Question about Asko 24 in. D3350 Dishwasher
Dishwasher keeps coming on and then turing off during all cycles, what could it be
  • Asko Master
  • 3,247 Answers
I am slightly unclear about the problem.
What do you mean by coming on and turning off during all cycles.
Does the dishwasher turn itself on even when it is turned off?
If coming on means the drain pump starts as soon as you select a program cycle then most likely the flood switch is activated which causes the pump to start to make sure there is no water left inside the dishwasher. You will have to find the location of the flood switch and dry it out. make sure power is turned off when you are working on the dishwasher components.
If this solves the problem there you also need to find out what is the source of the water leak.
Posted on Mar 17, 2011
4 Suggested Answers
  • 90 Answers
SOURCE: 18 in dishwasher drains water during cycles
find out how the dishwasher is set up to drain. Pour water into dishwasher 4 or 5 gallons, see if water disappears. if so, your drain is ran wrong
Posted on Jan 05, 2008
jmgldsmth
  • 1906 Answers
SOURCE: dishwasher stops during cycle. Have to push on door to start again.
Have someone replace your bad door switch
Posted on May 20, 2009
  • 784 Answers
SOURCE: rinse cycle on top drawer keeps turning on
You have a leak due to the Lid seal leak.
1- Unplug the power, then pull out top draw half way and
2-Touch the bottom top housing ( not bottom top draw) you will feel it wet. Try to dry it by stick in a towel.
3- Repeat the same for the bottom drawer.
After drying out, wait for at least 1 day so the sensor can be dried out then plug in the Power, you will be fine.
4- Contact me for the next step.
Posted on Jul 03, 2009
Motor keeps running. Water heats fine. Help
One of the reasons for motor not draining during normal cycle is the check valve is stuck. It is meant to return to normal during drain cycle but close during wash. I think the cancel is resetting it and letting water out.
See this discussion.
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dishwasher/26-129-977852-/Bosch-Dishwasher-won-t-drain-SHE43RF2UC64
Apr 02, 2014 | Bosch 24-in Built-In Dishwasher Color:...
Kenmore 665 Dishwasher
Sound like you have a bad control console, which will need to be replaced.
Apr 08, 2012 | Kenmore 13742 / 13744 / 13749 Built-in...
Hi I have a DD603 F & P dish drawer. I had an F2 fault, found the rotor motor seized. I've replaced that but F2 still comes up & the water doesn't drain away. Any ideas?
Before we talk about water not draining away, can you confirm if the wash arms rotate during the wash cycle. The rotor works as a wash pump and drain pump depending on which cycle it is in.
If F2 keeps coming then it is also likely there is some debris in the rotor cavity which is grinding on the rotor. But one needs to be sure if F2 is coming up only in drain cycle or is it already on during wash cycle.
May 16, 2011 | Fisher and Paykel 23 in. DD603H SS...
My Kenmore dishwasher will wash okay but, will not rinse. It runs during the rinse cycle but, no water comes in during cycle.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Sep 08, 2010 | Kenmore 24 in. 16032 Built-in Dishwasher
Dishwasher stops during cycle and full of dirty water
you are having a problem with your door latch.the unit may not be staying closed or the latch strike is not in position to engage the door switches.
check the metal bracket just where the door closes and try to bend it downward , closer to the door and see if this helps to keep it working.
Jan 20, 2010 | Dishwashers
Du1100xtpq7 has had the touch pad replaced along with the circuit board that goes behind it and yet it just keeps repeating the wash cycle and goes for hours
i would guess that you are having a problem with the optical sensor inside the pump housing. it is suppose to sense when the water is clean or dirty and allow the unit to continue washing or advance to the next cycle.
i have seen these test good but be just out of calibration enough to cause long run times.
you can try to change it yourself or have the service company try that instead of a new board and panel.
Jan 07, 2010 | Whirlpool 24 in. DU1100XTPS Built-in...
Rinse cycle on top drawer keeps turning on
Jul 01, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Jan 05, 2008 | Kenmore 15121 Built-in Dishwasher
Dishwasher only runs in rinse only mode!
my dishwasher just keeps bleaking clear AND NO WATER IS GOING INTO THE MACHINE IT JUSTS KEEPS RUNNING BUT THEIR IS NO WATER COMING IN.
THANKS
Jun 30, 2007 | Maytag 24 in. MDB5601A Free-Standing...
Asko 24 in. D3350 Dishwasher Logo
223 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
