Question about Samsung Televison & Video
Samsung dvd player + amplifier, when touched on the body its getting shock.current. it has 3 pin plug & i have proper earthing at home.
  • 604 Answers
You need to go to your hardware store and purchase a ground fault testor (they cost about 10 dollars) this will tell you if you have problem with your wiring in the house. This may also be a problem inside the device, as most devices these days are isoltated from ground, what may have happened is that something inside the unit is pinched against the case and causing current to flow through it THIS IS A VERY DANGEROUS CONDITON, do not use the unit till this is resolved. First step is to insure that your house wiring is ok.
Posted on Mar 17, 2011
It currently has a 2 pin plug going into a 3 pin plug for the power? Getting lots of shocks and am thinking of cutting off the 2 pin to allow me to wire up a brand new 3 pin plug.
A 2 pin plug is standard on a double insulated product. If you cut this plug off, you will probably find there is no earth wire to connect anyway, so a 3 pin plug is not going to help. If you are getting shocks of it, I would suggest there is something dangerously wrong with your equipment. Get it checked before the next boot you get of it is your last!
Apr 19, 2015 | Pioneer DJM-700 Standard Mid-Range...
I opened and started my laptop for first time on 26th April 2013, after initial settings and windows activation on same date,the battery was shown low by laptop,so I plugged charger. Now,as I am charging...
Are you using a 2-pin plug?
Usually when you use the 2 pin plug, there is no earthing/grounding available so the current passes through your body to the ground.
Try using the 3 pin plug. It should solve the problem.
In case it doesn't, it's better to get your laptop checked.
You can buy a 3-pin plug laptop charger at
http://memory4less.com/adapters-and-accessories
Mar 29, 2017 | ASUS Q200e Touchscreen Notebook
How to wire trailer plug
hope this helps
6 pin socket
6 pin plug
7 pin socket
7 pin plug
5 pin socket
5 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
12 pin socket
12 pin plug
small 6 pin round plug & socket
1 tail, clearance - brown
2 left hand turn - yellow
3 right hand turn - green
4 stop - red
5 electric brakes - blue
6 earth - white
small 7 pin round plug & socket
1 left hand turn - yellow
2 reverse - black
3 earth - white
4 right hand turn - green
6 stop - red
7 tail, clearance, side markers - brown
roundskt.jpg round socket
large 5 pin round plug & socket
3 earth - white
5 right hand turn - green
6 stop - red
large 7 pin round plug & socket
2 reverse - black
3 earth - white
6 stop - red
7 pin round heavy duty plug & socket
1 earth - white
2 left hand rear , clearance and marker - black
3 left hand turn - yellow
4 stop - red
6 right hand rear , clearance and marker - brown
7 reverse/auxilary - blue
7 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
7_flatsocket.jpg flat socket
12 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
8 battery supply - orange
9 auxiliaries - pink
10 earth - white
11 rear fog lamp - grey
12 auxiliaries - violet
Feb 02, 2013 | 2004 Toyota RAV4
I don't know why but whenever I'm connecting the power cable with laptop I'm getting shocked from metal parts of the laptop. Is it any kind of earthing problem? Please help me before my laptop...
Yes you are correct. It is because of earthing issue. Laptop has 3 pins out of which 1 is Earthing, 2 is positive and 3 is negative. Out of 3 pins, 2 pins will function properly however for Earthing, it is necessary to have some arrangement at your place.
Please get earthing solution implemented and then plug the laptop power cord into power socket. Else you will face the shock and it may happen that your laptop's internal part may get damaged.
Thanks,
Amar
Aug 30, 2011 | ASUS K52n-a1 Notebook
My new SWR workingpro 12 has a low frequency permanent noise, any idee ? Maybe from the Power supply... Thanks, bolliger_rudolf@bluewin.ch
All amps make a small amount of noise (system hiss) but the amps own power supply should not cause a problem on it's own.
However if the frequency is around 50hz (the G 2 1/2 octaves below middle C on a piano) it is most likely due mains electricity interference or an earth (grounding) issue.
Here are a few things to try to identify the source.
