Question about Compaq Computers & Internet
Can't get computor to shut down properly - Compaq Computers & Internet
  • Matt Konyn May 11, 2010
    PC or mac?
    What operating system?  XP? Vista?  Tiger?  Leopard?
  • 876 Answers
Shut it down anyway and immediately turn it ack on and do a thourough cleanup. update your virus control and run it> go to Tools (at top) of screen and then internet options and clear your history and cookies>go to all programs> accessories>system tools.clean disc and do that little chore.. If you have a registry cleaner program run that also. When you are all finished try shutting the computer down again, This time if it doesnt work, go and ahead and shut it off anyway and turn it back on and do a defrag (same place as clean disc. Good luck and let me know..
Posted on Aug 02, 2008
My computor needs booting
By "clean my windows on my computor" if that means the software try this program : http://www.filehippo.com/download_ccleaner/ Download, install, and use it often. I'm not clear on my "my computor needs booting"? Shut down the computer and re-boot.
Nov 08, 2012 | Acer Aspire AS5334-2153 Notebook PC
Shuting off computor
Hello:
If this unit is shutting down your computer while it is installed and the computer does not shut down with it not installed then I strongly suggest you not use it. After all it is refurbished meaning there was a problem with it in the past for it to need to be repaired..
May 31, 2010 | Linksys Refurb WirelessG PCI Adapter...
MacBook locked up, won?t close down
The first thing to try is this: It is a keyboard shortcut to shut down a mac laptop. Press the control key (ctrl) at the bottom and press the eject button at the same time (top button all the way to the right which looks like an arrow pointing up with a line under it). This should bring up a window asking if you want to restart, sleep,cancel or shut down. Click Yes to shutdown! If this does not work, here is the second option. Press the power button down on the upper right side,and just hold it down until the computor turns off. I have done this many times with my own computor when it has crashed with no ill effects, I have heard from Apple that it is not good for your computor and can cause problems, so I would only do this if the keyboard short cut does not work Good luck and if you find this helpful please comment!.
May 17, 2010 | Apple MacBook Pro Notebook
Computor shuts down for no reason. then I have to
Hi, Make double sure that your CPU isnt overheating , Your PC Turns off when it detects your CPU getting too hot , so it wont overheat and get damaged....Try using Realtemp or Speedfan to check your CPU tempreture..
Hope this helps bud
Happy new year :)
Jan 02, 2010 | Audio Players & Recorders
Computor shuts down. screen goes to black. turn back on and get siren sound and screen says shut down due to thermal event. hit F4 to resume. had same problem a couple years ago and they replaced fan
try applying new cooling pest between cpu heatsink and cpu. Heat from cpu surface should be quickly transferred to heat sink. Either coolent problem or heatsink doesnot properly fit on cpu. But be carefull, you need an 'EXPERT' to do this, or you end up damaging everything.
Jul 30, 2009 | Computers & Internet
Computor shuts down compressor its telling itlow refrigrant
Check for any codes on the ecu, if fine, check for correct parts used to fix a/c.
Jul 08, 2009 | 1991 Oldsmobile Toronado
My computor shuts down after 30 minutes or more
I would start with a heat event problem. Check the easy stuff first, are the fans running, is there a lot of dust inside the computer. And that failing, get some artic 5 pop off the heat sync and apply a skinny little coat.
Should that not do it, next look to the video card, that can give you hangs and shut downs. Make sure it is seated properly. There are more things to check but that just might get you started for now. If this doesn't help please let us know.
Apr 30, 2009 | Computers & Internet
Can not connect camera on to computor
I would make sure I had enough system resources to run the program check to make sure you aren't having a problem with the driver for the camera software it may need updating in order to properly work. you can uninstall the provided software and reinstall it. Also try connecting the camera before you turn on computer (NHW) should recognize and notify you that new hardware has been found have your disk ready and let your new hardware wizard guide you through the rest of setup. you can always ask me to further assist you good luck and much success. wutxtye0rjd9d9ekmodqt1eoxkvn9hr9qjz1l3dabggyud7sdgr36czsrfxqenadhnijx9nfayi+sz1sug0aaaaasuvork5cyii=
Apr 21, 2009 | Sanyo Xacti VPC-T700 Digital Camera
T180 won't shut down.
Hi Fix Ya team.   Thanks for your email.Fortunately an update from microsoft seems to have fixed the problem,but I still have my fingers crossed.Thanks again.Regards to you all Tim.
Sep 19, 2008 | Acer Aspire™ T180 PC Desktop
When i power my computor down it , just turns back on
Hi, check the on / off switch, it is most likely sticky. To test it open your case and trace the wires from the switch to the motherboard. unplug the power switch wire and bridge the 2 pins together, this will start the computer. then power down and if it shuts down properly then clean or replace the switch. Regards mistyman
Sep 08, 2007 | EliteGroup GeForce 6100SM-M Motherboard
Computers & Internet Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
