SOURCE: Problem with Bluetooth Transfer
There is one easy solution for the second question: You can set your SGH-L700 to store your photos and/or videos on your memory card. Just go to Settings -> Application Settings -> Camera Settings. Go to the rightmost section using arrow keys and change camera's default storing location as memory card, instead of phone.
The bluetooth problem is not that easy. There is one solution if you send the files from your PC. Just browse your "Bluetooth Devices" from your desktop - your SGH-L700 will appear as an independent device. Double click it's icon, you'll see the folders in it, just like you're browsing your computer's hard drive. Open "Memory Card" folder then drag and drop the files you want directly inside it. I almost always prefer this way when I use bluetooth transfer.
If you try right clicking on a file on your PC and choose "Send via Bluetooth" from the context menu, SGH-L700 receives it directly to the phone memory. So I recommend using "Bluetooth devices" option and placing the stuff directly in the memory card, just like you copy items in any place on your hard drive.
But there is not a standart solution for sending a file from another cell phone to SGH-L700. Some devices can browse SGH-L700's folders like your PC does, but some of them can't - and they just send the files to the phone memory.
SOURCE: Samsung a177 bluetooth help??????/
I'm sorry buddy because there is no way for your phone to pair up with
other BT capable phones because eventhough the phone has bluetooth, it
is only capable of pairing up with a bluetooth carkit & bluetooth
headset.
The SGH-A177 does not have a File transfer profile (FTP) under the bluetooth profiles that ur phone is supporting.
U
need to have another higher model but call Samsung first to inquire if
the other Samsung phone you want to buy has a file transfer profile.
check this bluetooth article.
that info is straight from Samsung....
SOURCE: Samsung S3310; Unable to copy messages to PC
Importing messages to computer is easy when we use other softwares for importing.PC studio cannot import messages from phone.Install FILE EXPLORER to transfer messages to PC.In file explorer connect phone and navigate to settings->messages->copy whatever messages you like and transfer it to the PC
SOURCE: im try to transfer files using bluetooth from a
Good day,there is probably an error in the established bluetooth link between the phones,my solution goes thus;
Put off the two phones and turn back on after 5mins,reconnect the phones via bluetooth and transfer the files,if the problem persists,it means the problem is solely from either of the phones,try transferring with other phone to establish where the fault is from and let me have a fitback to this solution
Thank you!!
SOURCE: I am using SAMSUNG GT
(1) Try to do a Samsung Master Reset:
CAUTION: A "master reset" changes the phone settings back to default. This process will erase all contacts, downloaded settings, and downloaded applications (ringtones, wallpapers, graphics, etc). This process cannot be undone.
Enter *2767*3855# from the standby screen. (You may need to remove the SIM before it will allow you to type the code in). (2)Yes, you can. (3) Just download it
Turn on the Bluetooth device from which you want to transfer files from or to.then turn the bluetooth of your samsung mobile..In most samsung mobiles the bluetooth can be turned on by going into applications where you can find bluetooth.
Press the "Search New Headset" button and allow the phone to search for the Bluetooth device. Once the device has been found, highlight it and press the "Select" button.
then you can transfer the files you want by going into options and then selecting the option of transfer via bluetooth.
