Question about HP T5730 1GB/1GB + L1750 17" Monitor PC Desktop
HOW TO REBOOT - HP T5730 1GB/1GB + L1750 17" Monitor PC Desktop
    Sergeant:
  • 162 Answers
You could use the windows/linux/mac icon in the lower left corner and select reboot. or press the reset button, but that's not good for your system.
Posted on Mar 17, 2011
Who do you reboot?
I couldn't read the information on the screen.
If you need to reboot, there sometimes a reboot button. Pressing and releasing it will cause the computer to reboot.
If there isn't a reboot button, press and hold the power button until the computer turns off. Release the button and press and release it to reboot the computer.
Good luck.
Paul
Feb 17, 2016 | Computers & Internet
Tip
How to Reboot a Blackberry Without Removing the Battery?
If you remove batteries and hardware while tinkering with electronic devices, you might run into trouble down the line. Blackberry devices must be rebooted time and again, but you can reboot your Blackberry without removing the battery. <br /> <b><i>Instructions</i></b> <br /> 1. When you install a new program or have a system failure, you must reboot the Blackberry. This is the same concept used in larger desktop or laptop computers. 2. Hold off on using the new program by selecting "Later" instead of "Now" when you are prompted by the Blackberry. This will allow you to wait awhile to reboot your device, especially if you need to use it at the moment and can put off the new program installation. 3. Initiate what is known as a soft reboot by pressing and holding down the key combination of Alt+Cap+Backspace on the Blackberry keyboard. Using this method will also work when the device stalls and you see only the white arrow, but it refuses to move. 4. Note that certain Blackberry models are different and require you to press and hold the Alt+Cap+Delete key combination to reboot the Blackberry without removing the battery. Make sure your keypad is correct for using this method of soft reboot before attempting it. Blackberry makes several different models, and they all operate differently under soft-reboot conditions. 5. Reference your Blackberry manual. Make sure that the keypad soft reboot will work with the specific model you are using. Larger models are typically more prone to working with the aforementioned soft reboot. If this does not work, you will have to use a secondary method. 6. Check to see if you need to install an application for your phone that allows for a soft reboot. Many models, like the Pearl, allow you to download an application for soft reboot. These applications may prevent you from pulling the battery to reboot. 7. Try all the available methods, and if it still does not work, request assistance from your Blackberry dealer. She may know of an alternative or a firmware update for your device. <br />
on Jun 06, 2011 | Cell Phones
Reboot need on Toshiba Satelitte
Rebooting from the Windows OS can be done y a variety of means, depending upon the version of the OS. Clicking the START button or pressing the Windows key on the keyboard will get you to the POWER option where you can select RESTART (which is a reboot).
If you are not in Windows at the time, you can usually press the CRTL-ALT-DEL combo and get a reboot. Lastly, press and hold the POWER button until the device fully shuts off. Wait a few seconds and then power back on to get a reboot.
Dec 15, 2015 | Toshiba Computers & Internet
HOW TO REBOOT A SAMSUNG TABLET?
keep the on/of switch pressed for about 3 seconds, there will be three lines showing # power off # reboot # airplane mode. press the reboot and wait, action completed
Mar 02, 2015 | Samsung Galaxy Tab 3 7.0" - White...
How do I reboot without turning tower off{windows 2000}
start - turn off computer then select reboot.
It won't power off but it does reboot the hardware and windows. No other way to reboot without powering down.
Mar 23, 2010 | Dell Dimension 2400 PC Desktop
No boot. Continuous long beeps
Remove the following one by one: 1. RAM. Reinsert and reboot. 2. HDD cable (both from the motherboard and from the HDD side). Reconnect and reboot. 3. Power cable from the mother board. reconnect and reboot. 4. Processor. Reinsert and reboot. 5. The 3 connectors from the front basel to the motherboard. Reconnect and reboot.
Nov 05, 2009 | Abit KT7A (KT7A-RE) Motherboard
Computer does not reboot after a reboot command
usually it's a faulty RAM, doesn't it show an error on/during POST ?!?!
maybe just a loose connection between board and keyboard?!
if you can, debug the process:
1 - check cables
2 - disconnect all cables except keyboard, mouse and monitor
-- REBOOT
3 - open the case
4 - how many RAM dimms?!?!
5 - if more than 1, remove one of them and REBOOT
exchange them and reboot again.
this should help to identify the problem.
if all fails.... maybe a faulty board, or processor.
or some pci card.
Sep 16, 2009 | EPoX EP-3VSA Motherboard
Mozilla firefox keeps asking me to reboot, even when I try to rem
This is due to the registry entries that are installed with Firefox. Any major changes to the system registry requires a reboot. However, a reboot in this case is not immediatelly necessary. You can ignore this error and reboot later if you are working on something, or close out all programs and reboot the computer.
I hope this helps. Please let me know if you have any questions.
Thanks, Raph30
Jan 26, 2009 | Mozilla Firefox
Reboot to get rid of virus
When it says to "Reboot" it means to restart the machine, shut it down and then turn it back on again.
Jul 31, 2008 | Acer Aspire 5500 5570-2609 Laptop
HP T5730 1GB/1GB + L1750 17" Monitor  PC Desktop Logo
20 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
