Question about Apple Computers & Internet
The space bar won't work at all. I've tried removing it and replacing but no luck. Thanks Vicky
    Sergeant:
  • 162 Answers
Then it's probably broken. sorry.
Posted on Mar 17, 2011
look for debris under the space bar, if not proubably needs keyboard disassambled and cleaned.
DickyO
Oct 11, 2012 | Brother SX-4000 Electronic Typewrite - 10...
After replacing needle, needle threader won't work. What am I doing wrong?
You probably haven't inserted the needle fully into the needle bar. Try that first.
Also check that there isn't a bit of needle shank in the holder.
Good luck.
Oct 04, 2012 | Brother Sewing Machines
About alternator replacement for 2001 vw beetle gls...I've removed the upper and lower bolts... What am I missing? Alternator still won't budge. Any assistance would be appreciated. Thanks.
all the bolts removed then all thats holding it is the adjustable tube in on the lower fitting ,put a bar in and try moving it then it will move as on the lower fitting with the long bolt is a tube in the alternator housing bracket and this is pulled or pushed out to make contact with the support bracket .Check you havent got three bolts holding it as some vehicles have two bolts on the bottom bracket or one long one
Apr 15, 2012 | 2003 Volkswagen New Beetle Convertible
How do i adjust the contrast on my acer aspire 5738z laptop
@tonymclau330
Try the following:
For Windows Vista / 7
1. Press the Fn+Left Arrow Key for brightness down and Fn+Right Arrow Key for brightness up (the Fn key is located at the left side of the space bar)
2. If that won't work, go to Start > type Power Options and click on the Power options icon.
3. Adjust the screen brightness bar below.
Good luck.
Sep 07, 2011 | Acer Aspire 5630 Notebook
Space bar reassembly
you can replace from any keyboard that is no more working. just remove the metal bar and replace it with yours. Except you want to buy another keyboard.
You can also try fixing it later, you might get a solution on your own, maybe you are exhausted or worn out. Just relax your brain and by the time you go back to it, You might just get it right this time around.
Wish you the best of luck.
Nov 05, 2009 | Audio Players & Recorders
Need to remove the space bar to recover a lost bead
You shouldn't have to remove any keys, try this >>>>>
Get yourself a clean dry paintbrush, turn the laptop off but leave the lid open, turn it on its side and gently brush the keys, gently tap around the keyboard with the back of the brush to knock out any foreign objects or beads that maybe trapped under the keys.
Good luck.
Aug 20, 2009 | HP 413669-001 - HP Compaq nc6320, nx6310,...
When i try and play a application on my new itouch ipod 16gb it t
Hi Vicky-Joy,
it is always a good idea to turn off your ipod touch or iphone after installing an application.
To do this, hold down the sleep/wake button on the top for 6 seconds until slide to turn off apears.
Then turn the ipod back on again, and it should work properly.
Also bear in mind that it may be poor programing that is causing the application to crash and exit out of itself.
Hope this helps,
Nathan.
Apr 05, 2009 | Apple iPod touch
My spacebar issticking.
Yup! you can do that.. carefully... i repeat, carefully pry-upward the space bar using a hard plastic card (I.D cards are best). Clean the hinge with a brush. Press down till you hear a click to return the key back to its position.
Mar 15, 2009 | Dell Latitude D600 Notebook
Keyboard space bar
turn your keyboard upside down and tap it a few times. if that doesnt solve the problem repeat.
If it still won't work write back for more ideas.
good luck and please rate my answer. thanks.
Feb 03, 2009 | Toshiba Satellite A100-S8111TD Notebook
Computers & Internet Logo
23 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
