Question about Sewing Machines
NEED PARTS AND MANUAL CORD TO PLUG ELECTRIC AND FOOT PEDAL BOBBINS AND FOOT AC. BELT FORT SMITH, ARKANSAS AREA WHERE TO GO AND FIND THESE PARTS.
    Genius:
  • 1,788 Answers
Probably will be cheaper to buy a new sewing machine, you can buy one for under $100 online or Target, Premiere appliance.com, ebay etc
Posted on Mar 17, 2011
Hi, My Quantum 9960, needs the bobbin refilled, but the machine shows me an icon of the foot paddle, then an icon of machine and conect? cord. The cord is connected, I've tried it 3x. Don't know what to...
Is there an up arrow in the icon you see? What you describe could be the Release foot controller pedal icon. Take your foot off the foot pedal. See the trouble-shooting page on page 102 of the manual. The manual is available from Singer here: http://www.singerco.com/uploads/download/5b9200a32cfd31ffc30b8d29fd195a57dff4a9e3.pdf .
You are supposed to take your foot off the controller (or press Stop) after winding a few turns of thread on the bobbin. Trim the excess thread above the bobbin. Then step on the foot controller or press Start. Release the foot pedal again when the machine stops winding the bobbin. See page 28 of the manual for the procedure.
I hope this helps. If you do not have the Release foot controller icon displayed, please add a longer description of the icon or indicate which icon from the trouble-shooting section of the manual that is closer to the one you see. If you have released the foot controller and the icon persists, then something may be wrong with the control pedal. A replacement control pedal is ~$35; see http://www.sewingpartsonline.com/singer-9960-quantum-stylist-parts.aspx .
Jul 21, 2017 | Sewing Machines
Tip
Garage Sale Sewing Machines
Before you get a sewing machine for $25 at a garage sale, make sure it truly sews.
You will need to bring thread, scrap material, and a pair of scissors. (I bring a couple types of pre-wound bobbins and a needle.) First, does it have all the parts? Bobbin case, bobbin, cord, foot pedal? Are the cords frayed, or the plugs broken? Will the owner let you plug it in? Are you able to thread it and wind the bobbin? Does it make a stitch in the straight stitch AND zig zag modes? If any of these are no, walk away. Use that $25 to save towards a quality new machine, or wait for another garage sale.
on Mar 05, 2015 | Singer Sewing Machines
My pfaff 1222e is running slow
1. Remove any stuck material from the feed dog, bobbin area including the hook (pointed object under bobbin). Lubricate as you go.
2. Remove top and end of sewing machine to look at the motor and belt. Place pressure on the foot pedal. Still slow?
3. With bolt attached to motor release the pressure on the belt. Now, place pressure on the foot pedal. Did you notice any increase in speed?
4. Apply pressure on the foot pedal and simultaneously adjust the motor. Adjusting means tightening of the belt and making it move in a straight line. (If it doesn't move straight it puts pressure on the motor so it will move slow.) When you have adjusted the motor to the right position the motor will be at it's highest speed.
5. If the pressure foot is the problem it will require a pro to take care of it.
Apr 16, 2015 | PfaFF Sewing Machines
What might cause my sewing machine to not respond when the foot pedal is depressed?
make sure the plug for the foot pedal is connected securely to the machine.
could be the plug in the machine has a problem even tho the foot petal is plugged in
could be the foot petal has gone out and needs to be checked.
Jul 27, 2014 | Husqvarna Viking 1
Is the motor in my kenmore sewing machine bad?
will the motor run if you turn it by hand when the power is on
Apr 02, 2014 | Sewing Machines
Euro pro sewing machine 9106
try changing the needle--make sure it's the right type for the fabric being sewed
try rethreading the machine make sure to use every thread guide
make sure the power cord and the foot pedal are securely plugged into the machine
clean under the needle plate for lint and also in the bobbin area
also make sure the bobbin winder spindle is not pushed over to
wind a bobbin
if these suggestions don't help then it would be a good idea to have the machine checked..
