Question about BenQ MP510 DLP Projector
How do you reset the projector after lamp installation?
  • 24 Answers
Its a pretty simple process on this particular model make sure the new lamp has been installed properly, and the power to the projector is on and then:
i. Press and hold the Up Arrow on the projector for 5 seconds to display the total used lamp time.
ii. Press AUTO on the projector or on the remote control to reset the lamp hour to "0".
iii. Wait about 5 seconds to let the OSD disappear.
That should take care of it...
Posted on Mar 17, 2011
  • 5 Answers
SOURCE: sanyo plc xu 40 lcd projector problem
not only reset the timer is good enough
u must use serive cable to disable the shut off function
and technically reset the system
Posted on Jul 10, 2008
  • 3 Answers
SOURCE: Reset Lamp Hours Timer
Make sure the main power switch is OFF. Hold the "ON", "MENU", and "VOLUM -" buttons at the same time and turn the main power switch on. Keep them held until the yellow power standby light comes on, then let go. It is done.
This works for Toshiba TDP T-9
Posted on Jul 11, 2008
  • 7 Answers
SOURCE: optoma DX605 hard reset
Have you tried going to Menu>Options>Lamp Settings>Lamp Reset>Yes?
Hope this helps!!
Posted on Jul 13, 2009
  • 630 Answers
SOURCE: Replaced the projector lamp 3 weeks ago. Reset
If the lamp is working it should be fairly obvious but stand to one side of the lens and see whether there is any light coming from the projector. If there is you know that it's an input problem. If there isn't either a fuse has gone, the bulb has blown or the filters might need cleaning. If the bulb has blown it's probably because you handled the bulb. It's vital not to touch these bulbs with your fingers. If you do wipe it with methylated spirits.
Posted on Aug 21, 2009
SOURCE: Benq PB8220 lamp used for 375 hrs shuts projector automatically
Unplug any cables from the projector (except for power)
On the device (not the remote control) hold down exit for 3 sec
lamp status are shown
on the remote control use MENU, and then left right to reset lamp
Posted on Oct 01, 2009
How to reset mitsubishi VLT-XD221LP projector lamp reset Kumar Salem
Reset of the lamp operation time
1,Connect with the Power cord, and turn the power on.
2,with a signal supplied to the projector.
3,Menu--INSTALLATION--LAMP TIME RESET-and press
ENTER button to reset lamp operation time.
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
Oct 07, 2013 | Mitsubishi VLT-XD221LP Replacement Lamp...
I replaced the lamp on my XGC55X Sharp Projector and it worked great for 2 nights (roughly 6 hours). Now it goes to warm up, with the lamp light blinking, and will power down with the status button showing...
Have reset the lamp hours after installing the new lamp? If, not the projector has treated the new lamp as old lamp & refusing to light further. So, reset the lamp hours to zero. To reset the lamp timer do as follows. Plug the power cord into the AC socket of the projector. Switch ON the power of the socket. (not projector) While pressing simultaneously INPUT, ENTER & UNDO on the projector, press ON on the projector. "LAMP 100%" is displayed, indicating that the lamp timer is reset.
If this does not correct your problem then the problem lies in other area. Let me know so that further I can provide you solution. Above things are preliminary
Aug 06, 2011 | Sharp XG-C55X Multimedia Projector
I have a sharp xg-c55x. I put a brand new lamp. It worked once for about 20mins. Since then it starts warming up & then it turns off. How do i fix or reset? Thank you
If this does not correct your problem then the problem lies in other area. Let me know so that further I can provide you solution. Above things are preliminary.
Jul 07, 2011 | Sharp XG-C55X Multimedia Projector
Red lamp light is blinking. Replaced lamp and light is still blinking.
The lamp still does not light up after the new lamp installed? Or the lamp is working but the Red lamp still blinking? Reset the lamp timer after the lamp is installed?