  1. Could be a lack of earth (grounding) This is potentially VERY DANGEROUS and could result in electric shock if you touch a metal part of the amp or touch some other metal object (like a microphone stand at the same time as your guitar strings). Check the earth wire is firmly attached at both ends of the power supply lead.
  2. Could be a defective mains socket - try plugging it in to a different one, preferably on a totally separate circuit.
  3. Could be an earth loop. These can occur if you are using the amp with an output to a public address system or mixer that is also earthed because of a 'potential difference' between the two earths. Solution - use the balanced (xlr) output which incorporates an earth lift rather than the unbalanced jack output.
  4. Unplug any effects pedals, foot-switch etcetera to see if that eliminates the problem. Turn off any internal effects, including bass intensifier.
  5. Make sure any signal cables (guitar leads) have good quality screening and that the screen is well soldered to the jack plugs at both ends.
  6. Ensure signal leads do not lay along side (parallel) close to mains electricity cables but are well separated and only cross at right angles.
  7. Move the amp away form other electrical equipment that may have a powerful magnetic field (especially CD or DVD players, hearing loop amplifiers, radio microphone transmitters / receivers, mobile phones
  8. Turn around or stand in a different position - it might simply be the pick-ups in your guitar causing interference in the magnetic field of the power supply.
  9. Does plugging in or unplugging a signal lead / guitar make any difference? This particular amp requires only mono jack plugs a stereo (trs) plug may be shorting across terminals
  10. Does it change when you touch the strings with your hand? If yes check internal wiring and screening within the guitar.
Feb 09, 2011 | SWR Workingpro 12 200watt 1x12" Bass Combo...
I just bought a Samsung HD LCD 32 in TV and want to play it through my Home Theatre System. I set the TV to external speakers, put the HTS in aux mode, but I don't get sound. My old Samsung SDTV would...
If you do not have a manual for the machine down load one at http://www.samsung.com/us/support/downloads/LN32B460B2D
It will show you how to set up a Home Theater Connection
Connecting an Amplifier / DVD Home Theater
TV Rear Panel
1 Audio Cable (Not supplied)
Amplifier/DVD Home Theater
1 Connect Audio Cables between the
AUDIO OUT [R-AUDIO-L] jacks on
the TV and Audio Input jacks on the
Amplifier / DVD Home Theater.
When an audio amplifier is connected
to the AUDIO OUT [R-AUDIO-L]
jacks: Decrease the volume of the TV
and adjust the volume level with the
Amplifier's volume control.
Each Amplifier/DVD Home Theater has
a different back panel configuration.
When connecting an Amplifier/DVD
Home Theater, match the color of the
connection terminal to the cable.
Nov 29, 2010 | Samsung LN32B460 32 in. LCD HDTV
Screen remains blank when starting up, K7S41 motherboard,
Unplug the data cable of your monitor and using a tester, check if it is carrying some electric current. If the tester doesn't show any current, try touching the pins of the data cable to make sure it doesn't give a shock on touch (do this on your own risk). If it does give some shock, you need to properly earth the monitor. So, earthing the monitor MAY solve the problem.
Sep 09, 2008 | Asrock K7S41 Motherboard
Annoying hum
First of all touch the metallic body of the amp with your palm after removing your footwear and find out if there is a reduction of the hum sound. If the hum is reduced that means there is no proper earthing .Check whether the power supply is properly earthed.If there is no earth connection in your home wiring there will be hum.You can ask your electrician to solve this problem and then switch on the system.
If the problem persisits check the audio cable for any damage and replace the cable with a new one.
Sometimes the hum may be caused by a tubelight which is taking power from the same plugpoint you are using for your player.this can also cause noise.
Jan 07, 2008 | Creek 5350SE Amplifier
Bac speaker bose 321
The arrays from this system are only designed to run with the Bose Acoustimass / subwoofer, which in turn will only work with the Bose DVD player. If you use them directly to an amplifier, they'll sound poor / wierd and you probably blow the drivers. You might even damage your amp.
Each speaker has 2 drivers firing in slightly different directions. The idea is (when its used with the 321 system), the inward speakers give a mix of front and centre, the outer drivers give a mix of front and rear. A normal amp won't do this....
Nov 28, 2007 | Bose 3·2·1 II System
Televison & Video Logo
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