Sep 11, 2013 | Sewing Machines
Machine in on and will not work, error code E7, does not have this code in manual, What does error code E7 mean
try these suggestion and if none of them work then you'll have to take the machine to a repair shop
change the needle and make sure the needle is for the fabric being sewed and is inserted correctly into the needle holder
rethread the machine top and bobbin and don't miss any thread guides
make sure the bobbin is not warped or damaged
make sure the bobbin is turned the right way in the bobbin case
if the bobbin is a front or side loading, make sure the bobbin case is inserted correctly into the machine
make sure the power cord and foot pedal is plugged into the machine securely
clean under the needle plate and in the bobbin area for lint
Aug 22, 2013 | Singer 7258 Sewing Machine
Foot pedal not working
Well, you are definitely getting power from the electric plug in.
Let's do some diagnostic work. Do you hear anything when you press the foot pedal? Any hum? Did you happen to leave it in bobbin winding mode?
your machine doesn't have a "sew" button for use without the pedal. So please rotate the hand wheel toward you as you press the pedal. Did the motor take over and sew?
If you know someone with a meter... have them test the pedal. (they will place probes on/in the part that plugs in which tests for shorts, etc.) If that tests ok... then we know it's something more than the pedal and it will need servicing by a Singer Tech.
Aug 27, 2012 | SINGER 7470 Sewing Machine
How to set up
  • Remove your Janome sewing machine from the box, placing the main machine on a hard surface appropriate for sewing and the accessories and smaller items to the side. Unwrap all of the wrapped items. Remove the tape used to protect the machine during shipment. Set aside the power cord and foot pedal.
  • 2
    Attach the power cord to the machine. The power cord plug-in area is located on the lower right side of all Janome sewing machines and has a series of metal prongs and a power switch. Fit the female end of the power cord onto the metal prongs and push it gently until it no longer moves.
  • 3
    Attach the foot pedal to the machine. The foot pedal plug-in is also located on the lower right side of all Janome machines, right next to the power cord plug-in. Press the foot pedal plug-in into place gently until it no longer moves.
  • 4
    Turn the power switch on. The power switch is located in the same area as the foot pedal and power cord plug-ins and is a rectangular black switch. Press this button. The sewing machine light will turn on.
  • 5
    Place a spool of thread on the spool pin, located on the upper right top side of the sewing machine. Place the thread so that the thread unwinds in a counterclockwise motion, with the thread coming off the back of the spool.
  • 6
    Insert a needle into your machine. Consult your owner's manual for the appropriate size and type of needle. Turn the needle clamp screw, located above the needle area, toward you to loosen it. Turn the needle so that the flat part of the upper shaft area faces the rear and slide the shaft of the needle up and into the needle area. Turn the needle clamp screw away from you to tighten the needle and lock it into place.
  • 7
    Wind the bobbin and insert the bobbin into the bobbin case. This procedure may vary depending on the model of your Janome machine, so consult your owner's manual for specific instructions.
  • 8
    Thread your machine according to the directions in your owner's manual. Like the bobbin, this procedure can vary widely depending on the model of your Janome machine.
  • 9
    Set your tension, located on the front of the machine, to halfway between three and four. The tension may be a dial or it may be computerized and located on the LCD screen, depending on your model. Consult your owner's manual to find out how to set the tension.
  • 10
    Place a piece of scrap fabric in the machine and sew a test seam before you start to work on a project to make sure all of your settings are correct.
    Things You'll Need
    • Janome sewing machine
    • Owner's manual
    • Needles
    • Thread
    • Bobbin
Jan 11, 2012 | Janome Sewing Machines
The needle does not move when the pedal is depressed, though the bobbin wheel and manual wheel do move, could this be attributed to a broken internal belt or?
Have you chosen a stitch pattern and a length, and made sure that the foot control plug is inserted correctely? Make sure your electrical outlet is good also. Good luck
Sep 16, 2010 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
