Question about Dyson DC17 Animal Bagless Upright Cyclonic Vacuum
Is there a way to stretch the hose ? when I use it the vacumm is right behind me and is hard to use.... it just wont extend unless the vacumm is held against something Thanks !
How far should you stretch hose when doing stairs
only as far as they will reach of course , that is why they made a lift away vacumm
Feb 25, 2017 | Vacuums
Stiff hose on new Dyson Animal upright
You need to call Dyson, but bet this is as designed.
Dec 19, 2016 | Dyson Vacuums
Dyson DC14 hose won't extend and floor unit lost suction
Sounds like the exhaust side is clogged. Remember a vacuum pulls air into the cavity, but for it to work properly it also has to be able to exhaust the same amount of air it takes in. If the exhaust is blocked it will continue to suck air inside and collapse on itself, which is why your hoses are getting shorter and harder to move. Check the exhaust system for any blockages, perhaps the hole you taped was the exhaust.
Mar 15, 2015 | Dyson Vacuums
No suction at floor section only on hand held part
clean the hoses and any part connecting the actual vacuume to the floor attachment.... probably clogged or not getting a good seal....if the motor sounds like its going faster (higher pitch) then its clogged up.....
Nov 09, 2013 | Russell Hobbs 14835 Tornado Stretch...
The extended vacuum tool will not retract into the handle and therefore no "vacumm" is created
the wand ? if the wand won't go back into the hose, sprinkle baby powder on it and see if that helps. The inside of Dyson hoses get sticky after a few years.
Oct 18, 2013 | Dyson DC14 Animal Bagless Upright Cyclonic...
Hose in DYSON too tight and hard to pull out
The problem is not a twisted hose. The hose itself is way too stiff. It pulls the vacuum around instead of expanding to reach. I hate this hose and it's too bad, because the vacuum works well, but trying to use the hose attachment it futile because it just doesn't stretch out unless the vacuum is pinned up against something to keep it from rolling and tipping over.
Nov 24, 2012 | Dyson DC25 Vacuum
How to stretch the dyson ball vacuum hose
I'm sorry to hear you're having difficulties with your Dyson. Due to the machine's very powerful suction, it's normal to experience a certain amount of resistance from the hose in use. However, you may find that stretching out the hose to it's fullest extent with the machine switched off, while someone else holds the machine in place, helps loosen it up a little.
If you've tried this and are still concerned, please get in touch with us directly so we can provide further assistance. You can call us free on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Feb 07, 2012 | Dyson Ball DC24 Bagless Upright Vacuum
How do I get the beater brush off of the vacumm to replace the belt? The vacumm is a Shark roadstar . I can get the belt on the one end but I cannot get the brush up to put it on that end. Judy It is a...
SUGGEST YOU COPY AND PASTE THIS ADDRESS INTO YOUR BROWSER'S ADDRESS WINDOW ( https://www.youtube.com/results?search_query=CHANGING+BEATER+BRUSH+BELT+ON+A+Shark+Roadstar+EURO-PRO+Model+No.+UV208C) TO SEE THE YOUTUBE VIDEOS ABOUT THIS ISSUE
Jan 09, 2018 | Vacuums
Hose has suction but will not stretch when turned on
Hi.
I have repaired Dyson machines for years & have never come accross this.
The only way you will have trouble extending the hose is if there is a blockage at the bend where you hold the wand could be a coin which when switched on flips accross & blocks oppening.
Is it easy to slide wand from flexi hose with machine switched off ? You will need to remove wand from hose & push broom handle down to the bend & tap coin out.
http://dysonmanuals.llc.nu/
Chris..
Jan 08, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
U5397-900 - wont clean carpet
could be, but probably just needs a new belt - they stretch.
Dec 16, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
19 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