Description of product:
Replacement RPTV projector lamp HITACHI 50C10
Supplied equipment: gloves, filter
Lamplife (hours): 5000
Performance (W): 100
Lamp type: UHP
Changing the lamp:
1. Turn off the projector and unplug it. Let the projector cool for at least 45 minutes. The hot lamp can burn you!
2. Find the lamp cover on the projector and remove it by loosening the screws on it.
3. Use a proper screwdriver to loosen the screws which secure the lamp inside the projector.
4. Grasp the lamp by its wire handrail or handle plate and carefully remove it.
5. At this point, always clean the projector and replace the air filter which provides air to the lamp.
6. Install the new lamp according to the aforementioned instructions in the reverse order.
7. Turn on the projector and turn the lamp operation counter to zero.
Changing a bare lamp without module:
4. Grasp the lamp by its wire handrail and carefully remove it.
6. Remove all impurities from the lamp module. If it is damaged, or if the connectors are oxidized, order a new complete module - you will thereby prevent and potential damage to the lamp or to the projector!
7. Examine and remeber in detail the method by which the lamp is fastened in the module, and the method of clamping the connectors - or mark the original connection.
8. If one of the connector parts is firmly fastened to the lamp, it will be necessary to disconnect it. Plug the cable eye to the end of the connector. The cable eye is included with the lamp.
9. Carefully remove the old lamp from the module. Wear a glove when installing the new lamp. The glove is included with the lamp. Never touch the lamp with your bare hand!
10. Insert the new lamp into the module and tighten the connectors.
11. Install the new lamp according to the aforementioned instructions in Numbers 1 to 5 in the reverse order.
12. Turn on the projector and turn the lamp operation counter to zero.
Reset the lamp counter hours of operation for the projector HITACHI 50C10
1. Turn on the projector
2. Press the "RESET" button on the remote controller for at least 3 seconds and the dialogue window will appear
3. Select the "RESET" function
4. The counter is at zero
Product websites:
www.hitachi.com
Dec 03, 2010 | Hitachi 50C10 LCD TV
Need to reset lamp. replaced lamp and installed new lamp.
Press RESET, <, >, ENTER keys on remote within 5 seconds to reset lamp timer.
Jul 29, 2010 | Sony VPL-CX86 Multimedia Projector
How do you reset the Projector after installing a new lamp?
There are two common methods to reset the lamp counter on these projectors: Method 1: - Press the decrease volume button on the remote and then the increase volume button within 3 seconds. - The LED light on the projector will turn green. - Turn on the projector. Method 2: - Turn on the Projector. - Open the standard menu using the remote. - Then select "Setup" or "Service" depending on your projector model. - Then select "Reset Lamp Timer" hope this solution has been helpful?
Jul 19, 2010 | Sharp Projector lamp Projector Lamp
Optoma DX605 hard reset
Hope this helps!!
Mar 15, 2009 | Optoma DX605 Multimedia Projector
HOW TO RESET TOSHIBA TDP-S8 LAMP
after installing the new lamp, hold the volume top & bottom key simulteniously, when green light indicate at panel start the projector & go to service there you may found reset lamp ? press yes the lamp will reset.
Feb 01, 2009 | Toshiba TDP-S8 Multimedia Projector
Toshiba Projector TLP 651 lamp problem
yes resetting the lamp hour might be the issue but not necessarily. It could also be a temperature issue as the fan (s) might have stopped or a temp sensor issue is faulty. check your manual for resetting lamp hours. Regards Kevin Andreassend www.iceav.co.nz iceavtech@gmail.com
Oct 28, 2008 | Toshiba TLP450, TLP451, TLP650, TLP651,...
Cannot reset projector after new lamp installed
hi
Have you reset the lamp timer after replacing the lamp, if not then do so and see the user manual for that.
Viren
Jan 24, 2008 | Canon LV-LP12 Projector Lamp for LV-S1,...
BenQ MP510 DLP Projector Logo
572 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Electro Med Services...
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
