 08, 2010 | 1998 GMC Jimmy
Squealing belts?
this caused by engine rpm check belt for shine on flat side and see if you can move it up and down easily tensioner may be bad prob just old belt vote for me ok and let me know good choice of rides im a foreign mechanic
May 23, 2009 | 2004 Mazda RX-8
Check gauges prob
Hello
Welcome to RY
Sounds like i would run a scan on the ecm
engine control Mogul
there could be a number of problems this scan will pin point it. most auto parts store can do this.
RD
Jan 11, 2009 | 1999 Jeep Wrangler
4 wheel drive
i have the same prob the actuator in the front is not functioning an needs to be replaced
Jan 08, 2009 | 1998 Chevrolet Blazer
Toshiba probs with DVDRW drive
if you setup messenger live you can make free pc - pc calls or use chat service.you dont even need a web phone you just need to link a mic up .(2 jack inputs at side of pc..1 mic 1 speaker)
or if you dont have a mic yet and who you want to contact does one can speak and the other one can type .if both have webcam can make video calls and its all free.regarding your drive prob ....I dont think Ive seen it yet though cant be sure as I answer many
Jan 04, 2009 | Computers & Internet
Car Audio & Video Logo
91 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
